Thread: Vw golf mk4 pd130 oil consumption
Results 1 to 10 of 10
  1. Vw golf mk4 pd130 oil consumption
    Jul 2010
    peebles
    Hey all I have a golf mk4 pd130 recently had a head rebuild and new turbo. Car doesn’t smoke but seems to be using a lot of oil roughly 1litre to 500 miles of easy driving. Car is on 140k and has been serviced all its days. What could be the problem hear are their any common faults to look for. Thanks Martin
  2. Re: Vw golf mk4 pd130 oil consumption
    1836 Post(s)
    That is a lot, the VAG specified maximum is 0.5 Litre per 1000Km so half a litre per 620 miles. That you are not seeing smoke makes me think the engine is burning the oil as fuel so my first step would be to investigate the charge air system for traces of excessive oil such as this when disconnecting the lower intercooler inlet, sorry the pic is refusing to show.
  3. Re: Vw golf mk4 pd130 oil consumption
    Jul 2010
    peebles
    Hi thanks for the reply. The car has had a new turbo and intercooler. Where would you suggest the oil is going to be? Thanks Martin
  4. Re: Vw golf mk4 pd130 oil consumption
    1836 Post(s)
    See what is in the intercooler intake.
  5. Re: Vw golf mk4 pd130 oil consumption
    Jul 2010
    peebles
    Car has just had a new turbo. I will double check is their anything else off the top of your head or could be. Also when starting from cold their is a slight misfire that I can’t get it the bottom of either after fitting new glow plugs full service etc
  6. Re: Vw golf mk4 pd130 oil consumption
    1836 Post(s)
    Did you fit new injector seal kits and bolts?
  7. Re: Vw golf mk4 pd130 oil consumption
    Jul 2010
    peebles
    Yeah everything head wise is new and if good quality parts. Starting to think maybe a dodgy deal or a seal not sitting properly causing oil to get down through to cylinder
  8. Re: Vw golf mk4 pd130 oil consumption
    1836 Post(s)
    So a new head and injectors?
  9. Re: Vw golf mk4 pd130 oil consumption
    Jul 2010
    peebles
    Sorry old injectors new seals fitted
  10. Re: Vw golf mk4 pd130 oil consumption
    1836 Post(s)
    But a new head casting without any injector bore wear?
  1. Vw pd130 remap copy to audi pd130???
    By Martynas26 in forum 1.9TDi - Engine
    Last Post: 02-09-2015, 10:15 AM
  2. mk4 golf gttdi pd130
    By Kat.M in forum Golf MK4 - 1999 - 2004
    Last Post: 22-01-2015, 11:30 PM
  3. Question 2002 Golf PD130 aircon
    By john tofts in forum Golf MK4 - 1999 - 2004
    Last Post: 11-09-2013, 05:44 PM
  4. Question new exhaust for PD130 Golf
    By tim0000037 in forum New Member Introductions
    Last Post: 17-11-2008, 10:17 PM
  5. 2002 Golf PD130 Knock
    By Monkey117SE in forum Archive posts
    Last Post: 26-08-2007, 09:15 PM
