Thread: Driveshaft bearing disintegrated, Mk6 1.4 TSI 122
  1. Driveshaft bearing disintegrated, Mk6 1.4 TSI 122
    Nov 2020
    Glasgow
    Appreciate any advice anyone can give. Gearbox (6spd manual) developed a whine, which got progressively worse over time (100k miles). Took box off and found this, surprised it was still running without seizing up.
    Does anyone have an opinion on whether this can be rebuilt with new bearings, or will it have damaged the casing? Trying to weigh up whether to try and get it rebuilt or source a used box from salvage.
    Picture is upside down unfortunately.
  2. Re: Driveshaft bearing disintegrated, Mk6 1.4 TSI 122
    1840 Post(s)
    That's the diff bearings, it should be OK to rebuild. I am just doing my diff bearings on a "guaranteed, low mileage" used gearbox I bought to do a six speed conversion. I thought I would take a gamble on fitting it without a rebuild so I had to take it out again... used boxes are often a disaster and I won't do it on customers cars. The bearing kit just turned up from Hungary a few minutes ago.
  3. Re: Driveshaft bearing disintegrated, Mk6 1.4 TSI 122
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    Our 2003 manual gearbox makes a couple of whirry noises. I'd thought about opening it up and maybe replacing a few bearings. Are they reasonably easy to do, or best left to someone who's done it before?
  4. Re: Driveshaft bearing disintegrated, Mk6 1.4 TSI 122
    1840 Post(s)
    They are easy enough to do IF you have the bearing pullers and extractors plus a decent dial gauge, THE most important part is setting all the various bearing pre loads and this takes time and patience. Also the bearings are not cheap, I bought all my 02M bearings from Rolling in Hungary but those and the shims plus goo and seals still came to £300. I do not trust gearbox rebuild people, you get them quoting £700 ish when a VAG recon is £4K so the realistic truth lies somewhere in between.
  1. Question driveshaft
    By carl55 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-11-2012, 10:58 AM
  2. quattro driveshaft centre support bearing
    By sbt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-09-2009, 11:04 AM
  3. mk2 gti driveshaft HELP!please
    By cr4igo in forum Golf MK2 - 1984 - 1992
    Last Post: 16-11-2008, 10:31 PM
  4. Please Help A4 Engine Under tray - disintegrated
    By QuattroOilBurnR in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-08-2008, 09:03 PM
  5. Intermediate driveshaft bearing?
    By 2manykids in forum Touran - Sharan - Caravelle
    Last Post: 17-11-2007, 03:08 PM
