Thread: Octavia 2007 Rear Brake Calliper Slider Pins.
  1. Octavia 2007 Rear Brake Calliper Slider Pins.
    Oct 2020
    Basingstok UK
    I have just finished replacing rear discs and pads and overhauled the genuine rear callipers on our daughter's Octavia. The replacement calliper repair kit contained slider pins of equal diameters top and bottom, each pin had three equidistanced flats, whereas the originals, on the callipers, have pins of different, top and bottom shape.
    The original pins looked OK, so I replaced them as I was unsure.
    I was wondering if anyone had come across this setup before and maybe knew the reason why the original pins are different top and bottom. Original Top has a tapered pin, tapering in three parallel steps. The bottom original is parallel but has three equidistanced flats.
  2. Re: Octavia 2007 Rear Brake Calliper Slider Pins.
    1841 Post(s)
    Replacement caliper carriers are handed but the pins being installed tappers top and parallel bottom.
  1. Noisy rear brake calliper (electronic parking brake)
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-08-2016, 06:41 PM
  2. Replacement Slider Pins for C38 Brakes on 2002 Allroad 2.5 Tdi Ake Auto
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-04-2014, 09:57 PM
  3. Audi a3 rear brake caliper slider bolts - replace?
    By GMW43 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-09-2013, 03:24 PM
  4. octavia rear brake flexis
    By mickgrant in forum Octavia
    Last Post: 29-05-2013, 08:07 PM
  5. Rear Brake Calliper
    By MathewRB in forum Golf MK4 - 1999 - 2004
    Last Post: 06-07-2009, 06:39 PM
