Thread: A6 ACC Fault following remap
Page 1 of 3 123 LastLast
Results 1 to 10 of 27
  1. A6 ACC Fault following remap
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Hi all sorry this is a little long winded....
    I have a 2012 A6 BiTDi it is very well speced and has ACC amongst other toys, the car had an Audi service 3 months or so back and the flashed the ECU with an emissions fix flash. OMG the car was terrible when I got it back, felt like it would randomly misfire and driving around town at 30 mph would sometimes get terrible diesel knock for 20/30 seconds then back to a decent drive. So I did some research as Audi said nothing they could do and decided to go for a remap. Did a bit of research and chose a company who are well known in the Audi high end tuning circuit, the car was booked in and remapped to 387BHP and had a gearbox tune to suit. however on the drive back from them it soon became apparent the ACC was no longer working, I had ACC and Audi Brake Guard unavailable when I tried to engage cruise, I call them up and they said return it, but I was heading to Kent to collect my Daughter for a weekend away, so I said I will scan the car and let them know the issue.
    When I scanned the car it had in module 13 Auto distance control "Internal Error" and the code would not clear. Spoke to the tuners who said nothing to do with the remap you ACC has failed.
    I rang Audi and was quoted £1720 per side to replace. So I brought two used and fitted them, booked it into Audi to get the system back up and running. Audi had only had the car an hour and called to say we cannot activate the ACC on your car as we need to flash the ECU and this will remove the remap..... ? Really is this the case as it sounds a bit strange.. Anyway she also suggested it was the remap that had caused the ACC to fail as it would have been looking for certain parameters from the engine and gearbox ECU’s.
    So I am left with a car that has no cruise control and I have potentially had to spend £600 replacing items that didn’t fail but broke.
    So my question is can a car with ACC be remapped and the ACC still work? And if so how can I get my ACC back on if Audi can’t do It.?
    this is the fault im now left with.
    Code:
    Sunday,29,November,2020,11:06:27:33186
    VCDS Version: Release 20.4.2 (x64) Running on Windows 10 x64
    Ross-Tech: Home
                    Address 13: Auto Dist. Reg       Labels: 4H0-907-561.clb
    Control Module Part Number: 4G0 907 561 B    HW: 4G0 907 561
      Component and/or Version: ACC3          H21 0055
               Software Coding: 7E04010202
                Work Shop Code: WSC 02391 785 00200
                  ASAM Dataset: EV_AdaptCruisContrAU57X 002015 (AU57)
                           ROD: EV_AdaptCruisContrAU57X_002.rod
                          VCID: 29539571487880CE64-807C
    1 Fault Found:
    150016 - invalid data record
              B2005 00 [009] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 207830 km
                        Date: 2020.11.29
                        Time: 10:40:38
                        Control Module temperature: 18 °C
                        Voltage terminal 15: 11.780 V
                        Velocity_vehicle_reference: -0.01 m/s
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s²
    Sunday,29,November,2020,11:07:58:33186
    VCDS Version: 20.4.2.0 (x64)
    Data version: 20200730 DS317.0
    Ross-Tech: Home
    VIN: WAUZZZ4G7CN175407   License Plate:
    Chassis Type: 4G-AU57 (4G0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 20 22 36 3B 3C 42 44 46
              52 53 55 56 5F 62 6C 6D 72 85 8B 8E 8F 90 A9 C0
    VIN: WAUZZZ4G7CN175407   Mileage: 207830km-129139miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    13-Auto Dist. Reg -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    20-High Beam Assist. -- Status: OK 0000
    22-AWD -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: Malfunction 0010
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: Cannot be reached 0100
    90-Pretens. Frt Right -- Status: Cannot be reached 0100
    A9-Struct. Borne Sound -- Status: OK 0000
    C0-Act. for Ext. Noise -- Status: OK 0000
    Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
       Part No SW: 4G0 907 589 C    HW: 4G0 907 589
       Component: 3.0BTD EDC17  H21 0002
       Revision: 57H21---
       Coding: 122A4012056601020000
       Shop #: WSC 00000 780 00200
       ASAM Dataset: EV_ECM30BTD0114G0907589C 001002
       ROD: EV_ECM30BTD0114G0907589C.rod
       VCID: 346D74059FBACD26C7-8060
    No fault code found.
