Thread: VW 1.6tdi 2014 passat estate rear washer pipe leaking through roof into boot.
  1. Question VW 1.6tdi 2014 passat estate rear washer pipe leaking through roof into boot.
    Nov 2020
    Spain
    Hello everyone a newbie to this forum.
    I have a 2014 1.6tdi Passat estate variant. Recently when I used my rear washer jet water was leaking into the boot area. Is there any easy way to remove the roof panel at the back in order to find the leak, or is it better to let the garage sort out. Thanks for any help.
  2. Re: VW 1.6tdi 2014 passat estate rear washer pipe leaking through roof into boot.
    1835 Post(s)
    Usually It is the highly unreliable Valeo motor.
  3. Re: VW 1.6tdi 2014 passat estate rear washer pipe leaking through roof into boot.
    May 2012
    Everywhere
    308 Post(s)
    OEM Valeo strikes again , buy Bosch .
    It's been going on for 2 decades !
  4. Re: VW 1.6tdi 2014 passat estate rear washer pipe leaking through roof into boot.
    1835 Post(s)
    I can only think that VAG use Valeo is they are cheap because their products are woefully unreliable and damage VAG's reputation... I hope the high voltage parts they make for electric cars fare better. It's been going on for more than two decades, the Golf 2 was recalled in the early 90's because the heater matrix exploded blowing boiling water all over your legs, guess who made the matrix?
  5. Re: VW 1.6tdi 2014 passat estate rear washer pipe leaking through roof into boot.
    Jan 2016
    Winchester Hants
    29 Post(s)
    I had the same issue. The washer pipe splits where the bundle passes through the tailgate hinge.
    Took my local garage 6 hours...while I waited.
    I would have hated to done it myself though.
    2013 B7 Passat BlueMotion Sport Estate 2.0 TDi 177PS (CFGC), 6 speed Manual, Metallic Night Blue, Fontana alloys, Start/Stop, RNS-510 (HW H09, SW 5238 V13 maps, 8316) Nav DAB, ACC, XDS, TPM, Westfalia Tow bar, Rear View camera, Keyless Entry, Easy Open/close Electric Tailgate, Park Assist, Electric Parking Brake, DRL's, Amb light, Zebrano wood, Tinted Glass, mud flaps, 61K. Cheat emission software. Nextbase 402G iN-CAR CAM.
  6. Re: VW 1.6tdi 2014 passat estate rear washer pipe leaking through roof into boot.
    Nov 2020
    Spain
    Hi. Thanks for your reply. After what you have said it confirms my suspicion that it is going to be a difficult job, so I think I will book it into the garage so they can have them look at it.
  1. Please Help A4 (B7) Avant Rear washer pipe leaking
    By bootleexile in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-10-2015, 07:38 PM
  2. How To Golf MKiv estate boot catch actuator problems / rear washer leak
    By wcubbin in forum Golf MK4 - 1999 - 2004
    Last Post: 03-01-2013, 05:42 PM
  3. leaking rear washer pipe
    By thewall in forum Polo - Derby - Lupo - Fox
    Last Post: 22-12-2010, 04:48 PM
  4. passat estate rear washer problem
    By passat tdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 06:51 PM
  5. Passat estate - blocked rear washer
    By pcs7038 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2007, 12:18 PM
