Thread: 1.9 tdi won't rev over 3000 rpm
  1. 1.9 tdi won't rev over 3000 rpm
    Dec 2020
    Croatia
    I have problem with 2009 vw golf V 1.9 tdi engine. Sometimes car doesn't want to rev over 3000 rpm. Car does not show any fault codes. I also noticed that this problem only happens in 1. gear (car is manual). It accelerates fine in all gears, and then suddenly in 1. gear it comes to 3000 rpm and stop. I tried disconneting maf and problem stays. Authorized local vw dealership near me also could not find the problem...Do you have any idea what can be the cause.
  2. Re: 1.9 tdi won't rev over 3000 rpm
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Sounds like it’s on limp home mode....
    You need a new MAF.
    Unplugging it isn’t the best idea as it will need to have the fault codes cleared after doing this.
    I’ve seen plenty of posts and sticky somewhere about this issue.
    Get a new MAF and it should be back to normal.
  3. Re: 1.9 tdi won't rev over 3000 rpm
    Jul 2018
    8 Post(s)
  4. Re: 1.9 tdi won't rev over 3000 rpm
    Dec 2020
    Croatia
    I forgot to say that I also have iCarsoft so I can easily clear the fault later. But why it also goes sometimes to limp after I disconnect the maf. It wont rev over 3000 for few seconds and then goes back to normal. This problem happens approximately every third time in 1. gear. Do you have any more idea what else could be the problem. Thank you for your reply.
  5. Re: 1.9 tdi won't rev over 3000 rpm
    Jul 2018
    8 Post(s)
    Replace the MAF first and see if that resolves it.
  6. Re: 1.9 tdi won't rev over 3000 rpm
    Mar 2017
    Nottingham
    11 Post(s)
    Make sure it's a genuine one or it will cause you a nightmare
  7. Re: 1.9 tdi won't rev over 3000 rpm
    May 2017
    Cardiff
    12 Post(s)
    Before throwing parts/money at the issue you should get it scanned with VCDS (or ODIS) otherwise you could well end up chasing your tail and spending money for no reason.
  1. 3000 mile run
    By lasstesh in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-11-2010, 12:46 PM
  2. Please Help 3000+rpm at 50mph
    By jeffa in forum Bora - 1998 - 2005
    Last Post: 06-11-2009, 11:27 PM
  3. A6 V6 TDI no power after 3000 rpm
    By MCHAUDRY in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-11-2008, 04:35 PM
  4. 2,998, 2,999, 3000!
    By Sam in forum Chat - Completely Off Topic
    Last Post: 09-01-2008, 10:52 PM
  5. revving over 3000 revs
    By chris audi a4 in forum Audi A4 - Archive Topics
    Last Post: 21-03-2007, 04:55 PM
