Thread: 2004 Ibiza flashing hand brake light
  1. 2004 Ibiza flashing hand brake light
    Apr 2015
    East sussex
    My friend had the brake warning light (handbrake not ABS) and 3 loud beeps on start up. The car does not have electronic brake pad wear indicators, I checked the brake fluid level and tested the level sensor and checked and tested the hand brake switch.
    I scanned with my VCDS and the only fault relaring to brakes was in the ABS module-65535 "internal control module memory error" Surely if the ABS module has gone it shoud show the ABS warning light on the dashboard? I'm hoping it isn't a fault with the wiring loom!
    I had a similar fault on my 99 passat and it was just a case of swapping the ABS module with on with a used one with the same part number-No coding needed. If i do the same with the Ibiza will it be the same or will it need coding?
    Any help/advice would be much appreciated.
  2. Re: 2004 Ibiza flashing hand brake light
    1841 Post(s)
    ABS module failure with the Bosch units is a problem, the software corrupts itself. Which part number controller, 6Q0 907 379 C, D, F, G, H, M, L, AA, AM? D and H are obsolete with supersession.
  3. Re: 2004 Ibiza flashing hand brake light
    Apr 2015
    East sussex
    It's 6Q0 907 379 G on the Bosch 5.7.
  4. Re: 2004 Ibiza flashing hand brake light
    1841 Post(s)
    Typical, the one I missed so I added it. ECU 6Q0 907 379 G is replaced by 6Q0 907 375 G which is £933.80 but it is a rare one that VAG actually offer as an exchange unit (probaly because it is so unreliable) under part number 6Q0 907 375 GX which is a little more bearable at £670.34.
  1. Red brake warning light flashing and constant abs light
    By lee.p.wood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-08-2014, 06:45 PM
  2. Please Help Dashboard lighting problem - roof light flashing, no parking brake light etc
    By 95cabrio in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 14-12-2011, 07:21 PM
  3. LT28 2004 Flashing Immobiliser Light
    By sciroccostorm in forum The Commercial Range
    Last Post: 12-12-2011, 10:12 PM
  4. Flashing glow plug light on 03 Ibiza 130 TDI sport
    By Maitland_78 in forum Ibiza - Cordoba
    Last Post: 10-04-2008, 04:45 PM
  5. hand brake light on
    By gpaul in forum Vento - 1994 - 1998
    Last Post: 07-11-2007, 10:35 AM