    Readiness: 0 0 0 0 1
    Address 02: Auto Trans (J217)       Labels:| 0BK-927-156.clb
       Part No SW: 4G0 997 749 B    HW: 0BK 927 156 AM
       Component: 0BK 30RTDIRdW H16 1001
       Revision: --H16---
       Coding: 000001
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_TCMAL551211 002022
       ROD: EV_TCMAL551211_002_AU48.rod
       VCID: 3A715A3DBDDE3B561D-806E
    Address 03: ABS Brakes (J104)       Labels:. 4G0-907-379-V1.clb
       Part No SW: 4G0 907 379 J    HW: 4G0 907 379 J
       Component: ESP PREMIUM   H09 0361
       Revision: --------    Serial number: --------------
       Coding: 49B7870192EDE180DB00
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ESPPremiAU57X 004028
       ROD: EV_ESPPremiAU57X_004_AU57.rod
       VCID: 3875403583D22946EB-806C
    Address 05: Acc/Start Auth. (J393)       Labels:. 8K0-907-064-05.clb
       Part No SW: 4H0 907 064 BP    HW: 4H0 907 064 BP
       Component: BCM2 2.0      H31 0333
       Revision: 00002001
       Coding: 05B92F06000000000000
       VCID: 78F58035CB52E9462B-802C
       Subsystem 2 - Part No SW: 4H0 905 852 C    HW: 4H0 905 852 C
       Component: J764 ELV MLB  H40 0046
       Serial number: 2312000082218009
    1 Fault Found:
    00955 - Key 1
                002 - Lower Limit Exceeded
                 Freeze Frame:
                        Fault Status: 01100010
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 207830 km
                        Time Indication: 0
                        Date: 2020.11.29
                        Time: 10:30:48
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0064
       Serial number: 04051200110600
       Coding: 3622000824
       ASAM Dataset: EV_AirCondiBasisUDS 002040
       ROD: EV_AirCondiBasisUDS_002.rod
       VCID: 244D84452F5A5DA657-8070
    Address 09: Cent. Elect. (J519)       Labels:. 4H0-907-063-V1.clb
       Part No SW: 4H0 907 063 BN    HW: 4H0 907 063 F
       Component: BCM1 2.0      H12 0111
       Revision: 20012002    Serial number: 00000001477705
       Coding: 2600201141749FE2A18100C380001D0CCF9DC7082F090101000004602100
       VCID: 75EB8901DC40942E30-8020
       Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS57X 120326  H35 0080
       Serial number:         120404125917
       Coding: 0045F7
       Subsystem 2 - Part No SW: 8K0 955 559     HW: 8K0 955 559   Labels: 8K0-955-559.CLB
       Component: RLS  H04 0003
       Serial number: 12016111
       Coding: 022159
       Subsystem 3 - Part No SW: 4G0 941 531 E    HW: 4G0 941 531 E
       Component: E1 - LDS  H07 0044
       Serial number: 27 04 2012  00001520
       Subsystem 4 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
       Component: Humidity_Sens  H03 0002
       Serial number: 07288826000000000001
    1 Fault Found:
    03725 - Control Module for Seat Belt Tensioner; Left Front
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Time Indication: 0
                        Date: 2020.11.28
                        Time: 11:24:00
    Address 10: Park/Steer Assist (J446)       Labels:| 4H0-919-475-7X2.clb
       Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0060
       Revision: 11001001    Serial number: 55901211700965
       Coding: 282B08
       ASAM Dataset: EV_EPHVA18AU57X0000 004005
       ROD: EV_EPHVA18AU57X0000_004.rod
       VCID: 408528D5DB02618653-8014
    Address 13: Auto Dist. Reg (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Serial number: 00000000000000
       Coding: 7E04010202
    1 Fault Found:
              B2005 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 59
                        Mileage: 207830 km
                        Date: 2020.11.29
                        Time: 10:40:38
    Address 15: Airbags (J234)       Labels:* 4H0-959-655.clb
       Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
       Component: Airbag10.43   H43 0040
       Revision: --------    Serial number: 003JG008FE2Y
       Coding: 30323436313330303539554A305234473053
       ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
       ROD: EV_AirbaAU10BPAAU64X_VW51.rod
       VCID: 36694E0D89C6DF36F9-8062
       Crash sensor for side airbag: driver side:
       Serial number: 3575HRB404V1BBH2D1DB
       Crash sensor for side airbag: front passenger side:
       Serial number: 3585HRB404P1BBH23HPO
       Crash sensor for side airbag: rear: driver side:
       Serial number: 3515JRB405318E5ECHL3
       Crash sensor for side airbag: rear: passenger side:
       Serial number: 3525JRB405J197FG1H2$
       Crash sensor for front airbag: driver side:
       Serial number: 3554VRB400G4UI5CR0PC
       Crash sensor for front airbag: front passenger side:
       Serial number: 3564VRB40044UFMU4P8I
    Address 16: Steering wheel (J527)       Labels:. 4H0-953-568.clb
       Part No SW: 4H0 953 568 G    HW: 4H0 953 568 G
       Component: Lenks.Modul   H03 0005
       Revision: --------    Serial number: 90372LDR001Z4
       Coding: 0000FD
       VCID: 3777430986CC263EE2-8062
       Subsystem 1 - Part No SW: 4G0 951 528 A    HW: 4G0 951 528 A
       Component: E221 - MFL  H08 0009
       Serial number: 11 04 2012  D0107519
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb-SRI1
       Part No SW: 4G8 920 982 R    HW: 4G8 920 982 R
       Component: TDieGb Acc    H79 0416
       Revision: 28460177    Serial number: 658020312596025
       Coding: 338711008F15A600010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K_AU57.rod
       VCID: 438F27D9CA147A9E4E-8016
