Thread: Q7 4M Coolant fan control circuit fault, only start with jump starter
  1. Q7 4M Coolant fan control circuit fault, only start with jump starter
    Aug 2016
    Own an Audi Q7. Went weekend shopping and after loading the car with goodies the car did not start. A drive system error message came on. The car would make a click sound and then turn off. Luckily I had jump pack in the boot and was able to jump start the car and it switched on. I thought maybe the battery is going as its winter and they tend to pack up in the winter. Once home I checked the battery voltage it was 12.4v. the car still would not start. The voltage would drop to 12v when starting and then back up to 12.4v with no load. I replaced the battery and still the same issue. I performed a diagnostic and it contains the errors below. basically the coolant fan and glow plug control module are getting low voltage yet the battery voltage is 12.8v with the new battery and 12.3ish when on load. ive checked the fuse and its fine. I looked at the connector for the coolant fan and the voltage there is 8.5v.. the connector has no water damage. ive looked at the earth wire for the coolant fan and that is clean with no rust.
    the only thing I have not done is look at the relay. I cant locate it in any diagram. So basically what is causing the low voltage? any help would be much appreciated. Thanks
    PHP Code:
    Monday,26,October,2020,19:10:36:64250VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64VCDS Version20.4.2.0 (x64)Data version20200730 DS317.0www.Ross-Tech.com
    VIN
    WAUZZZ4M7GD   License PlateAA0001
    Chassis Type  4M-AU73 (4M1)Scan01 02 03 06 08 09 15 16 17 19 28 29 2B 36 39 42 44 46 47 50          52 5F 6C 6D 81 82 A5 AC BB BC D6 D7
    VIN
    WAUZZZ4M7GD
    01
    -Engine -- StatusMalfunction 001002-Auto Trans -- StatusOK 000003-ABS Brakes -- StatusMalfunction 001006-Seat MemPass -- StatusOK 000008-Auto HVAC -- StatusMalfunction 001009-CentElect. -- StatusOK 000015-Airbags -- StatusOK 000016-Steering wheel -- StatusOK 000017-Instruments -- StatusOK 000019-CAN Gateway -- StatusMalfunction 001028-HVACRear -- StatusOK 000029-Left Light -- Status: INTERFACE NOT COMPATIBLE 2B-SteerColLock -- StatusOK 000036-Seat MemDrvr -- StatusOK 000039-Right Light -- Status: INTERFACE NOT COMPATIBLE 42-Door ElectDriver -- StatusOK 000044-Steering Assist -- StatusOK 000046-Central Conv. -- StatusMalfunction 001047-Sound System -- StatusOK 000050-Seat Adj3rd row -- StatusOK 000052-Door ElectPass. -- StatusOK 00005F-Information Electr. -- StatusMalfunction 00106C-Back-up Cam. -- StatusOK 00006D-Trunk Elect. -- StatusOK 000081-Gear Shift -- StatusOK 000082-Heads Up Display -- StatusOK 0000A5-Frt SensDrvAssist -- StatusMalfunction 0010AC-Reductant Control -- StatusOK 0000BB-Door Rear Drv -- StatusOK 0000BC-Door Rear Pass -- StatusOK 0000D6-Light Ctrl Left 2 -- Status: INTERFACE NOT COMPATIBLE D7-Light Ctrl Right 2 -- Status: INTERFACE NOT COMPATIBLE  -------------------------------------------------------------------------------Address 01Engine (J623-CRTC)       LabelsRedir Fail!   Part No SW4M0 907 401     HW059 907 309 B   Component3.0TDI EDC17  H45 0004     Revision91H45---       Coding2A2A40320326050334080000000000000000000000000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_ECM30TDI0114M0907401 001008   ROD: EV_ECM30TDI0114M0907401.rod   VCID: 66C9AC74999D37B689-8032
    3 Faults Found:4527 Coolant Fan Control Circuit 1           P0480 00 [039] - Electrical Malfunction          Not Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority2                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
                        Engine speed
    0.00 /min                    Normed load value0.0 %                    Vehicle speed0 km/h                    Coolant temperature45 °C                    Intake air temperature17 °C                    Ambient air pressure990 mbar                    Voltage terminal 3011.600 V                    Unlearning counter according OBD40                    Air massspecified value434.3 mg/stroke                    Coolant temperature at radiator outletactual value42.0 °C                    Heat delivery temperature in cooling system: -273.1 °C                    Outside air temperature10.5 °C                    Coolant fan 2activation0.00 %                    Coolant fan 1activation10.54 %                    Fuel temperature36.1 °C
