Thread: Alarm issue
Results 11 to 20 of 22
  1. Re: Alarm issue
    #11
    1836 Post(s)
    Quote Originally Posted by John S View Post
    Saloon
    Start with a diagnostic scan but the mechanic may have to look into the last trigger tables to find the cause.
  2. Re: Alarm issue
    #12
    May 2007
    Stalyvegas
    Well got my car back tonight from independent... much lighter wallet after oil change service and pads all round
    Good service yes... but failed to identify any fault on alarm, so will use my newly purchased CTEK charger to see if battery issue
    What I was really annoyed about was they pulled the jacks out of the front and rear dash cams the unit is mounted close to rear view mirror so is a mare to get them back in... they will be getting some customer service advice tomorrow
  3. Re: Alarm issue
    #13
    1836 Post(s)
    Mechanics don’t like dash cams... do you like being video'd as you work?
  4. Re: Alarm issue
    #14
    May 2007
    Stalyvegas
    Got nothing to hide ?... I can accept that ...what I don’t accept is leaving them unplugged... I don’t see why a cloth over the camera would not do the job of sparing the mechanics blushes
  5. Re: Alarm issue
    #15
    1836 Post(s)
    It is not necessarily the video they are trying to hide, have you ever heard a grease monkeys working language, it would make a navvy blush!
  6. Re: Alarm issue
    #16
    May 2007
    Stalyvegas
    Well apart from the Dash-cam incident when I got car home I realised the aftermarket immobiliser was not working so took car to the guy who installed it... he scratched his head and could only think it was some sort of power spike... will never really know but after removal and reset it’s fully functional again... could be unfortunate coincidence but just makes me seriously suspicious
    Thankfully the installer has done work on my last 4 cars and installed the dash cams so he charged a nominal amount for his time
  7. Re: Alarm issue
    #17
    1836 Post(s)
    I have had a couple of instances of Scorpion Sterling Excel Transponder immobilisers lock up and only come back to life after being powered down but they failed immobilized which was very awkward when one did it as I was parked in the drop off/pick up at the train station collecting the customer... very confidence inspiring!
  8. Re: Alarm issue
    #18
    May 2007
    Stalyvegas
    yes at least mine failed disarmed
    Have put the CTEK trickle charger on now... only lights up to stage 3 of 7 so looks like my original issue is battery drain thro lack of use and the car warning me
    Will see if this cures it
  9. Re: Alarm issue
    #19
    1836 Post(s)
    I was trying to order an immobilser a few weeks ago and Scorpion were out of stock due to the high demand from customers with modern keyless cars (especially Audi) to stop them getting nicked... I never thought I would see aftermarket immobilisers make a comeback.
  10. Re: Alarm issue
    #20
    May 2007
    Stalyvegas
    The manufacturer should put suitable security on performance cars
    Having said that if you go aftermarket and don’t put stickers in the window it will keep the muppets guessing
  1. Alarm Issue
    By ValleyBoy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-07-2013, 05:17 PM
  2. A6 Alarm Issue
    By Clinterous in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-06-2010, 12:19 PM
  3. a4 b5 alarm issue
    By quattrogary in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-06-2010, 09:45 PM
  4. Alarm issue
    By dap1977 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-06-2010, 07:55 PM
  5. Alarm issue!
    By Waffs1984 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2008, 10:49 PM
