Thread: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
  1. 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    Jul 2016
    United Kingdom
    Hi guys, got in my golf last night and tried to start it up only to find out the whole instrument cluster is dead, not showing mileage or anything. Tried to start it up and it starts but then cuts out about a second later.
    Car was completely fine and running well previously. Any ideas what I should be looking at? It was getting quite cold last night with some frost on the bonnet so I’m wondering if it’s related to the cold/damp?
  2. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    1837 Post(s)
    Is anything working on the dash pre ignition on? The Golf 5 is becoming extremely prone to sudden dash failure, we are seeing a lot of 10 to 12 year old dash units suddenly fail right across the VAG range.
  3. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    Jul 2016
    United Kingdom
    Hi Crasher, the dash is completely dead 99% of the time. I did disconnect the battery for a while and then try again and the red display lit up for a few seconds when I opened the car door but then I went to turn on the ignition and the whole thing went off again. Now if i come back to the car it’s just completely off. Other electrics appear to be ok (radio/ heat blowers etc)
  4. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    1837 Post(s)
    I would start with a full vehicle code scan using VCDS and with the battery on charge whilst doing the scan.
  5. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    Jul 2016
    United Kingdom
    So this is what I got from the scan, I'm starting to think maybe the instrument cluster itself is the issue.
    Code:
    08-Auto HVAC -- Status: Malfunction 0010
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Cannot be reached 1100
    25-Immobilizer -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 1010
    Address 01: Engine        Labels: 03G-906-016-BKD.clb
       Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
       Component: R4 2,0L EDC  000SG  4661
       Revision: --H08---    Serial number: VWX7Z0H53NB8O2
       Coding: 0000072
       Shop #: WSC 00682 210 71757
       VCID: 7CF679543F3F83664F-8028
    4 Faults Found
    000564 - Boost Pressure Regulation
                   P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
                 Freeze Frame:
                        Fault Status: 00110000
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 178058 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 20:49:24
                 Freeze Frame:
                        RPM: 2709 /min
                        Speed: 140.0 km/h
                        Load: 91.0 %
                        Voltage: 14.29 V
                        Bin. Bits: 00000000
                        Absolute Pres.: 2315.4 mbar
                        Absolute Pres.: 2590.8 mbar
    005712 - Powertrain Data Bus
                   P1650 - 000 - Missing Message from Instrument Cluster
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 3
                        Fault Frequency: 20
                        Reset counter: 255
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 10.72 V
                        Bin. Bits: 00000100
                        Torque: 0.0 Nm
                        Torque: 351.4 Nm
    053273 - Control Module for Instrument Cluster
                   U1019 - 000 - Missing Signal for Oil Level/Temperature
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 14
                        Reset counter: 255
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 11.40 V
                        Bin. Bits: 00000100
                        Bin. Bits: 00000000
                        (no units): 0.0
    005488 - Engine Start Blocked by Immobilizer
                   P1570 - 000 -  - MIL ON
                 Freeze Frame:
                        Fault Status: 11110000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                        RPM: 1323 /min
                        Speed: 0.0 km/h
                        Load: 0.0 %
                        Voltage: 11.10 V
                        Bin. Bits: 00000100
                        Bin. Bits: 11000000
                        (no units): 33.0
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----)       Labels: None
       Part No SW: 1K0 907 379 AD    HW: 1K0 907 379 AD
       Component: ESP MK60EC1   H35 0104