    5456
    Starter Will Not Turn           P3054 00 [167] - Jammed or Electrical Malfunction          MIL ON Not Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority2                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:07
                        Engine speed
    0.00 /min                    Normed load value0.0 %                    Vehicle speed0 km/h                    Coolant temperature45 °C                    Intake air temperature17 °C                    Ambient air pressure990 mbar                    Voltage terminal 3011.080 V                    Unlearning counter according OBD40                    Accelerator pedal travel0.00 %                    Starter controlInterlock- or P/N-signal-Bits 0-717                    Engine statusCOENG_READY                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE1
    14615
    Control Module for Glow Plugs           P052F 00 [038] - Implausible Voltage          Intermittent Not Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority2                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:07
                        Engine speed
    0.00 /min                    Normed load value0.0 %                    Vehicle speed0 km/h                    Coolant temperature45 °C                    Intake air temperature17 °C                    Ambient air pressure990 mbar                    Voltage terminal 3011.100 V                    Unlearning counter according OBD40                    Glow-control unitactivation voltage0 mV                    Glow_period_control_unit_ground_offset_voltage0 mV                    Glow-control unitcalculated glow voltage0 mV                    Glow_period_control_unit_energy_integrator_calculated_value0.0 V²s                    Glow cycles upon reaching temperature threshold-Bits 0-70                    Glow cycles upon reaching temperature threshold-Bits 0-71                    Glow status-Bits 0-70                    Glow status-Bits 0-70                    Co EOM st Op Mode Short-Bits 0-78
    Readiness
    0 0 0 0 1
    -------------------------------------------------------------------------------Address 02Auto Trans (J217)       Labels:| 0BK-927-156.clb   Part No SW4M0 927 158 J    HW0D5 927 156 H   Component0D5 30TDIRdW  H03 1007     Revision: --H03---       Coding100000   Shop #: WSC 00000 000 00000   ASAM Dataset: EV_TCMALX52011 002009   ROD: EV_TCMALX52011_AU73.rod   VCID: 3B7F2D00B29F5A5E06-806E
    No fault code found.
    Address 03ABS Brakes (J104)       Labels4M0-907-379-PRE-V1.clb   Part No SW4M0 907 379 K    HW4M0 907 379 K   ComponentESP9 Premium  H08 0521     Coding249830B230A20A9F96A3589400825292E6A6D2240C0C50691A004A4967654B   Shop #: WSC 22162 002 1048576   ASAM Dataset: EV_ESP9BOSCHAU736 011006   ROD: EV_ESP9BOSCHAU736_AU73.rod   VCID: 3F875910A687467E2A-806A
    8 Faults Found:420352 TPMS WarningFront Left Tire           C1054 00 [047] - Pressure too Low          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
                        74 00 80 00 C2 24 00 00 F0 80
    416768
    TPMS WarningFront Right Tire           C1056 00 [047] - Pressure too Low          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
    420096
    TPMS WarningRear Left Tire           C1058 00 [047] - Pressure too Low          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
    417024
    TPMS WarningRear Right Tire           C105A 00 [047] - Pressure too Low          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
    415488
    TPMS WarningFront Left Tire           C1055 00 [047] - Flat          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
    419328
    TPMS WarningFront Right Tire           C1057 00 [047] - Flat          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
    419584
    TPMS WarningRear Left Tire           C1059 00 [047] - Flat          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
    419840
    TPMS WarningRear Right Tire           C105B 00 [047] - Flat          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Mileage110975 km                    Date2020.10.26                    Time19:04:02
