Thread: ESP Light on
  1. ESP Light on
    Dec 2020
    New member, wondered if anyone can help.
    My Mum has a 2006 Golf 1.6 FSi Auto, which has only done about 25,000 miles.
    it was fine when she went shopping, however 2 days later the ESP light has come on and will not switch off.
    I have read various things on the internet from bulbs to brake pads to complete new system at around £1500
    I was wondering, if there is anything I can check easily and what should I look for.
    Many Thanks
    PT
  2. Re: ESP Light on
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Hi pt55 welcome to the forum,
    ESP light can mean lots of different things and not easily checked without diagnostic equipment.
    You need to get the car scanned for fault codes via the OBD (on board diagnostics) port....
    Most garages have these but you may wish to go to specialist or VAG / VW independent garage for the best help at a good price. It may get expensive if you go to the VW dealerships.
    Some examples of diagnostic systems are:
    VCDS / VAG COM (aftermarket)
    ODIS (dealership system)
    AVOID the cheap scanners on auction sites which are useless!
    Does the vehicle drive correctly? Is it underpowered due to being in limp home mode?
    First port of call is fault scan so the issue can be narrowed down and then you can focus on those fault codes to detect if there is defective part, wiring, module etc......
  3. Re: ESP Light on
    1836 Post(s)
    This WAS a common problem on the Golf 5 and was a problem with a pressure sensor called G210 so the first step must be a code read by a garage with VAG specific diagnostic equipment to see what is stored in the ABS ECU.
  1. Question DPF Light, Flashing Glow Plug Light & Engine Management Light on
    By Jockeyblade in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2020, 07:34 PM
  2. R/h reverse light and rear fog light light playing up
    By Panzerdriver in forum Passat CC
    Last Post: 01-12-2017, 10:32 PM
  3. should i buy? abs light, esp light and handbrake light flashing
    By craigq in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2011, 03:36 PM
  4. audi 53 plate esp light on abs light on handbrake light flashing
    By craigq in forum Chat - Anything with wheels
    Last Post: 03-09-2011, 08:58 PM
  5. Brake light changed diesel coil light and brake light still on
    By Manny.p in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-09-2010, 02:04 PM