       Revision: 00H35001
       Coding: 1362401A094A0022C833020C904100823000
       Shop #: WSC 01316 785 00200
       VCID: 74E65174D76FCB2607-8020
    4 Faults Found
    01317 - Control Module in Instrument Cluster (J285)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 158
                        Time Indication: 0
                 Freeze Frame:
                        Count: 0
                        Count: 0
                        Count: 12288
                        Count: 8208
                        Count: 37632
                        Count: 0
                        Count: 0
                        Count: 0
    03391 - Coding Not Possible
                000 - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 158
                        Time Indication: 0
                 Freeze Frame:
                        Count: 2
                        Count: 0
                        Count: 12288
                        Count: 8254
                        Count: 41728
                        Count: 0
                        Count: 0
                        Count: 0
    00474 - Control Module for Immobilizer
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 158
                        Time Indication: 0
                 Freeze Frame:
                        Count: 2
                        Count: 0
                        Count: 12288
                        Count: 8211
                        Count: 41728
                        Count: 0
                        Count: 0
                        Count: 0
                008 - Implausible Signal
                 Freeze Frame:
                        Fault Status: 01101000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 158
                        Time Indication: 0
                 Freeze Frame:
                        Count: 2
                        Count: 0
                        Count: 12288
                        Count: 8224
                        Count: 41728
                        Count: 0
                        Count: 0
                        Count: 0
    Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
       Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 77FC66780619A03E22-8022
    2 Faults Found
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: None
       Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 00000008480911
       Coding: E5898F2700041500471400001400000000087F075C000100000000000000
       Shop #: WSC 00000 785 00200
       VCID: 3364926852E18C1EDE-8066
       Subsystem 1 - Part No: 1K2 955 119 E
       Component: Wischer 300508 021  0501
       Coding: 00038805
       Shop #: WSC 00000
       Subsystem 2 - Part No: 1K0 955 559 AH
       Component: RLS     130608 054  0402
       Coding: 00209069
       Shop #: WSC 00000
    1 Fault Found
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 158
                        Mileage: 0 km
                        Time Indication: 0
                 Freeze Frame:
                            ON
                        Voltage: 10.60 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    Address 15: Airbags        Labels: 1K0-909-605.lbl
       Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
       Component: 38 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD22289T
       Coding: 0013112
       Shop #: WSC 01269 785 00200
       VCID: 3D70B45064A54A6E38-8068
       Subsystem 1 - Serial number: 6332MSME2570433B6
       Subsystem 2 - Serial number: 6342MSME2D22715DH
       Subsystem 3 - Serial number: 6352QSME694D1D17V
       Subsystem 4 - Serial number: 6362QSME737C1D15R
    2 Faults Found
    00532 - Supply Voltage B+
                002 - Lower Limit Exceeded - Intermittent - MIL ON
                004 - No Signal/Communication - Intermittent - MIL ON
    Address 16: Steering wheel        Labels: None
       Part No SW: 1K0 953 549 CA    HW: 1K0 953 549 CA
       Component: J0527           051 0101
       Coding: 0000012
       Shop #: WSC 01279 785 00200
       VCID: 73E452681261CC1E1E-8026
    5 Faults Found
    00576 - Terminal 15
                012 - Electrical Fault in Circuit
    00883 - Ignition Switch (D) Terminal S
    00884 - Ignition Switch (D) Terminal X
    01744 - Ignition Switch Terminal P (D)
    00885 - Ignition Switch (D) Terminal 50
                012 - Electrical Fault in Circuit - Intermittent
    Address 17: Instruments
    Cannot be reached
    Address 19: CAN Gateway        Labels: Redir Fail!
