Thread: Retrofit auto lights mirror wipers question
  1. Retrofit auto lights mirror wipers question
    Nov 2020
    Uk
    Hi all, I have a 2009 b7 convertible, with factory drl and adaptive lights, Ive retro fitted the rls sensor, ch lh switch, auto headlight switch, and dim mirror, with the KufaTec loom. The issue I have is the guides are limited online and I have an issue, pin 18 used for power to all the above items is already in use on my cecm, would it be that as I had drl already I don’t need to mod this wire? Also there should be a wire running from the mirror in to my interior light and back out again, pin 1 and pin 11, going to 19 on the cecm. It doesn’t say what the wire is for either. Pin 19 is Also occupied already, problem I have is the cabriolet int light only has a 6 pin plug, not 11 like the guides suggest.
    Ive wired it up as is, vcds shows the rls working (pin14), the mirror dims and works but I have headlights on all the time. Regardless of switch position. Ch/lh work fine
    Any help with this would be very welcomed, Ive searched the Internet for days looking at pin outs but can’t find the answer for it.
  2. Re: Retrofit auto lights mirror wipers question
    Nov 2020
    Uk
    Obviously no one knows... I have now sorted this issue. Just downloaded elsawin. I now have all options coded and functioning
  3. Re: Retrofit auto lights mirror wipers question
    Aug 2012
    Hartlepool
    I'm looking to do exactly the same thing, ish...
    I've a B7 cab with AFS Xenon and DRL, looking to add auto dimming rear view and side mirrors plus CH / LH and auto lights from a B6 I'm breaking.
    I'm aware the B6 doesn't have the rain sensor for the auto wipers and don't mind leaving this for now to save replacing the windscreen.
    I've found loads of conflicting reports online, and can see you setup is similar to mine.
    Any help appreciated!
  1. Retro fitting Auto wipers and auto dip interior mirror to my 2001 S6
    By beelzibus in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-08-2015, 08:42 PM
  2. Question Retrofit anti dazzle mirror, rain sensor, auto lights
    By Burfy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-04-2014, 07:57 PM
  3. Retrofit auto wipers to an allroad
    By mike ryan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-04-2013, 11:05 PM
  4. Auto-Dim Mirror/Auto Lights/Auto Wipers Retrofit
    By mercedeslimos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2011, 03:50 PM
  5. Question retrofit - auto wipers/rear dim/lights...?
    By jiberjaber in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-03-2011, 04:39 PM
