Thread: Auxiliary water pump wire break
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Auxiliary water pump wire break
    Jul 2013
    76 Post(s)
    I'm not questioning anyones repair methods, the image in the first post shows that there is sufficient wire to re pin the connector.
    The splicing of wires is a a good repair if done correctly, i.e. a mechanical splice covered with a adhesive coated heatshrink to seal the wire on both sides.
    Soldering wires together is a tidy way to do this but the flux should be cleaned off and again the adhesive heatshrink should be used.
    Solder degrades over time and will cause issues in the future, solder joints can suffer from breaks due to movement should the wire be prone to vibration/movement.
    Dan
    2009/2010 2.0 TDIe SE
  2. Re: Auxiliary water pump wire break
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by dan2485 View Post
    A proper fix is to just replace the pin which is a MQS pin they cost pennys.
    If your using the new plug then remove the pin from the new one and replace it with the single damaged one other wise you are cutting good wires.
    Just move the pink locking tab to the left and then press on the visible part of the pin the housing and pull out the pin with the wire.
    Attachment 37602
    How do I pull the pins out of the OE plug as there isn't a locking tab?
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  3. Re: Auxiliary water pump wire break
    Feb 2015
    Peterborough
    7 Post(s)
    The OE plug has a fold up flap that locks the pins instead of the purple pull out type on the replacement
    2010 A6 TDI 170 S Line Avant
    Sold 2007 A3 TDI 170 S Line
    Sold - 2002 S3
  4. Re: Auxiliary water pump wire break
    Feb 2015
    Peterborough
    7 Post(s)
    Bare in mind the depth the wire goes into the plug re terminating may not be the ideal as it may cause an unacceptable bend radius of the wire as it did in my case.
    Sold - 2002 S3
  5. Re: Auxiliary water pump wire break
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by S3SteveW View Post
    I think its the bend radius of the said broken wire that's caused it to break. I think Im going to snip off the old plug and add the new one with a little extra wire to eliminate sharp kink in the wire at the plug..
  1. V5 Auxiliary Water Pump question...
    By deserthawk in forum Bora - 1998 - 2005
    Last Post: 26-01-2017, 05:26 PM
  2. Replies: 2
    Last Post: 06-03-2015, 12:01 PM
  3. How To Wire up an auxiliary cable in a 2004 audi a3 concert stereo
    By A3nuu in forum In Car Entertainment
    Last Post: 30-03-2014, 08:41 AM
  4. Help. engine light, auxiliary coolant pump
    By jcdub in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:50 PM
  5. Auxiliary water pump replacement...
    By webchem in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-10-2008, 10:35 AM