       Part No SW: 1K0 907 530 Q    HW: 1K0 907 951
       Component: J533__Gateway   H16 0202
       Revision:   H16       Serial number: 2700K085230C5F
       Coding: E9801F060002020001
       VCID: 3560AC705C95922EF0-8060
    4 Faults Found
    01304 - Radio
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 254
                        Reset counter: 158
                        Mileage: 141856 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 13:45:58
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 158
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 4
                        Reset counter: 158
                        Time Indication: 0
    00381 - Databus Instrument Cluster
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 23
                        Reset counter: 158
                        Time Indication: 0
    Address 25: Immobilizer
    Cannot be reached
    Address 42: Door Elect, Driver        Labels: None
       Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
       Component: Tuer-SG         006 1208
       Coding: 0000564
       VCID: 387EA5444B876F46EB-806C
    1 Fault Found
    00932 - Electric Window Motor; Drivers Side (V147)
                005 - No or Incorrect Basic Setting / Adaptation
    Address 44: Steering Assist        Labels: None
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 69     2301
       Revision: 00H15000
       VCID: 2A5A8F0C852BCDD66D-807E
    3 Faults Found
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 2
                        Reset counter: 158
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 00:00:54
                 Freeze Frame:
                        Voltage: 12.00 V
                            DD
                        Temperature: 7.0°C
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
    00778 - Steering Angle Sensor (G85)
                000 - - - MIL ON
                 Freeze Frame:
                        Fault Status: 11100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Time Indication: 0
                 Freeze Frame:
                        Battery Volts: 12.3 V
                            PD
                        Temperature: 7.0°C
                        Count: 2
                        Steering Angle: 0.00°
                        Count: 0
                            SteerAng n.Init
    00750 - Warning Lamp
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01111101
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 158
                        Time Indication: 0
                 Freeze Frame:
                        Voltage: 11.25 V
                            DD
                        Temperature: 7.0°C
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
    Address 46: Central Conv.        Labels: None
       Part No: 1K0 959 433 AJ
       Component:    KSG              0401
       Coding: 01C802087F2D8405485AC69010CC
       Shop #: WSC 00682 210 88562
       VCID: 78FE65440B07AF462B-802C
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H08 9001
       Subsystem 2 - Part No: 1K0 951 178 A
       Component: Neigungssensor  003 0203
       Subsystem 3 - Part No: 1K0 951 178 A
       Component: Innenraumueberw.003 0203
    1 Fault Found
    01038 - Central Locking Thermal Protection
                000 - - - Intermittent
    Address 52: Door Elect, Pass.        Labels: None
       Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
       Coding: 0000564
       VCID: 3978A040708D764E14-806C
    No fault code found.
    Address 56: Radio
    Cannot be reached
    End-------------------------(Elapsed Time: 01:20)--------------------------
  6. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Oh my that’s a lot of malfunctions being read!
    I was going to suggest that the ignition switch might be to blame but sounds like it was working as you managed to start it (all but briefly)....
    I suggest plugging each fault code you have into the Ross tech fault code wiki...this should help you understand what each code means and possible solutions.
    The problem lies into which one is the main cause.
    I would take Crashers advice regarding the malfunctioning instrument cluster...
    Though replacing this might be expensive??...it would have to be recoded to the car....correct mileage entered...keys paired....etc
    It’s very frustrating when something was working then suddenly fails...
    Fingers crossed you can get this sorted.
    Not sure I’ve been much help but I’m sure there are others out there they may have experienced something similar.
  7. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    Jul 2016
    United Kingdom
    Quote Originally Posted by willdudeuk View Post
    Thanks for your input, I’ll give that a try. I did find a few company’s that say they can repair the original instrument cluster if it is that that’s causing the problem so I can keep the original one without the hassle of recoding it etc.
    I just need to try and figure out if that is the issue first.
    Luckily it’s not the only car I have access to so I can manage without it whilst I try and work it out but I do really like my golf very clean car for it’s age and I guess I can't complain having owned it for 6 years this is the first major issue it’s had.
  8. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    1837 Post(s)
    Start with a new ignition switch, this is clearly faulty and will cause all sorts of problems.
  9. Re: 2008 Golf 2.0 BKD Dash lights blank and no start cutting out
    Jul 2016
    United Kingdom
    Well I switched the ignition switch from our Jetta today to test it and it started straight up with all lights back on so I guess that’s fixed it! Just need to get a new one for it now. Thanks for the help guys
  1. Question Golf Auto won't start - flickering dash lights and clicking - dodgy grounds?
    By alexl102 in forum Golf MK4 - 1999 - 2004
    Last Post: 01-11-2018, 07:04 PM
  2. Please Help 2008 A4 B8 2.0Tdi - Intermittently wont start or starts and cuts out EPB, ESP & EML lights on
    By chrisk8117 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-08-2016, 08:47 PM
  3. 99 tdi no dash lights turns over wont start
    By pg339 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-12-2013, 04:07 PM
  4. Please Help Car Won't Start, No Dash Lights, Have To Reconnect Battery
    By CraigClark in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 16-04-2013, 10:18 AM
  5. Please Help TDi fails to start all lights on dash flash
    By Pod1.9TDi in forum Golf MK4 - 1999 - 2004
    Last Post: 24-12-2009, 03:28 PM
