Thread: Passat front right wing rust
  1. Passat front right wing rust
    Nov 2020
    Essex
    I know it's a common problem
    Both my 55/57 plates have it
    No joy with dealers as they dont admit who's fault it is
    I removed the rust from my 55 plate last year 2019 I thought I did a good job
    After a month it started to appear again
    The 57 plate after getting the car last year appeared after 6 months
    Question is if I get a new wing will it do it again
    I believe it comes from the inside where the cover is
    Sidepike
  2. Re: Passat front right wing rust
    1841 Post(s)
    We have a 2010 as loan car and the right wing is breaking out very badly. Personally I think the excuse about the foam sound blocker being at fault is rubbish, the Octavia 1 front wings have this in all models and these don’t rust, I think it is movement between the arch liner and wing which frets away at the extremely thin paint.
  3. Re: Passat front right wing rust
    Aug 2009
    london england
    There is a piece of sponge/plastic spacer on the inside that holds onto the water, hence the rusting.
    If you get a new wing, take off the plastic spacer.
    My 06 plate have this on both wings.
  4. Re: Passat front right wing rust
    1841 Post(s)
    I think it is the arch liner moving that is the biggest cause and the VW paint being so thin, they depended on electro galv to allow them to massively reduce the amount of paint they used and its caused all sorts of problems, Golf 6 tailgates are a joke!
  5. Re: Passat front right wing rust
    Oct 2017
    London
    12 Post(s)
    Thats very interesting about the Octavia. I always thought it was the foam as any Ive worked around are saturated in water and i throw them away.
  6. Re: Passat front right wing rust
    1841 Post(s)
    I have seen Golf 5's with warranty replacement wings that have rusted through and the foam isn't there. If you think about it, the rest of the car is soaking most of the time but doesn't rust (well sort of) unless the pint is undermined, when you take the liner out, you can see where it rubs. On the Golf 2, 3 they had a rubber gasket to stop fretting.
  7. Re: Passat front right wing rust
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    My 3C2 has all of the arch liner bolts intact (I renewed the lot a while back) and there is zero movement between wing and arch liner...never has been and I have the same foam inside. I have solid non rusty wheel arches that are 14 years old.
  1. Rust behind front bumper
    By B@rnstormer in forum Alhambra
    Last Post: 10-09-2020, 04:25 PM
  2. Question 2007 Polo Front Bumper Removal, front wing replacement.
    By SteveReedPolo in forum Polo - Derby - Lupo - Fox
    Last Post: 18-02-2016, 03:00 PM
  3. Rust on front wheel arches
    By swm1982 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-11-2015, 10:43 PM
  4. Rust on front wings
    By dode in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-10-2012, 08:10 PM
  5. Rust on front wheel arches
    By barney2 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2011, 12:16 PM
