Thread: Gear change fault
  1. Gear change fault
    Nov 2020
    manchester
    Hi guys,
    Got a real problem on my hands, I have 2012 MK5 Polo gti 1.4 dsg, the cars jerking into the next gear unexpectedly there is no specific gear, we have had the mechatronics changed, clutch pack changed and still havent had a fix. The vehicle mostly does it or it is more noticeable when the vehicle is cold, when warm the vehicle does it less or it is less noticeable, i suspected a remap however the ecu remap file is stock, there are no fault codes showing i am clueless now and dont know what to try next.
  2. Re: Gear change fault
    1840 Post(s)
    My first step would be an adaptation set up, can you find out if this has been done with ODIS?
  1. CVT Gear box oil change
    By Chuckles in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-01-2017, 04:08 PM
  2. Question Gear Oil Change @ 60K ?????
    By b4a4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-11-2010, 06:29 PM
  3. Gear box oil change ?
    By natz in forum Golf MK4 - 1999 - 2004
    Last Post: 12-06-2008, 03:04 PM
  4. When do you change gear?
    By RobBentley in forum Passat - Archive Topics
    Last Post: 28-01-2008, 02:59 PM
  5. Change gear oil
    By UKDK in forum Touran - Sharan - Caravelle
    Last Post: 14-01-2008, 07:48 PM
