Thread: A6 ACC Fault following remap
Results 11 to 20 of 27
  1. Re: A6 ACC Fault following remap
    #11
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    I see all sorts of unusual software errors such as dash pods going faulty and then corrupting other units or new central convince units changing the ABS unit coding and then the ABS controller locks itself, I have see that one four times now.
    So Audi have had the car just over 24hrs and have called to say cannot fix the ACC as my master should be 4G0907561A and i have fitted a B revision they have suggested i find a used A revision or pay the £1720 for a new one and they will look again, but he says as i have added traffic sign recognition he still doesn’t feel they can say 100% they can get the system working.
    He says the engine Ecu and multimedia show they are not what the car left the factory with. Ive only had it 15 months so no idea if these are originalor not.
    They are also grumbling about the seatbelt pretensioner fault. (I pointed this out many times inside the warranty period) and the fact the tailgate has decided it has no basic settings.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: A6 ACC Fault following remap
    #12
    108 Post(s)
    1816 Post(s)
    Could you private message me the reg and your email?
  3. Re: A6 ACC Fault following remap
    #13
    Dec 2007
    43 Post(s)
    Yes will do it now.
  4. Re: A6 ACC Fault following remap
    #14
    Dec 2007
    43 Post(s)
    re scan with new lead
    Code:
    Wednesday,09,December,2020,19:30:53:32552
    VCDS Version: 20.12.0.1 (x64)  HEX-NET2 CB: 0.4529.4
    Data version: 20201125 DS322.1
    www.Ross-Tech.com
    VIN: WAUZZZ4G7CN175407   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 22 36 3B 3C 42 44 46
              52 53 55 56 5F 62 6C 6D 72 85 8B 8E A9 C0
    VIN: WAUZZZ4G7CN175407   Mileage: 207857km-129156miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    20-High Beam Assist. -- Status: OK 0000
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    C0-Act. for Ext. Noise -- Status: OK 0000
    Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
       Part No SW: 4G0 907 589 C    HW: 4G0 907 589
       Component: 3.0BTD EDC17  H21 0002
       Revision: 57H21---
       Coding: 122A4012056601020000
       Shop #: WSC 00000 780 00200
       ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
       ROD: EV_ECM30BTD0114G0907589C.rod
       VCID: 343A76E42EBC9D2BA7A-8060
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 4G0 997 749 B    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H16 1001
       Revision: --H16---
       Coding: 000001
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMAL551211 002022
       ROD: EV_TCMAL551211_002_AU48.rod
       VCID: 3A2658DC0CD86B5B7D6-806E
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
       Component: ESP PREMIUM   H09 0361
       Revision: --------    Serial number: --------------
       Coding: 49B7870192EDE180DB00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004028
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 382242D432D4794B8B2-806C
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Component: BCM2 2.0      H31 0333
       Revision: 00002001
       Coding: 05B92F06000000000000
       VCID: 78A282D472D4B94B4B2-802C
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 2312000082218009
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0064
       Serial number: 04051200110600
       Coding: 3622000824
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       ROD: EV_AirCondiBasisUDS_002.rod
       VCID: 241A86A49E5C0DAB37A-8070
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0111
       Revision: 20012002    Serial number: 00000001477705
       Coding: 2600201040749FE2A18100C380001D0CCF9DC7082F090101000004602100
       Shop #: WSC 53834 003 1048576
       VCID: 75BC8BE065C6C423504-8020
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 120326  H35 0080
       Serial number:         120404125917
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 12016111
       Coding: 022159
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 27 04 2012  00001520
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H03 0002
       Serial number: 07288826000000000001
    1 Fault Found:
    03725 - Control Module for Seat Belt Tensioner; Left Front
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Time Indication: 0
                        Date: 2020.12.09
                        Time: 19:22:00
    Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0060
       Revision: 11001001    Serial number: 55901211700965
       Coding: 282B08
       ASAM Dataset: EV_EPHVA18AU57X0000 004005
       ROD: EV_EPHVA18AU57X0000_004.rod
       VCID: 40D22A346A04318B332-8014
    Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Serial number: 00000000000000
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 29049790F97ED0C304C-807C
    2 Faults Found:
    12288 - Sensor for Automatic Distance Regulation; Incorrectly Positioned
              C1103 00 [009] - -
              [FAULT_MAR_PLANT_CODED]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Date: 2020.12.09
