Thread: Wipers stuck on
  1. Wipers stuck on
    Dec 2020
    Penshaw Sunderland
    Ever since Friday when we had the massive rain my car had been playing up. It started with my hazard light not going out. So I read about the CCM went off to euro to get some electrical cleaner on the way there I could hear water sloshing around. So I removed the battery to find that area full of water. I cleared the drain holes and set about checking the CCM. It was completely dry. No water around the area at all. I still removed the board and cleaned it with electrical cleaner and dried it. Made no difference. But water was coming in the vehicle as my drivers side is soaking I had been getting wet feet when driving dripping on my feet. So more investigation and it says relay 377 for wipers. I have searched and searched there is no 377 relay in mine. Removed relay 370 that stopped the wipers but swapped it with the other 370 relay and it made no difference to my wipers (but wondering if both could be knackered with the amount of water that came in)
    I’m literally lost apart from just buying new relays on what else it could be. I’m having to disconnect the fuse when driving and hoping it doesn’t rain.
    Has anyone got any suggestions ? Or know anyone in the north east that could look at it and be able to pinpoint my issue
    Thanks in advance
    Car is a 2004 Audi A4 B6 1.9 TDI Quattro
  2. Re: Wipers stuck on
    1841 Post(s)
    The wiper motor is directly controlled by the Body Control Module under the dash on the drivers side and it is commanded by CAN from the steering column controller and the hazard warning switch signal also goes direct to the BCM so I am surprised it was dry.
  3. Re: Wipers stuck on
    Dec 2020
    Penshaw Sunderland
    Would you happen to have a picture of the part I’m looking for ? As my hazards was playing up too but seem to of fixed the self. I see relays under the drivers side but what does CAN look like ?
  4. Re: Wipers stuck on
    Jan 2009
    Birmingham
    35 Post(s)
  5. Re: Wipers stuck on
    Dec 2020
    Penshaw Sunderland
    Thanks guys I have removed it cleaned it with isopropyl hair dried it and put it back in but no joy. I think it’s got to much corrosion on the board I would upload a picture but not sure how from a mobile phone
  6. Re: Wipers stuck on
    Dec 2020
    Penshaw Sunderland
    Purchased a new (second hand) body control module from eBay and it now works spot on. Thanks for all the help
  1. 1.9 tdi help please I'm stuck
    By dervquattro in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-12-2013, 02:03 AM
  2. Fuel gauge stuck and brake stuck !
    By Satch in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-01-2009, 03:40 PM
  3. Front slow wipers, faulty wiper motor, wipers park intermittently
    By guddo1969 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-12-2008, 09:51 AM
  4. VR6 stuck?
    By Sears in forum Golf MK3 - 1993 - 1999
    Last Post: 22-07-2008, 04:23 PM
  5. CD Stuck!!!!
    By Scottmully82 in forum Golf MK5 - 2004 - 2009
    Last Post: 08-02-2008, 09:14 PM
