Thread: VW CARAVELLE 2,5 petrol AVT
  1. VW CARAVELLE 2,5 petrol AVT
    Jul 2018
    Sweden
    I have a problem and not sure where to go exactly.
    T4 2,5 petrol, AVT year 2001.
    VIN: WV2ZZZ70Z1H108351
    Reading (the three fault codes come back in different order, sometime all, sometimes without cylinder 4 misfire)
    Code:
    Friday,06,November,2020,10:28:33:18201
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
    Data version: 20190930 DS308.0
    www.Ross-Tech.com
    Dealer/Shop Name: Firma Johannes Bruun
    Workshop Code: 000 02013 000000
    VIN:    License Plate: SFT984
    Mileage: 213360km-132575mi   Repair Order:
    Chassis Type: 7D - VW Transporter/Multivan (1996 > 2004)
    Scan: 01 02 03 08 15 17 18 19 22 25 35 37 56
       Mileage: 213360km-132575miles
    Address 01: Engine        Labels: Redir Fail!
       Part No: 023 906 033 B
       Component: 2.5l/2V SIMOS3  00HS3603
       Coding: 00001
       Shop #: WSC 00000
       VCID: 0C41A66AEF5F26F7A5F-51CE
    3 Faults Found:
    16514 - Oxygen (Lambda) Sensor B1 S1
                P0130 - 35-00 - Malfunction in Circuit
    16688 - Cylinder 4
                P0304 - 35-10 - Misfire Detected - Intermittent
    17834 - EVAP Purge Valve (N80)
                P1426 - 35-10 - Open Circuit - Intermittent
    Readiness: 0010 0001
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 603 BL
       Component: AIRBAG VW3 -        V04
       Coding: 16972
       Shop #: WSC 02743
       VCID: 74B1DE8A97AF5E37DDF-4B9A
    No fault code found.
    Address 17: Instruments        Labels: 7D0-920-xxx-17.lbl
       Part No: 7D0 920 803
       Component: T4-KOMBIINSTR. VDO V22
       Coding: 01151
       Shop #: WSC 00000
       VCID: 619FA7DE385DDB9FA69-5160
    End----(Elapsed Time: 03:08, VBatt start/end: 12.1V/12.0V. VIgn 0.0V)------
    When the owner bought the car and first got Engine light he came by to read the fault codes:
    Lambda code was present.
    And 4 cylinder missfire.
    So I have changed the first lambda.
    MOT didnt pass due to high emissions.
    After that the lambda code and EVAP code came.
    I checked the charcoal canister solenoif next to lambda connector. Solenoid OK.
    After that I started to measure wires:
    Both lambdas 12V wire (the white/red)
    MAF sensor 12V wire
    EVAP solenoid 12V wire
    They all are connected to each other before going through the torpedo wall into the cabin.
    All have 1,9 ohm resistance to ground
    Only couple of mV with ignition on.
    I cannot follow the white/red wire with tone generator.
    BUT - when I took out the S117 fues (right one, above the relay plate inside cabin) The resistance went to infinite.
    And the tone generator OK.
    I could not find any damage in the wiring in the engine bay.
    When I connect the tone generator to the other wire (blue/red) from the fuse S117 - the tone is missing.
    So the problem must be somewhere after the fuse.
    Here it gets trickier to follow the wire.
    I did take the fuel pump relay in and tested it.
    OK.
    And then I realised - I should measure voltage with engine running:
    At lambda voltage - 14,2V - so OK.
    So I measerued resistance on wires between G80 and Lambda and ECU.
    All wires to ECU had 0-0,2 ohm resistance. So OK.
    Is it the ECU??
    Pics of wiring:
  2. Re: VW CARAVELLE 2,5 petrol AVT
    Jul 2018
    Sweden
    Now I have had all the pins out in the connectors to prelambda and evap solenoid - as well as the corresponding pins on ECU side are checked - they all are OK.
    Would the intermittent fault on missfire on cylinder 4 also indicate towards ECU? Its a Simons 3.5.
    Perhaps I should take out the oscilloskope and see how that injector behaves?
  3. Re: VW CARAVELLE 2,5 petrol AVT
    Jul 2018
    Sweden
    I think Im getting closer now.
    What do you think of these spikes at over 50V to EVAP solenoid??
  4. Re: VW CARAVELLE 2,5 petrol AVT
    Jul 2018
    Sweden
    Those spikes above would be the normal inductive kick from the solenoid coil.
    But:
    I think I have found the cause for the P0130 at least.
    Measured voltage to heater element on pre cat lambda - engine running:
    Ground from ECU
    Voltage on B1S1 O2 with ground from ECU - YouTube
    Following is with ground taken from battery:
    Voltage on B1S1 O2 ground taken from battery - YouTube
    It looked like the fault code was set when the voltage got under 10.5V.
    The warmer the enigne got - the higher the voltage got - or the ground was better.
  1. Caravelle 2.5ltr petrol automatic transmission problems
    By fiaranoracer in forum Touran - Sharan - Caravelle
    Last Post: 15-12-2008, 05:08 PM
  2. VW Caravelle 2.5 petrol auto..good choice?
    By Twenty 23 in forum Touran - Sharan - Caravelle
    Last Post: 30-04-2008, 10:20 PM
  3. 1996 caravelle petrol injectors
    By mrjolly in forum The Commercial Range
    Last Post: 02-01-2008, 06:46 PM
  4. Petrol 2 Stroke Mix in Petrol Engine
    By gcmozart in forum Chat - Anything with wheels
    Last Post: 17-11-2007, 11:13 PM
  5. caravelle 2.0 litre petrol
    By Russellbar01 in forum Chat - Completely Off Topic
    Last Post: 17-01-2007, 12:10 PM
