Thread: replacement head light bulbs S4 B7
  1. replacement head light bulbs S4 B7
    Dec 2018
    cardiff
    As in title, know it probably been asked quite a few times but need some solid advise&lt
    basically one of my head lights has started to (blink occasionally ) and got the (low beam) yellow warning on the dash
    this was an intermittent problem, both the light and the warning, but having had the battery off and used the opportunity to
    fully charge the battery, the warning light is now on constant on start up, so obviously a stored code
    ive read it can be a few things so want to work my way through the basics first, by changing both the head light bulbs
    so want advise on what to get, its a DS1 6000k im needing right?
    ideally something a little brighter than OE but not blue
    second the best place to get them, i know they can get expensive so a set off ebay worth getting/trying?
    or have i got to stump up for something more expensive
    also any thought on the other bulbs to change while the bumpers off
    any advise help or links would be great full
  2. Re: replacement head light bulbs S4 B7
    Southern County Softy
    20 Post(s)
    It could be the bulb or the ballast.
    If you swop your bulbs over and the faults stays in the same headlight its the ballast. Bulbs are best replaced in pairs.
    Sent from my SM-G960F using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: replacement head light bulbs S4 B7
    Dec 2018
    cardiff
    Quote Originally Posted by kite View Post
    that`s my thoughts from what ive read, so im looking on replacing both the bulbs first when the bumpers off
    if the problems not solved, ill then be looking at the ballast packs, but first need some advise on what bulbs to get, before spending out
  4. Re: replacement head light bulbs S4 B7
    Dec 2018
    cardiff
    any advise on what replacement bulbs to use
  5. Re: replacement head light bulbs S4 B7
    1840 Post(s)
    It is a D2S, VAG number N 104 457 01 which are £146.28 genuine which personally I feel is daft. I would use the Phillips 85122XV2S1 Xenon X-TremeVision Gen2 as I have a bit of a thing for the companies products (just fitted two domestic LED units in the hall and stairs) but I would worry about dazzling other drivers although that is pretty much every modern car now, I think I need to wear sunglasses whilst driving at night...
  6. Re: replacement head light bulbs S4 B7
    Dec 2018
    cardiff
    Thanks will look into it
  1. Question 2007 Touran - Replacement Side Light Bulbs
    By caribsimon in forum Touran - Sharan - Caravelle
    Last Post: 16-12-2016, 11:10 PM
  2. LED Replacement bulbs
    By Ben in forum Chat - Anything with wheels
    Last Post: 13-11-2012, 11:41 PM
  3. Head light bulb (H7) replacement polo 2010
    By polo12v in forum Polo - Derby - Lupo - Fox
    Last Post: 05-12-2011, 10:40 PM
  4. head light, spot and parking bulb replacement!
    By McSleepy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-05-2010, 10:00 PM
  5. uprated head-light bulbs
    By tdi-tel in forum Chat - Anything with wheels
    Last Post: 15-05-2008, 11:47 AM