    Address 19: CAN Gateway (J533)       Labels:* None
       Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000506260
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001013
       ROD: EV_GatewPkoUDS_001_AU57.rod
       VCID: 70E5B815AB22B106E3-8024
       Battery Monitoring Control Module:
       Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790876526
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Component: J532_DCDCStab  H23 0021
       Serial number: 18021200000000000117
    2 Faults Found:
    5080 - Front Left belt tensioner control module
              U107C 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Date: 2020.11.28
                        Time: 11:24:42
                        Voltage terminal 30: 11.8 V
                        Voltage terminal 15: 11.9 V
                        Control Module temperature: 27 °C
                        System status: Terminal 15 on
                        IN ESP_standstill flag: standstill detected
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status via CAN: On
                        Terminal 15 status: On
                        Datenfeld: 0
    5081 - Front Right belt tensioner control module
              U107D 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Date: 2020.11.28
                        Time: 11:24:42
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Datenfeld: 0
    Address 20: High Beam Assist. (J844)       Labels:. 8K0-857-511.clb
       Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
       Component: FLA           H04 0004
       Revision: AA001002
       Coding: 02028264747464545425363E
       VCID: 336F771992B4CA1EDE-8066
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 A    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H15 0013
       Serial number: 002004120001011
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003023
       ROD: EV_AllWheelDiffeQSPFR.rod
       VCID: 275793495E6CB6BE72-8072
    Address 36: Seat Mem. Drvr (J136)       Labels: None
       Part No SW: 4G8 959 760     HW: 4G8 959 760
       Component: MEM-FS        H03 0154
       Revision: AA000000    Serial number: 00000027673648
       Coding: 00781B0000006001000001010101102030303232203232
       Shop #: WSC 02311 785 00200
       VCID: 77F78309C64CE63E22-8022
    Address 3B: Sensor Elect. (J849)       Labels: 4G0-907-637.clb
       Part No SW: 4G0 907 637 C    HW: 4G0 907 637 C
       Component: SARA 6D red   H02 0009
       Revision: --------    Serial number: EJ1BPA3E00CZFU0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: 2E59666D7196E7F6B1-807A
    Address 3C: Lane Change        Labels: Redir Fail!
       Part No SW: 4G0 907 566 D    HW: 4G0 907 566
       Component: J769  SWA MasterH01 0040
       Revision: 00H01000    Serial number: 6PZ 010 287-03
       Coding: 0001102
       VCID: 30657815A3A2F106A3-8064
       Subsystem 1 - Part No: 4G0 907 568 D
       Component: J770  SWA Slave H02 0040
       Subsystem 2 - Serial number: 6PZ 010 287-23
       Subsystem 3 - Serial number: 5F04.05.1200H020003CF25122ÿ
       Subsystem 4 - Serial number: F25122ÿ
    Address 42: Door Elect, Driver (J386)       Labels:. 4H0-959-793.clb
       Part No SW: 4G8 959 793 D    HW: 4G8 959 793
       Component: TSG FA        H05 0212
       Coding: 011F16205E01628002080013
       VCID: 41832DD1D808688E5C-8014
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Time Indication: 0
                        Date: 2020.11.28
                        Time: 11:24:43
    Address 44: Steering Assist (J500)       Labels:| 4G0-909-144.clb
       Part No SW: 4G0 909 144 L    HW: 4G0 909 144 G
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0002484695
       Coding: 101001010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 3261721D65AEC316D5-8066
    Address 46: Central Conv. (J393)       Labels:. 4H0-907-064-46.clb
       Revision: 00002001    Serial number: 0175250996
       Coding: 013F0E2228B93481832009040C0304000000000000000000000000000000
       Subsystem 1 - Part No: 4G0 951 177
       Component: DWA-Sensor  H01 0010
       Subsystem 2 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HO  H05 1501
       Subsystem 3 - Part No SW: 3AA 962 243     HW: 3AA 962 243
       Component: GEB.F.Heckoef  H12 0719
       Serial number: 84247147
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Time Indication: 0
                        Date: 2020.11.28
                        Time: 11:24:43
    Address 52: Door Elect, Pass. (J387)       Labels:. 4H0-959-792.clb
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       Coding: 011F16205E01628002080002
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Time Indication: 0
                        Date: 2020.11.28
                        Time: 11:24:43
    Address 53: Parking Brake (----)       Labels: 4H0-907-801.clb
       Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
       Component: EPB-4         H03 0012
       Revision: --------    Serial number: 00000000333813
       ASAM Dataset: EV_ParkiBrake 001022
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2A516A7D4D7E8BD66D-807E
    Address 55: Headlight Range (J431)       Labels:| 8X0-907-357.clb
       Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
       Component: ....LWR12.... H02 0013
       Serial number: 120504-0002-143
       Coding: 1122A6101000A300
       ASAM Dataset: EV_HeadlRegulBasic 005001
       ROD: EV_HeadlRegulBasic.rod
       VCID: 2C5D6C65478A95E69F-8078
    Address 56: Radio (R)       Labels: Redir Fail!
