Thread: Error codes P0263 P0269 P0272 P0266
  1. Error codes P0263 P0269 P0272 P0266
    Feb 2017
    Rochester
    I have error codes P0263, P0269, P0272 and P0266.
    I can’t believe all 4 injectors are bad. Had the dpf cleaned and turbo actuator changed.
    Could it be a problem with the high pressure fuel pump?
    Many thanks
    Rob
  2. Re: Error codes P0263 P0269 P0272 P0266
    1840 Post(s)
    Which engine code? Do you have a proper VCDS scan you can post?
  3. Re: Error codes P0263 P0269 P0272 P0266
    Feb 2017
    Rochester
    It’s not actually my car. It’s a mates car. I use obdeleven. I will get the scan. It’s weird. All 4 codes at once. I’d get it if it was just one or two.
  1. Please Help Touran 2.0 TDI judder and power loss - code P0272
    By bigdaddysi in forum Touran - Sharan - Caravelle
    Last Post: 29-09-2013, 09:10 PM
  2. A3 3.2 error codes
    By simonk in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-11-2010, 08:03 PM
  3. Help with my Error Codes please - What do they mean?
    By Dan Glibitz in forum VCDS - Help Requests
    Last Post: 06-06-2010, 11:43 AM
  4. error codes???
    By shrubby in forum Chat - Anything with wheels
    Last Post: 31-08-2008, 09:42 AM
  5. Error codes
    By kjopen in forum Golf MK3 - 1993 - 1999
    Last Post: 29-02-2008, 03:11 AM
