Thread: Golf mk4 tdi Ccv valve replacement diaphragm
  1. Golf mk4 tdi Ccv valve replacement diaphragm
    Jul 2010
    peebles
    Hi all wondering if anyone has had any problems with the ccv diaphragm on their mk4 1.9tdi (asz). I am getting all the symptoms burning oil smell in car and Smokey on idle and using oil was wondering if it can be changed without removing rocker cover. Also is this a common problem with 1.9pd engine
  2. Re: Golf mk4 tdi Ccv valve replacement diaphragm
    1840 Post(s)
    What there is of a PCV system is built into the PD TDI cam cover, I would suspect your problem lies elsewhere.
  3. Re: Golf mk4 tdi Ccv valve replacement diaphragm
    Jul 2010
    peebles
    Well i had car a run and when came back popped the bonnet their was one end of the pipe from ccv had came off after making sure it was all connected properly before hand
  4. Re: Golf mk4 tdi Ccv valve replacement diaphragm
    1840 Post(s)
    Which end had it come off, the cam cover or turbo inlet? If the hose is falling apart the part number is 038 103 493 AC and they cost £24.47
  5. Re: Golf mk4 tdi Ccv valve replacement diaphragm
    Jul 2010
    peebles
    It had came off at turbo inlet side. Theirs nothing wrong with pipe doesn’t seem split or anything. Has had new turbo as thought that’s why it was using oil but starting to think it’s this ccv that’s splits or something inside.
  6. Re: Golf mk4 tdi Ccv valve replacement diaphragm
    1840 Post(s)
    It does not have a crankcase vent valve, it is just a breather from a splash guarded cavity in the cam cover straight into the turbo intake pipe, I cannot imagine how the pipe would blow off.
  1. Question Turbo diaphragm
    By bertb in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-08-2016, 02:57 PM
  2. Intake Manifold Diaphragm Gone..
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-08-2012, 11:55 AM
  3. Q7 Intake Manifold Diaphragm
    By Chris Taee in forum VCDS - Help Requests
    Last Post: 09-07-2012, 01:20 PM
  4. Please Help EGR Anti shudder diaphragm
    By cazyp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2009, 12:53 PM
