Thread: 1st Gear selection issue.
  1. Question 1st Gear selection issue.
    Mar 2014
    Nottingham. UK
    2011. 2.0L TDI, 170Ps.
    I'm hoping this could be something overlooked.
    I've just had a new used low mileage Manual Gearbox fitted as the old ones shaft bearings were shot causing excessive wobble/ Vibrations.
    Now the new gearbox has cured these issues with no more wobble/ Vibrations. It's now Alot more responsive and tight.
    However the old gearbox also had an issue of not wanting to go into 1st gear at random times.
    And now this new gearbox is doing the same but it's more prominent!
    It will not go into 1st gear at all, It refuses to even push up into 1st from neutral UNLESS I slightly wiggle the gearstick to the right and then it falls into 1st gear with ease as it should.
    Does this sound like something needs adjustment? Or something else?
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
    0 0
  2. 1st Gear selection issue.
    Nov 2009
    Ireland
    Did U try put in 3rd first and then 1st gear....? It worked for me....
    Had the similar problem in my Van... but newer got down to the source of the problem...
    2001 allroad 2.5 AKE manual -gone
    2007 A6 Estate 2.0 BRE manual
  3. Re: 1st Gear selection issue.
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by luklawecki View Post
    Yesterday it would go into 1st if I put it into 2nd first but now that doesn't work. Now only wiggling it slightly to the right while pushing it into 1st gear works and when I do this it goes into gear with ease. Almost like something is mis- aligned.
  4. Re: 1st Gear selection issue.
    Sep 2020
    South Wales
    Don’t you have to align a gearstick on a manual?
    isn’t there adjustment on the stick / cabling to sort that out? If you replaced the gearbox, perhaps the cabling between stick and transmission needs adjusting correctly?
  5. Re: 1st Gear selection issue.
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by Veeb2k View Post
    Do these have cables or arms? It's something I can get looked at.
  6. Re: 1st Gear selection issue.
    Sep 2020
    South Wales
    I’ve got a tiptronic, so no idea sorry.
    all I know is that on previous cars, if there were issues in getting the car into a notchy first gear it was recommended to adjust the linkage.
    just had a google, and some bits cone up from this forum -
    does the car go into gear easily when engine off?
    also, does it go into gear if you pump the clutch a few times first?
    if it goes into gear, then possibly issue with master cylinder or air getting into system, may need more bleeding to get air out?
  7. Re: 1st Gear selection issue.
    Mar 2014
    Nottingham. UK
    Yes the car goes into all gears with the engine off.
    I will look into having the Master cylinder/Slave cylinder re-bled and see if there is any improvement.
    Pumping the clutch doesn't help it get into 1st, Only slightly wiggling it as mentioned does.
  1. Gear Selection (Bit Of An Odd One)
    By lc25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-08-2010, 06:03 PM
  2. Please Help Gear selection issue PASSAT 2004 1.6
    By sz_danii in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-07-2009, 12:49 PM
  3. Gear selection
    By mutindas in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-03-2009, 03:36 PM
  4. First Gear Selection
    By Greenfield in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2008, 06:24 PM
  5. Gear Selection
    By fencer in forum Golf MK3 - 1993 - 1999
    Last Post: 04-06-2008, 06:49 PM