                        Time: 19:22:43
                        Control Module temperature: 13 °C
                        Voltage terminal 15: 14.672 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    150016 - invalid data record
              B2005 00 [009] - -
              [FAULT_BPC_NVM_DATA]
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Date: 2020.12.09
                        Time: 19:22:43
                        Voltage terminal 15: 14.657 V
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H43 0040
       Revision: --------    Serial number: 003JG008FE2Y
       Coding: 30323436313330303539554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 363E4CEC38C08F3B99E-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB404V1BBH2D1DB
       Front Passenger's Side Airbag Crash Sensor:
       Serial number: 3585HRB404P1BBH23HPO
       Rear Side Airbag Crash Sensor (on driver's side):
       Serial number: 3515JRB405318E5ECHL3
       Passenger side rear thorax airbag crash sensor:
       Serial number: 3525JRB405J197FG1H2$
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB400G4UI5CR0PC
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB40044UFMU4P8I
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H03 0005
       Revision: --------    Serial number: 90372LDR001Z4
       Coding: 0000FD
       VCID: 372041E83F4A7633828-8062
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0009
       Serial number: 11 04 2012  D0107519
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 982 R    HW: 4G8 920 982 R
       Component: TDieGb Acc    H79 0416
       Revision: 28460177    Serial number: 658020312596025
       Coding: 339711008F112600010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU57.rod
       VCID: 43D825387B122A932E0-8016
    1 Fault Found:
    13636608 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Date: 2020.12.09
                        Time: 19:22:43
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000506260
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001013
       ROD: EV_GatewPkoUDS_001_AU57.rod
       VCID: 70B2BAF41A24E10B832-8024
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790876526
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 18021200000000000117
    Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Component: FLA           H04 0004
       Revision: AA001002
       Coding: 02028264747464545425363E
       VCID: 333875F82B329A13BE0-8066
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H15 0013
       Serial number: 002004120001011
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       ROD: EV_AllWheelDiffeQSPFR.rod
       VCID: 270091A8EF6AE6B3128-8072
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000027673648
       Coding: 00781B0000006001000001010101102030303232203232
       Shop #: WSC 02311 785 00200
       VCID: 77A081E87FCAB633428-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 C    HW: 4G0 907 637 C
       Component: SARA 6D red   H02 0009
       Revision: --------    Serial number: EJ1BPA3E00CZFU0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: 2E0E648CC090B7FBD1E-807A
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH01 0040
       Revision: 00H01000    Serial number: 6PZ 010 287-03
       Coding: 0001102
       VCID: 30327AF4D624A10BC32-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H02 0040
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F04.05.1200H020003CF25122ÿ
       Subsystem 4 - Serial number: F25122ÿ
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 D    HW: 4G8 959 793
       Component: TSG FA        H05 0212
       Coding: 011F16205E01628002080013
       VCID: 41D42F30618E38833CC-8014
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Time Indication: 0
                        Date: 2020.12.09
                        Time: 19:22:41
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0002484695
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323670FCD4A8931BB56-8066
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0175250996
       Coding: 013B0E2220B93481832009040C0304000000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84247147
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Time Indication: 0
                        Date: 2020.12.09
                        Time: 19:22:41
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F16205E01628002080002
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Time Indication: 0
                        Date: 2020.12.09
                        Time: 19:22:41
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
       Component: EPB-4         H03 0012
       Revision: --------    Serial number: 00000000333813
       ASAM Dataset: EV_ParkiBrake 001022
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A06689CFC78DBDB0D6-807E
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Component: ....LWR12.... H02 0013
       Serial number: 120504-0002-143
       Coding: 1122A6101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C0A6E84F68CC5EBFFA-8078
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109EY0C7563127
       Coding: 010103020100000001