       Part No SW: 4G0 035 061 S    HW: 4G0 035 061
       Component: Radio U DAB   H60 0154
       Revision: AB001007    Serial number: 109EY0C7563127
       Coding: 010103020100000001
       VCID: 2D5B616174909CEE88-8078
    Address 5F: Information Electr. (J794)       Labels:. 4E0-035-6xx-5F.clb
       Part No SW: 4G0 035 670 Q    HW: 4G0 035 670 H
       Component: H-BNT-EU      H49 1034
       Revision: --------    Serial number: 190ES0C7503235
       Coding: 050101010102E9FF7D30CF3E00000003000001000000000000
       VCID: 31637D1168A8F80EAC-8064
       Subsystem 1 - Part No: 8R0 060 884 AH
       Component: EUR 2012  1308
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC9401HHFY
       Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
       Component: E380 BDT C7  H11 0204
       Serial number: 90349LE10003F
       Subsystem 4 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
    2 Faults Found:
    03276 - Please Check Software Version Management
                000 - -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Time Indication: 0
                        Date: 2020.11.28
                        Time: 11:24:47
                 Freeze Frame:
                        Text: DUA009,Front,M,0,0,6
    03157 - Functionality limited due to Communications Disruption
                000 - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 59
                        Mileage: 207830 km
                        Time Indication: 0
                        Date: 2020.11.29
                        Time: 10:19:48
                 Freeze Frame:
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 10000000 00000000
    Address 62: Door, Rear Left (J388)       Labels:. 4H0-959-795.clb
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010F14204001628002080002
       VCID: 448D24C5C71A7DA677-8010
    Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
       Part No SW: 4G0 907 441 B    HW: 4H0 907 441
       Component: SG Rueckfahrkamera  0061
       Revision: --H06---    Serial number: 525 PA8J24G2DY
       Coding: 1080005
       VCID: 26499E4D9166AFB649-8072
    Address 6D: Trunk Elect. (----)       Labels:* Redir Fail!
       Part No SW: 4G9 959 107 A    HW: 4G9 959 107 A
       Component: HDSG-Modul    H03 0139
       Revision: 14003001    Serial number: 118200102
       Coding: 097205C010
       ASAM Dataset: EV_HDSGAu572 001001
       ROD: EV_HDSGAu571.rod
    1 Fault Found:
    0004 - No Basic Setting
              B2010 00 [137] - -
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 58
                        Mileage: 207815 km
                        Date: 2020.11.28
                        Time: 11:24:43
                        Voltage terminal 30: 12.17 V
    Address 72: Door, Rear Right (J389)       Labels:. 4H0-959-795.clb
       Component: TSG HR        H04 0212
    Address 85: On Board Cam. (J852)       Labels:| 7P6-907-217.clb
       Part No SW: 4G0 907 217 A    HW: 4H0 907 217 A
       Component: DPC-SG        H25 0038
       Revision: --------    Serial number: 262130025421000
       Coding: 7A060000
       ASAM Dataset: EV_OnBoardCamerDPC 001007
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 26499E4D5966AFB649-8072
    Address 8B: Adaptive Cruise 2 (J428)       Labels:| 4H0-907-561.clb
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E04010202
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
    Address 8E: Image Processing (J851)       Labels:| 4H0-907-107-V2.clb
       Part No SW: 4G0 907 107 E    HW: 4H0 907 107
       Component: BV-SG         H31 0041
       Serial number: 005000120910127
       Coding: 04C2391A1111
       Shop #: WSC 03654 128 28888
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       VCID: 285590755372B9C67B-807C
    Address 8F: Pretens. Frt Left
    Cannot be reached
    Address 90: Pretens. Frt Right
    Cannot be reached
    Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
       Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0005
       Serial number: 120419200965
       ASAM Dataset: EV_SoundActuaGen2AU64X 002005
       ROD: EV_SoundActuaGen2AU64X_002.rod
       VCID: 2B5F6F79428492DE96-807E
    Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
