Thread: Drivers Door Wont Open From Inside
Results 1 to 10 of 11
  1. Drivers Door Wont Open From Inside
    Dec 2009
    14 Post(s)
    I have found my first niggle today, not rattle related.
    When trying to open the drivers door from inside. It does not release and feels like you have deadlocks on, which I do not.
    It did finally open & let me out. On closing the door again I could hear the door solenoid & again could not open the door inside.
    Sounds like a new door motor, which is rubbish for a car 12 mths old & little use due to COVID.
  2. Re: Drivers Door Wont Open From Inside
    1836 Post(s)
    If you could get a fault code report on the convince system it would be interesting but Audi won't hand it over for warranty work.
  3. Re: Drivers Door Wont Open From Inside
    Dec 2009
    14 Post(s)
    Thanks Crasher,
    Long time no speak!
    Car is booked in next Friday for starter/alternator recall & they will cover the door lock issue under warranty FOC
  4. Re: Drivers Door Wont Open From Inside
    Dec 2009
    14 Post(s)
    Used the car a fair bit this week & zero issues.
    Guessing it was due to 7 mths lack of use & cold weather. TBH, I have only put fuel in 3 times this year.
    Will get them to simply carry out the recall work only.
  5. Re: Drivers Door Wont Open From Inside
    Dec 2009
    14 Post(s)
    Picked the car up & they did a check on the car. Zero faults shown.
    They did a reflash of SW for drivers door & said my car was 2nd one this week with the same fault I reported.
  6. Re: Drivers Door Wont Open From Inside
    Apr 2009
    Surrey
    171 Post(s)
    Had the car throw a central locking error yesterday. Firstly it flashed up a message saying you could not open a door while the vehicle was moving (or something to that effect) then I got the following message
    When I got home the car was okay for me to lock with the remote and today the error has gone. Recently the front passenger outside door handle has shown a reluctance to fully return after opening the door, so wonder if that is why it thought someone was opening the door whilst the car was moving. Will add it to the list when it goes in for service.
  7. Re: Drivers Door Wont Open From Inside
    Dec 2009
    14 Post(s)
    No warnings or error messages shown on my display.
  8. Re: Drivers Door Wont Open From Inside
    Jan 2020
    Norwich
    10 Post(s)
    I’ve seen this error message twice on my car, I thought it was because I had been overzealous with the key fob when trying to unlock the rear doors. Last time it happened was in the summer.
  9. Re: Drivers Door Wont Open From Inside
    Oct 2019
    Chippenham
    Mine did the same last year - it comes and goes intermittently, a software update fixed it completely.
  10. Re: Drivers Door Wont Open From Inside
    Apr 2009
    Surrey
    171 Post(s)
    In the cold weather over the weekend on 2 occasions I opened the car to start the engine and turn on the front and rear screen demisters while I removed the snow and ice from the windows. Having shut the drivers to do the windows I was then unable to reopen the door to get back in. At first I thought I had managed to lock the car, but the other doors (I could open see my other post) were unlocked. After repeated attempts and using the switch on the front passenger door to lock and unlock the car I finally managed to open the door. Let’s hope it is a sw issue aggravated by the cold weather.
  1. Question Rear door wont open from inside
    By Chriseybaby in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-01-2016, 07:56 PM
  2. passenger door wont open from inside or outside and driver window not working
    By nickeym1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2014, 11:49 AM
  3. Please Help Passenger rear door wont open from inside?
    By BigPhysco in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-05-2013, 09:17 PM
  4. Please Help drivers door wont open from inside + few other things
    By cazb71 in forum Toledo
    Last Post: 07-07-2012, 01:59 PM
  5. Why wont my door open from inside???
    By Ians3422 in forum Golf MK2 - 1984 - 1992
    Last Post: 25-01-2008, 03:18 PM