       VCID: 2D0C6380CD16CCE3E84-8078
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 H
       Component: H-BNT-EU      H49 1034
       Revision: --------    Serial number: 190ES0C7503235
       Coding: 050101010102E9FF7D30CF3E00000003000001000000000000
       VCID: 31347FF0D12EA803CCC-8064
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC9401HHFY
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Component: E380 BDT C7  H11 0204
       Serial number: 90349LE10003F
       Subsystem 4 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
    2 Faults Found:
    03276 - Please Check Software Version Management
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Time Indication: 0
                        Date: 2020.12.09
                        Time: 19:22:46
                 Freeze Frame:
                        Text: DUA009,Front,M,0,0,6
    03157 - Functionality limited due to Communications Disruption
                000 - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 60
                        Mileage: 207857 km
                        Time Indication: 0
                        Date: 2020.12.09
                        Time: 19:22:46
                 Freeze Frame:
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 10000000 00000000
    Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204001628002080002
       VCID: 44DA26247E9C2DAB17A-8010
    Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
       Part No SW: 4G0 907 441 B    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H06---    Serial number: 525 PA8J24G2DY
       Coding: 1080005
       VCID: 261E9CACE4E0FFBB29E-8072
    Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
       Part No SW: 4G9 959 107 A    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0139
       Revision: 14003001    Serial number: 118200102
       Coding: 097205C010
       ASAM Dataset: EV_HDSGAu572 001001
       ROD: EV_HDSGAu571.rod
    Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H04 0212
    Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H25 0038
       Revision: --------    Serial number: 262130025421000
       Coding: 6A060000
       ASAM Dataset: EV_OnBoardCamerDPC 001007
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 261E9CACE860FFBB29E-8072
    Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
    Address 8E: Image Processing (J851)       Labels:| 4H0-907-107-V2.clb
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H31 0041
       Serial number: 005000120910127
       Coding: 04C2391A1111
       Shop #: WSC 03654 128 28888
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 28029294E274E9CB1B2-807C
    Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
       Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 120419200965
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: 2B086D98F382C2D3F60-807E
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0004
       Serial number: 120323200969
       ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
       ROD: EV_ActuaForExterNoiseUDS.rod
    End----------(Elapsed Time: 02:38, VBatt start/end: 14.8V/14.6V)-----------
  5. Re: A6 ACC Fault following remap
    #15
    108 Post(s)
    1816 Post(s)
    Hopefully it just needs the sensor setting up, the information electrics error means it needs to go on ODIS and be flashed.
  6. Re: A6 ACC Fault following remap
    #16
    Dec 2007
    43 Post(s)
    so apparently the B version i have fitted is not a compatible swap for the A variant until i re fit the correct 4G0907562A im told no acc
  7. Re: A6 ACC Fault following remap
    #17
    Jan 2021
    Hucknall
    Hi, Have you got an older scan, one before the faults started. If you have , compare them and see if your coding as changed.
  8. A6 ACC Fault following remap
    #18
    Dec 2007
    43 Post(s)
    I have it working now, used vag can pro and re parametrised the 561b module
  9. A6 ACC Fault following remap
    #19
    May 2013
    Quote Originally Posted by dean warren View Post
    Did you also have to have full calibration?
    I replaced only the failed unit, it the revision was identical down to the month of production. Only got ACC working again after calibration. Although had been told if replaced as a pair (from a donar car) calibrations not required.
    A6 Avant S-Line BiTdi | born Sept '13 | advanced tech pack | sports diff | privacy glass | 75l fuel tank | lighting pack | HB assist | rear cam
    Q5 S-Line Plus TFSI | born April '11 | tempted to add stage 1 Revo taking HP from 177 to 290.
  10. Re: A6 ACC Fault following remap
    #20
    Dec 2007
    43 Post(s)
    I replaced the pair audi couldnt get the system running so. Its not been calibrated yet, thats on the list to do now its working again.
  1. Please Help 16683 Boost Pressure fault code and question about Turbo, Exhaust, Remap
    By BarnaBK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-08-2019, 07:36 AM
  2. Huddersfield Chip Tune Remap offer £180 and a chance to win a FREE REMAP!!!!!
    By Hyper-Remaps in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-07-2011, 03:31 PM
  3. Replies: 4
    Last Post: 14-04-2010, 12:07 AM
