Thread: Mk4 Golf GT Tdi 1.9 PD 130 ASZ (Limp mode on and off for some time)
  1. Mk4 Golf GT Tdi 1.9 PD 130 ASZ (Limp mode on and off for some time)
    Nov 2020
    Higham , Kent Uk
    Hi.
    I'm new to this...
    My Golf has been starting to to run ever so irregular. One minute, I have loads of power. Then it goes into limp mode. Turn off the ignition key, and back on. It resets itself.
    I asked a couple of guys who I know, and was advised that it could be many reasons. Anyway, I was advised the other day, that my Hydraulic lifts (Tappets) are failing. And possibly the Camshaft has excessive wear on the lobes.
    I gave into a mechanic to have the Camshaft done and Hydraulic lifters (Tappets), also the Oil pump.
    Have now been advised that one of the Rocker shafts on injector 3 has snapped in two, sheared two of the four retaining bolts.
    Can any of you guys please advise why this may have happened. I like my Golf, to be honest, I've spent a small fortune on it.
    Need some impartial advise.
  2. Re: Mk4 Golf GT Tdi 1.9 PD 130 ASZ (Limp mode on and off for some time)
    1841 Post(s)
    If the bolts failed after reassembly then they were not new as they should be, they are one time only... I suspect someone screwed up.
  1. Please Help Golf mk6 limp mode
    By Xzashx in forum Golf MK6 - 2009 - 2013
    Last Post: 27-09-2019, 04:19 PM
  2. Please Help Golf Mk5 1.9 TDI Limp Mode
    By Zeeshan Shafiq in forum Golf MK5 - 2004 - 2009
    Last Post: 22-01-2017, 04:06 PM
  3. Limp Mode 1 Single time
    By klitoni in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-01-2012, 02:12 AM
  4. Please Help golf 1.9 TDI 'limp mode'
    By dave_g1007 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-11-2010, 07:55 PM
  5. GOLF gt tdi cut-out limp mode
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2008, 03:55 PM