    -------------------------------------------------------------------------------Address 06Seat MemPass (J521)       Labels:* None   Part No SW4M0 959 760 E    HW4M0 959 760 E   ComponentMEM-BFS       008 0014     Serial number00000151565537   Coding002010000000B0410000210101010000110000313100000000000000000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_SCMPasseSideCONTIAU736 006007   ROD: EV_SCMPasseSideCONTIAU736_AU49.rod   VCID: 3A712804BDA563561D-806E
    Address 08Auto HVAC (E87)       Labels:* None   Part No SW4M0 820 043 K    HW4M0 820 043 K   ComponentKlima Zone 4  H52 0060     Coding6618003C5544451102220180800000000000000000000000000000000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013   ROD: EV_AirCondiFrontBHTCAU736.rod   VCID: 2D5B13587CEBC4EE88-8078
    Fresh Air Blower Front:    Subsystem 1 Part No SW4M2 820 021     HW4M2 820 021    ComponentJ216 FLuftV  H05 0001    Serial number00000000000000447173
       Relative humidity sensor in fresh air intake duct
    :    Subsystem 2 Part No SW4H0 907 658 A    HW4H0 907 658 A   ComponentAQ_Hum_Sensor  H01 0003    Serial numberC68885B7000000000001
    1 Fault Found
    :262658 High Pressure Sensor           B10AE 31 [009] - No Signal          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority5                    Fault Frequency1                    Reset counter244                    Mileage109924 km                    Date2020.09.23                    Time17:25:25
    17.50 °C                    Engine speed/min                    Compressor currentactual value0.00 A                    Temperature after evaporator22.00 °C
    -------------------------------------------------------------------------------Address 09CentElect. (J519)       Labels:* None   Part No SW8W0 907 063 G    HW8W0 907 063 G   ComponentBCM1 MLBevo   H12 0215     Coding07501943E16900CD010D87155B2F00F911033100900000000000000020001A810A450122025605   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_BCM1BOSCHAU736 014003   ROD: EV_BCM1BOSCHAU736_014.rod   VCID: 3F875910A687467E2A-806A
    Control Unit For Wiper Motor:    Subsystem 1 Part No SW4M2 955 119 A    HW4H1 955 119 C  Labels1KX-955-119.CLB   ComponentWWS536 141216  042 0792    Serial number:         150115093452   Coding1BC7F7
       Rain Light Recognition Sensor
    :    Subsystem 2 Part No SW8U0 955 559 C    HW8U0 955 559 B  Labels8U0-955-559.CLB   ComponentG397_RLFS  H06 0004    Serial number20382874               Coding02006E
       Light
    switch:    Subsystem 3 Part No SW4M0 941 531 P    HW4M0 941 531 P   ComponentE1 LDS  H05 0007    Serial number03 06 2015  00029413
       Automatic Day Night Interior Mirror
    :    Subsystem 4 Part No SW4M0 857 511 A    HW4M0 857 511 A   ComponentY7_Innenspieg  H08 0002    Serial numberGX1CE111061511520276   Coding230000
       Interior Light Module
    :    Subsystem 5 Part No SW4M0 947 135 BE    HW4M0 947 135    ComponentJ528-Dachele  H13 0081    Serial numberQ00018609
       Convenience
    And Driver Assist Operating Unit:    Subsystem 6 Part No SW4M0 925 301 A    HW4M0 925 301 A   ComponentSL-Q7NF/AU736  H09 0006    Serial number00000000000000003928
    No fault code found
    Address 15Airbags (J234)       Labels:* None   Part No SW4M0 959 655     HW4M0 959 655    ComponentAirbag10.44   H50 0081     Serial number003L1000A6XV   CodingAACCF0D80C80000058F650F3C08C00000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_AirbaAU10BPAAU736 005012   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod   VCID: 78F5F20CC329B1462B-802C
    Side Sensor Driver Front:    Subsystem 1 Part No SW: -----------    HW442 062 210 17   ComponentSideSensor_Df  1E2 0887    Serial number3577Y00B728A7A7394FK   Coding2D2D2D
       Side Sensor Passenger Front
    :    Subsystem 2 Part No SW: -----------    HW442 061 906 15   ComponentSideSensor_Pf  1E2 0887    Serial number3587Y00AB193B8525542   Coding2D2D2D
       Side Sensor Driver Rear
    :    Subsystem 3 Part No SW: -----------    HW442 0B2 406 15   ComponentSideSensor_Dr  1C7 0148    Serial number3517700BB1AC53B4823I   Coding2D2D2D
       Side Sensor Passenger Rear
    :    Subsystem 4 Part No SW: -----------    HW442 0B2 406 15   ComponentSideSensor_Pr  1C7 0148    Serial number3527700B91AC53B2407D   Coding2D2D2D
       Front Sensor Driver
    :    Subsystem 5 Part No SW: -----------    HW442 0C2 906 15   ComponentFrontSensor_D  1C5 014A    Serial number3557500C91B50DF5931N   Coding2D2D2D
       Front Sensor Passenger
    :    Subsystem 6 Part No SW: -----------    HW442 0C2 906 15   ComponentFrontSensor_P  1C5 014A    Serial number3567500C91B50DF1F0F.   Coding2D2D2D
