Thread: Help needed - Post Halfords!
Results 1 to 8 of 8
  1. Help needed - Post Halfords!
    Feb 2017
    Stockport
    6 Post(s)
    Hello to one and all,
    Hope you are all keeping well and these trying times are not having to much of an impact for you.
    I am here looking for some advice if i may...
    Took my 2013 C7 A6 (3.0 S-line 245, Stronic) in to Halfords for a Full Service, MOT and 2 new front tires on Monday -Went there last year with no issues and decent service (customer service).
    Collected my car on Tuesday morning and was greeted with this (video), The chap agreed it wasnt there prior and took it back into the bay, claimed he hooked it up to diagnostics (i presume to just clear any codes) then took it out for a quick spin - returned and all ok.
    I went home.
    two days later i got in to take my daughter to school and they are all back on again, Once driven a little bit some of the errors clear, once engine off and restart they all clear.
    Called Halfords that day and explained, they got very defensive - nothing we have done could have caused this blah blah, now there has NEVER been any errors in 4 years of me having it, only low pressure and service due. He agreed to take it back in on Sat for troubleshooting and perhaps an auto electrician but depending on outcome may charge me...
    Few peeps on facebook suggested a Battery issues others ABS Sensor, so got a new battery on the car, Got Halfords to test my battery and gave me the print out - bat @ 53% so i replaced, they told me it was an 019 and ordered it in.... it was an 020!
    Had Battery fitted, kept car live and they ran an exide unit to program my car to new batt (not Halfords), made NO changes.Went back to Halfords, told me that they still dont know and dont think it is anything to do with them so they booked it into an Auto Electrician for tomorrow; im worried they will be bias towards Halfords tbh and cost will be passed back to me.Took it on a long run today and when i stopped at a services an AA dude parked next to me so i just got talking and he said he would look again, got his gear out and hooked me up, he rekons my ABS Control Module is screwed and gave me this report:Patrol found the following fault code/s: System : Engine control 1 - VE9 / Diesel EDC 17CP44 UDSU111300 - Function restriction due to fault value received. Error Message : .P067200 - Glow plug, cylinder 2. Error Message : Circuit defective.P067600 - Glow plug, cylinder 6. Error Message : Circuit defective. Attended vehicle found various abs related data bus codes. Suspect abs module failure. Advised member to drive directly to garage for further diagnosis and repair. Engine Oil Level Ok. Coolant Level Ok.He tried to clear them but said it failed, however, by the time i drove out of the carpark the faults cleared for about 2 minutes. Anyone got any thoughts to share, are Halfords likely to blame (i know i am for taking it there in the first place....) or is it just a coincidence?... i dropped my car with them with no errors collected with errors - to me, this happened in their care.I am planning on going to an Audi
    Specialist and having a master tech look at my car on Tuesday next week for a second opinion.
    <span data-offset-key="2me3h-2-0" style="font-family: &quot;Segoe UI Historic&quot;, &quot;Segoe UI&quot;, Helvetica, Arial, sans-serif; color: rgb(5, 5, 5); font-size: 15px; white-space: pre-wrap;"><span data-text="true" style="font-family: inherit;">
  2. Re: Help needed - Post Halfords!
    Nov 2006
    Crewe, Cheshire
    43 Post(s)
    All the faults being displayed in the car relate to information needed from the ABS sensors.
    I would suspect one of the 4 is intermittent.
    The faulty glow plugs detected by the AA will need replacing, but won't cause your present problems.
    You will need to get the car connected to VCDS diagnostics or the dealer system to get the specific fault codes.
    Hopefully the auto electrician will have the required gear.
  3. Re: Help needed - Post Halfords!
    Feb 2017
    Stockport
    6 Post(s)
    Quote Originally Posted by philipharmes View Post
    Apparently Offside Rear ABS / Speed sensor is ****** possibly from a swollen wheel bearing causing contact - 282 to correct.
    Halfords had car on ramps and had rear wheels off to check wear of rear pads. I think this might infact be a coincidence afterall - GFrrrrrrrrrrrrrrrr
  4. Re: Help needed - Post Halfords!
    May 2018
    Kent
    7 Post(s)
    My girlfriend is a driving instructor and started using halfords for servicing and repairs as you’d think they are of some repute. They’ve been worse than useless when its anything other than filter changes. Failed to identify a failed reluctor ring despite a 2” chunk missing, fitted an incorrect wing mirror having declared the original as failed ( electrics), whilst they have put things right and refunded for charges for incorrect parts, lost days at work made them a very expensive choice.
    Never again.
    You’d be forgiven for thinking its where the pg chimps went when the tea bag ads ended.
  5. Re: Help needed - Post Halfords!
    Jan 2013
    Wessex. and Southern France
    85 Post(s)
    Yeah, guys, stop using Halfords. Find a local 'Steve' with a good local reputation and use them, if you want to be picky, find a good indie instead but never, ever, use Halfords.
  6. Re: Help needed - Post Halfords!
    Apr 2014
    SW London / Surrey
    125 Post(s)
    Swollen wheel bearing? Sounds nasty...
  7. Re: Help needed - Post Halfords!
    Mar 2016
    Minervois, France
    46 Post(s)
    Quote Originally Posted by VAG-Abound View Post
    Caused by the balls enlarging.
    Did this forum help you? Help make sure it's here next time! click here to make a suitable donation using PayPal and add your forum name .
    1996 A4 B5 Avant 1.8T 150 bhp code AEB automatic with 67,500 kms = 42,000 miles on 01/11/2020.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  8. Re: Help needed - Post Halfords!
    Mar 2017
    Hi. You mentioned they changed tyres? They might have damaged a wire or something?
  1. halfords coolant
    By MARKSTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 06-03-2009, 09:01 PM
  2. Halfords bulbs - ****.
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-12-2008, 02:48 PM
  3. Halfords oil
    By pulsaret in forum Golf MK5 - 2004 - 2009
    Last Post: 29-09-2008, 11:52 AM
  4. halfords PD oil
    By nfegan in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-07-2008, 03:08 PM