       Part No SW: 4G0 907 160 B    HW: 4G0 907 160 B
       Component: SAS-GEN 2 AGA H09 0004
       Serial number: 120323200969
       ASAM Dataset: EV_ActuaForExterNoiseUDS 003013
       ROD: EV_ActuaForExterNoiseUDS.rod
    End-------------------------(Elapsed Time: 06:19)--------------------------
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  2. Re: A6 ACC Fault following remap
    135 Post(s)
    2039 Post(s)
    As VCDS says, to start with you will need a read using the latest HEX NET interface as a starter and it my need to go on the dealer system ODIS under Guided Fault Finding to make any progress. Recently I have been seeing all sorts of strange things happening on CAN BUS cars when an ECU is worked on or changed such as three cases of a new central electrics unit being fitted and coded into the car which then recoded the ABS unit for left hand drive, in one case this was impossible to rectify and the TPS the garage had used had to hand it over to their local dealer who fixed it but would not tell anyone, even the supplying TPS, what the fix was.
  3. Re: A6 ACC Fault following remap
    Dec 2007
    44 Post(s)
    Yeah getting the later interface is on my to do list. It was in with audi yesterday though they cannot do it without reflashing the ecu and removing the map.
  4. Re: A6 ACC Fault following remap
    135 Post(s)
    2039 Post(s)
    The can selectively re flash individual ECU address with ODIS, I was doing it on Friday.
  5. Re: A6 ACC Fault following remap
    May 2013
    My local dealer paid for reapplication of my Revo remap, after they applied the ECU update without asking.
    Initially they questioned if I could really tell the difference from the map update and asked if my car was previously mapped, but only so far as to pay the map being reapplied.
    The TCU update, happens to be so much better with the reapplied remap, previously i’d been considering a TCU map but no longer.
    Apparently Revo’s remaps are always repackaged on the latest stock ECU... which might also contribute to the gearbox feeling remarkably (after every drive) better.
    A6 Avant S-Line BiTdi | born Sept '13 | advanced tech pack | sports diff | privacy glass | 75l fuel tank | lighting pack | HB assist | rear cam
    Q5 S-Line Plus TFSI | born April '11 | tempted to add stage 1 Revo taking HP from 177 to 290.
  6. Re: A6 ACC Fault following remap
    Mar 2014
    Aylesbury Bucks
    21 Post(s)
    Has the company that did the remap got a copy of the remap file? If so, you could take the car to Audi, let them re-flash all relevant ECU's to get the ACC working again, then go back to the remap company with definitive proof that their remap caused the ACC to fail.
    Then they need to fix their remap, and re-flash it, or refund you, and take it elsewhere for a remap that works.
  7. Re: A6 ACC Fault following remap
    Dec 2007
    44 Post(s)
    Quote Originally Posted by bluezie View Post
    Looks like this is the route, Audi have the car again tomorrow and are instructed to flash if needed. Then it goes back for a remap. I personally dont think the map was at fault but it all seems a bit strange Audi cant fix stuff without flashing an ECU.
  8. Re: A6 ACC Fault following remap
    135 Post(s)
    2039 Post(s)
    I see all sorts of unusual software errors such as dash pods going faulty and then corrupting other units or new central convince units changing the ABS unit coding and then the ABS controller locks itself, I have see that one four times now.
  9. Re: A6 ACC Fault following remap
    Apr 2014
    SW London / Surrey
    10 Post(s)
    169 Post(s)
    Whoever flashed it ought to be able to put the original back on to see if the ACC comes back to life.
  10. A6 ACC Fault following remap
    May 2013
    Removed text. Can’t delete, posted on the wrong thread!
  1. Please Help 16683 Boost Pressure fault code and question about Turbo, Exhaust, Remap
    By BarnaBK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-08-2019, 07:36 AM
  2. Huddersfield Chip Tune Remap offer £180 and a chance to win a FREE REMAP!!!!!
    By Hyper-Remaps in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-07-2011, 03:31 PM
  3. Replies: 4
    Last Post: 14-04-2010, 12:07 AM
