Hi all,
I have a 2014 A4 B8 2.0tdi 170 quattro with S Tronic. Something, which I think is oil, is building up on the front passenger wheel. The drive shaft covers and other areas around that side have checked and all seems fine. I then had the bottom cover off and it seems there is a leak from the crankshaft pulley seal. Could this be the cause? Could the oil be spraying onto the wheel from here? The car also has signs of a front end repair but nothing showed on HPI. Could a front end smash have caused damage to this area causi g the leak? I'm at a loss so any help appreciated.
Thanks in advance
