Thread: 1.6 8v 75kw smoking problem
Results 1 to 8 of 8
  1. 1.6 8v 75kw smoking problem
    Dec 2020
    Croatia
    Greetings
    My gf has new beetle 2001 with 1.6 8v 75kw petrol engine, car started smoking and failed MOT emissions test, the smoke is pure white , reaka of petrol
    I changed catalyst and both lambda's (original bosch) , i removed cylinder head and replaced valve steams and head gasket, also changed intake manifold seal rubbers
    Engine works fine, car pulls good but its smoking alot, white smoke with petrol smell... there are no error codes with vcds
    On MOT emission test there is very high CO which indicates too rich (too much fuel in air fuel ratio)
    Im currently stuck and have no ideas, hoping someone can help me solve this nightmare : D
    Best Regards
  2. Re: 1.6 8v 75kw smoking problem
    Dec 2020
    Croatia
    Forgot to mention , ive took it to my friend mechanic which has emission test machine and test was perfect , no smoke at all in the morning (0.1 CO) and afternoon we re-did the test and car failed (4-5 CO) and smoked alot...i dont know what to suspect ? Faulty ecu?
  3. Re: 1.6 8v 75kw smoking problem
    1837 Post(s)
    If it is that rich it has to be storing a fault code, what are you using to read the codes? Is it using oil or coolant?
  4. Re: 1.6 8v 75kw smoking problem
    Dec 2020
    Croatia
    Sometimes system too rich trouble code, no oil or coolant consumption, i have vcds and launch diag
    I will try to replace fuel regulator
  5. Re: 1.6 8v 75kw smoking problem
    1837 Post(s)
    Fuel pressure regulators very rarely cause problems.
  6. Re: 1.6 8v 75kw smoking problem
    Dec 2020
    Croatia
    Injectors? Fuel pump ?
  7. Re: 1.6 8v 75kw smoking problem
    1837 Post(s)
    Anything like that and the pre and post cat Lambda sensors will pick it up. Have you had a fault code for the tank vent system? Which engine type code, AWH or AYD?
  8. Re: 1.6 8v 75kw smoking problem
    Dec 2020
    Croatia
    Not fault codes at all, occasionally system too rich code
  1. Please Help Intermittent smoking problem on my gt
    By Doubledaddy in forum Golf MK5 - 2004 - 2009
    Last Post: 03-10-2015, 01:39 AM
  2. passat 2007 2.0 diesel smoking misfire problem
    By johnkent in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-06-2015, 08:19 AM
  3. Smoking A4 3.0 TDI
    By chrishyde6666 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-01-2010, 01:43 PM
  4. vw passat 1,9tdi pd smoking problem
    By audi_rs2 in forum Chat - Anything with wheels
    Last Post: 17-12-2008, 11:43 AM
  5. PD130 Smoking Problem.
    By apole in forum Passat - Archive Topics
    Last Post: 12-10-2006, 09:17 PM
