Thread: Image processing ecu (8E) retrofit
  1. Image processing ecu (8E) retrofit
    Aug 2012
    Hampshire
    Hi all, has anyone retrofitted this into an a7 or A6 platform ? I’m looking at retrofitting TSR and active lane assist and this seems a pre requisite of that.
    Module is easy to source just wonder about wiring and anything else I need to know ?
    Ryan
  2. Re: Image processing ecu (8E) retrofit
    Apr 2009
    Surrey
    174 Post(s)
    Quote Originally Posted by Ryan_Pestell View Post
    Ryan
    You will almost certainly need to have component protection removed from the device so it works with your car. This requires speciaist equipment that is not widely available outside the franchised dealer network
  3. Re: Image processing ecu (8E) retrofit
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    No cp on the image processing unit, i have just swapped mine to a newer version to get traffic sign recognition on, though i think it pulls the speeds from the maps anyway.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  4. Re: Image processing ecu (8E) retrofit
    Aug 2012
    Hampshire
    Perfect, it is based in the passenger footwell area, think passenger seat needs removing too. Found a couple of threads online googling by Rizzio and another on a Russian forum but seems to give wiring information.
  5. Re: Image processing ecu (8E) retrofit
    Dec 2007
    43 Post(s)
    Yes it is, and yes seat needs to come out.
  6. Re: Image processing ecu (8E) retrofit
    Aug 2012
    Hampshire
    Has anyone retrofitted this? Just after how about fitting the module in the floor , any cutting that needs doing ? Cable routing ? Up passenger “A” pillar and to camera?
    I have the bracket and the ecu and the lvds cable should be at TPS this week, I have a new connector to wire the ecu into the flexray.
    So just looking for some guidance really.
  1. Image Process Ecu 8e retrofit
    By Ryan_Pestell in forum A7 - S7
    Last Post: 08-11-2020, 06:35 PM
  2. Help Identifying Image - 2006 A6 3.0 TDI
    By Trivstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2015, 02:09 PM
  3. How low to go??? - Image attached
    By macarthur.2000 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-09-2008, 05:27 PM
  4. re size image? jpeg
    By hogiapesda in forum Chat - Completely Off Topic
    Last Post: 29-12-2007, 12:18 PM
