Thread: Door Lock Repair Guide - Help!
Results 1 to 10 of 15
  1. Door Lock Repair Guide - Help!
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    I found this guide on VWwatercooled Australia....
    DIY: How to repair a VW MK5 door lock module
    Though it might be useful for this forum too....
    Tried giving it a go myself but haven’t had any success.
    I know it makes more sense just to buy genuine but they are just too expensive.....and the aftermarket ones I’ve heard aren’t that great especially off that well know auction website!
    Was hoping for some advice as to why I can’t get them to work.
    It’s making noises and the red lever does move but sometimes it get stuck in one position and won’t return.
    Any help would be appreciated.
  2. Re: Door Lock Repair Guide - Help!
    May 2017
    Cardiff
    12 Post(s)
    I replaced a rear door module a few months ago with one from ebay and it works fine.
    I would have no problem doing it again, they're very affordable.
    I did look into used parts from scrap vehicles but chose against it (as their age puts them in the potential fail zone).
  3. Re: Door Lock Repair Guide - Help!
    Jul 2018
    8 Post(s)
    Fair enough think I may have to! Seems to have made the problem worse taking it apart! Almost couldn’t get the door open at all once I got it back together. Thought it was deadlocked forever but managed to open it from the interior handle after frantically turning central locking on and off , pulling at the handle and she eventually opened up.
    Any suggestions for a decent door lock that isn’t from that auction site??
  4. Re: Door Lock Repair Guide - Help!
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    I went with genuine item on eBay from a car being dismantled. Cheap, and working absolutely fine a year later on.
  5. Re: Door Lock Repair Guide - Help!
    Jul 2018
    8 Post(s)
    Thanks for your reply.
    I shall take a look and see what I can find at the breakers yard / online.
    Just interested to know what actually fails on these door locks?
    The motors both worked fine when I put a 9v battery across them.....all micro switches had continuity on the outer pins and went off when switch depressed...
    What else could it be? Circuit board issue? Wiring?
  6. Re: Door Lock Repair Guide - Help!
    1840 Post(s)
    We will only fit new genuine from TPS, then when one jams in warranty (we have had this on a Golf 6 and A4) it is the main dealers problem not mine. Take care though even then, twice now we have been supplied an old but cleaned up faulty unit by TPS that a trade customer has sent back for a refund, the first time on a traders Golf 5 GTI really had me scratching my head until I sussed it.
  7. Re: Door Lock Repair Guide - Help!
    Jul 2018
    8 Post(s)
    No worries thanks for the advice.
    To be honest I’m still scratching my head why it’s not working correctly.
    I had the unit open to see how the inner workings operate and the motor for the lock/ unlock doesn’t appear to always work.
    Tested all the micro switches which have continuity and operate as one would expect.
    Attempted to find bad solder joints but couldn’t see any but I know these can be very subtle so may have missed something on the printer circuit board.
    Now starting to suspect dodgy wiring to the lock unit.
    Door jam area looked ok.....
    Need to check from window control unit to lock to see if anything not right.
  8. Re: Door Lock Repair Guide - Help!
    Jul 2018
    8 Post(s)
    VCDS Scan for my door lock issue....
    Code:
    Saturday,05,December,2020,18:32:59:33544VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 20.4.2.0 (x64)
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: WVWZZZ1KZ4W096975   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WVWZZZ1KZ4W096975   Mileage: 351740km-218561miles
    01-Engine -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    Address 01: Engine        Labels: 03C-906-056-BAG.lbl
       Part No SW: 03C 906 056 BA    HW: Hardware No
       Component: MED9.5.10       G00 5697
       Revision: 00000000    Serial number: VWZ7Z0D9331576
       Coding: 0000072
       Shop #: WSC 01279 785 00200
       VCID: 63C1C201A2D6B09E6E-8036
    No fault code found.
