Thread: leon po19300 fault code
  1. leon po19300 fault code
    Oct 2017
    Fleet
    Hi got leon 2010 yr 1.6 tdi cay engine glow plug light flashing code po19300 car in limp home code cannot be erased checked wiring to ecu ,0.9 volts on signal wire at idle ,5 volt reference on other wire and good earth wire,signal wire has 1.4 volts at blipping throttle when stationary replaced fps still same code.
    Already replaced hp pump with secondhand one as customer previously misfuelled it.
    Anybody had this fault ?
  2. Re: leon po19300 fault code
    1840 Post(s)
    This car should not have Add Blue, what are you reading the codes with?
  3. Re: leon po19300 fault code
    Oct 2017
    Fleet
    Bosch kts
  4. Re: leon po19300 fault code
    Oct 2017
    Fleet
    Fuel high pressure sensor short to b+
  5. Re: leon po19300 fault code
    1840 Post(s)
    16577 (P0193) - Fuel Rail Pressure Sensor (G247): Circuit High Input
    I misread it as P1930. The full engine code will be CAYC, the G247 fuel pressure sender shares its positive 5V power feed with five other sensors from a combined junction a few inches up the harness from the ECU fed by a single yellow/grey wire which is very thin at only 0.5mm² CSA and from the junction it drops to a 0.35mm² CSA yellow/grey wire but if the problem lay at the feed or the junction you would expect 5 other fault codes BUT I have had another forum members car in a couple of times now with a similar code on this same circuit together with a code report a problem with this circuit which I THINK is the ECU but we have not taken the £1.5K plunge yet... he may get shot of it. In your case I would expect the fault to be the sensor itself unless you also get
    4124 (P0651) - Sensor Reference Voltage B [168] - Open Circuit
    To start with, check the G247 plug at pin 3 on the yellow/grey wire for an engine running 5v signal. I get the part number of the sensor to be 03L 906 054 A which is a revised part as they have been unreliable, the VAG retail price is £65.32. Remember when removing this sensor the system is under very high pressure.
    This picture is of the junction on a CC so is very slightly different
  6. Re: leon po19300 fault code
    Oct 2017
    Fleet
    Thanks crasher will get genuine fuel rail switch and see if it fixes it will let you know
  7. Re: leon po19300 fault code
    Oct 2017
    Fleet
    hi still trying to solve this one no one can test ecu properly changed frp switch still no change so now double checking wiring does middle wire (yellow /brown trace )of frp go to pin 40 on ecu plug as cant find any continuity on this wire anywhere at ecu plug ?
  8. Re: leon po19300 fault code
    Oct 2017
    Fleet
    It was broken wire to ecu pin 40 yellow brown trace signal wire from middle terminal of fuel rail switch hope that helps someone else
  1. Please Help Seat Leon 1.4 tsi fault code p000A
    By kevin b in forum Leon
    Last Post: 14-08-2018, 07:51 PM
  2. Seat Leon 1.8 20v fault code
    By Batunball in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 03-12-2012, 11:31 PM
  3. Replies: 6
    Last Post: 10-05-2011, 11:03 AM
  4. 00533 code 1.6 leon
    By badade 1.8t in forum Leon
    Last Post: 03-04-2011, 05:01 PM
  5. seat leon fault code 16947 system voltage too high?
    By yas_b in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 30-03-2010, 11:37 PM
