Thread: P0727
  1. P0727
    Aug 2014
    uk
    looking at a 2006 1.9tdi 6speed touran for a friend.
    The glow plug light flashes and eml reports fault code p0727. Engine speed sensor no signal.
    It will only start by pumping the accelerator pedal while turning up a few times.
    There's alot of engine oil everywhere, can that damage the senor ? I believe the cap wasn't put on correct and it made some mess..
    is Swaping the senor a easy enough job, dont need to lock at tdc or anything special?
  2. Re: P0727
    1840 Post(s)
    What is the car and engine code?
  3. Re: P0727
    Aug 2014
    uk
    I dont know the engine code, only that its an 2006 vw touran, 1.9tdi 6speed transmission. Thanks
  4. Re: P0727
    1840 Post(s)
    It could be BKC, BXE (God help him if it is), BLS, BRU or BXF but if it is six speed I think it will be BXE () and it is a real pain to get at buried behind the oil cooler. It is held in with a 4mm hex screw which cannot be accessed straight so you have to use a ball ended key and this can easily round out meaning gearbox off the deal with it.
  5. Re: P0727
    Aug 2014
    uk
    You've just made my day mate, ill be back at the car in a day or so, I'll let you know.... thanks
  6. Re: P0727
    Aug 2014
    uk
    So its a bkc.. easier job now?
  7. Re: P0727
    1840 Post(s)
    Nope... same job.
  1. Replies: 0
    Last Post: 09-01-2014, 11:17 AM