    Readiness: 1110 0101
    Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
       Part No: 1K0 907 379 K
       Component: ESP FRONT MK60      0103
       Coding: 0019073
       VCID: 3A7F5F6575DC91561D-806E
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No: 1K0 820 047 CB
       Component: Climatic PQ35   080 0201
       Shop #: WSC 00000 000 00000
       VCID: 66C7DB1551E4C5B689-8032
    Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
       Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
       Component: Bordnetz-SG 1.0 H30 0701
       Revision: 00030000    Serial number: 00000000514812
       Coding: E48D0F0600041800001400001400000000
       VCID: 3779465146CE8C3EE2-8062
       Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer VW350  012  0401
       Coding: 00065493
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 K  Labels: 1K0-955-559-AF.CLB
       Component: RegenLichtSens 002  0505
       Coding: 00217125
       Shop #: WSC 00000
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
       Component: 0M AIRBAG VW8   022 0500
       Revision: 04022000    Serial number: 0033FD08P0VC
       Coding: 0012365
       Shop #: WSC 01268 785 00200
       VCID: 2A5F6F25857C21D66D-807E
       Subsystem 1 - Serial number: 6332MSME5D7E1002
       Subsystem 2 - Serial number: 6342MSME57340A02
       Subsystem 3 - Serial number: 6351HSME43485801
       Subsystem 4 - Serial number: 6361HSME5D0F5901
    Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
       Part No SW: 1K0 953 549 A    HW: 1K0 953 549 A
       Component: Lenksäulenmodul 012 0030
       Coding: 0000022
       VCID: 306B7D4DA3A05B06A3-8064
    Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
       Part No: 1K0 920 950 K
       Component: KOMBIINSTRUMENT VDD 3554
       Coding: 0000401
       Shop #: WSC 00218 210 03908
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V1.clb
       Part No SW: 1K0 907 530 C    HW: 1K0 907 951
       Component: Gateway         H08 0080
       Revision: 08          Serial number: 2100104128EF35
       Coding: 3D0F0340070003
       VCID: 27599611966E1CBE72-8072
    Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
       Component: IMMO                3554
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
       Part No: 1K0 959 701 E
       Component: Tuersteuergeraet 09 0116
       Coding: 0000052
    Address 44: Steering Assist        Labels: 1Kx-909-144-G2V1.clb
       Part No: 1K2 909 144 E
       Component: EPS_ZFLS Kl.1       1202
       VCID: 2E576335B9944DF6B1-807A
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 BL
       Component: 01 KSG              0301
       Coding: 81E802087F2D8505485BC61000
       Shop #: WSC 00218 210 08203
       VCID: 7BF19A613A66685E46-802E
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H05 1501
       Subsystem 2 - Part No: 1K0 907 719
       Component: Neigungssensor  003 0003
       Subsystem 3 - Part No: 1K0 951 177
       Component: Innenraumueberw.004 0101
    3 Faults Found:
    01134 - Alarm Horn (H12)
                004 - No Signal/Communication
    00931 - Locking Module for Central Locking; Rear Right (F223)
                012 - Electrical Fault in Circuit
    01038 - Central Locking Thermal Protection
                000 - -
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
       Part No: 1K0 959 702 E
       Coding: 0000052
       VCID: 316D7849A8AA520EAC-8064
    1 Fault Found:
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
                008 - Implausible Signal
    Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
       Part No: 1K0 035 186 J
       Component: Radio BNO           0016
       Coding: 0040400
       VCID: 2D556439B49236EE88-8078
    End-------------------------(Elapsed Time: 01:34)--------------------------
  9. Re: Door Lock Repair Guide - Help!
    1840 Post(s)
    That’s an early UK Golf 5, built 03-03-04. The door lock unit is faulty, plain and simple. It is controlled by the window lifter control unit which itself is CAN BUS commanded so a wiring fault between the lifter unit and the lock unit is unlikely.
  10. Re: Door Lock Repair Guide - Help!
    Jul 2018
    8 Post(s)
    Thanks for the reply Crasher I shall get a replacement.
    Can you explain a bit more my what you mean by the CAN BUS and why it can’t be a wiring issue? This is communication system the vehicle uses?
    The window on the passenger side does go on the fritz sometimes.....you touch the window button and it goes all the way down when you want it go up and visa versa....not sure why it does this or has any relation to what is happening with the door lock.
  1. Question Passat B5.5 Estate needs tailgate microswitch and rear passanger door lock repair
    By berrick in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-02-2014, 11:50 AM
  2. Replies: 0
    Last Post: 12-01-2012, 07:07 PM
  3. Lupo door lock repair
    By davidsaglover in forum New Member Introductions
    Last Post: 08-12-2011, 09:11 AM
  4. DIS LCD Repair guide
    By inertia in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-05-2009, 11:41 AM
  5. Interior door handle and door panel removal guide
    By sferg55 in forum Bora - 1998 - 2005
    Last Post: 19-10-2008, 09:59 AM