       Pedestrian Protection Center
    :    Subsystem 7 Part No SW: -----------    HW442 0C2 906 15   ComponentPedP_Sensor_C  1C5 014A    Serial number2307500C71B50DF27408   Coding2D2D2D
       Pedestrian Protection Driver 2
    :    Subsystem 8 Part No SW: -----------    HW442 422 906 15   ComponentPedPSensor_D2  21E 0887    Serial numberI0M8U00A5198985372DT   Coding2D2D2D
       Pedestrian Protection Passenger 2
    :    Subsystem 9 Part No SW: -----------    HW442 422 906 15   ComponentPedPSensor_P2  21E 0887    Serial numberI0N8U00AF1989853B0A$   Coding2D2D2D
       Central Sensor XY
    :    Subsystem 10 Part No SW: -----------    HW410 202 505 15   ComponentCentrSensorXY  1C8 0108    Serial numberI0O7800A9165692272D0   Coding2D2D2D
    No fault code found
    Address 16Steering wheel (J527)       Labels4M0-907-129.clb   Part No SW4M0 907 129 HD    HW4M0 907 129 HD   ComponentLenks.Modul   H11 0008     ASAM DatasetEV_SMLSKLOAU736 006008   RODEV_SMLSKLOAU736_006.rod   VCID79F3F708F823A84E54-802C
    No fault code found
    Address 17Instruments (J285)       LabelsRedir Fail!   Part No SW4M0 920 790     HW4M0 920 790    ComponentFBenRDW       H12 0280     Coding242401D0288006000123E9601000000000000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_DashBoardAU736 001020   ROD: N/A   VCID: 6CDDDE5C87710DE6DF-8038
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.No ASAM data for: "EV_DashBoardAU736" (AU73No fault code found.
    Address 19CAN Gateway (J533)       Labels:* None   Part No SW4M1 907 468 A    HW4M1 907 468 A   ComponentGateway       H13 4079     Revision3B010050    Serial number5043B002115519   Coding0301000100008F407F0700000059003248120007008000000100000000000000   Shop #: WSC 55552 002 1048576   ASAM Dataset: EV_GatewCONTIAU736 002040   ROD: EV_GatewCONTIAU736_002_AU73.rod   VCID: 356B3B3894BB8C2EF0-8060
    Multi Function Steering Wheel Control Module:    Subsystem 1 Part No SW4M0 951 523     HW4M0 951 523    ComponentJ453 MFL  H06 0002    Serial number20150528162726 RD088
       Battery Monitoring Control Module
    :    Subsystem 2 Part No SW8S0 915 181     HW8S0 915 181    ComponentJ367-BDMHella  H10 9041    Serial number7079276403
    1 Fault Found
    :197149 Generator           U1052 00 [009] - No Communication          [New featureExtended UDS fault detail is only supported by current geninterfaces]          Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority4                    Fault Frequency1                    Reset counter1                    Mileage110975 km                    Date2020.10.26                    Time18:40:59
    -------------------------------------------------------------------------------Address 28HVACRear (E265)       Labels:* None   Part No SW4M0 919 158 C    HW4M0 919 158 C   ComponentKlima Zone 2  H52 0060     Coding000000000000040100820080000000000000000000000000000000000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_AirCondiFondBHTCAU736 001013   ROD: EV_AirCondiFondBHTCAU736.rod   VCID: 356B3B3894BB8C2EF0-8060
    Address 29Left LightInterface not compatible.Please upgrade to a current Ross-Tech interface.
    Address 2BSteerColLock (J764)       Labels:* 5Q0-905-861.clb   Part No SW3Q0 905 861 A    HW3Q0 905 861 A   ComponentELV-MLBevo    H05 0032     Serial number15000069779012   Coding8800000000000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_ELVMarquMQBB 001007   ROD: EV_ELVMarquMQBB.rod   VCID: 3261002465D59B16D5-8066
    Address 36Seat MemDrvr (J136)       Labels:* None   Part No SW4M0 959 760 E    HW4M0 959 760 E   ComponentMEM-FS        008 0014     Serial number00000151545539   Coding002010000000B0410000210101010000110000313100000000000000000000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007   ROD: EV_SCMDriveSideCONTIAU736_AU49.rod   VCID: 3A712804BDA563561D-806E
    Address 39Right LightInterface not compatible.Please upgrade to a current Ross-Tech interface.
    Address 42Door ElectDriver (J386)       Labels:* None   Part No SW4M0 959 593 H    HW4M0 959 593 F   ComponentTSG FS        005 0125     Serial number0000288024178    Coding001F9A005001000000003082   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005   ROD: EV_DCU2DriveSideMAXHCONT_AU49.rod   VCID: 41835FE8D073308E5C-8014
    Address 44Steering Assist (J500)       Labels:* None   Part No SW4M0 909 144 G    HW4M0 909 144 B   ComponentEPS_MLBEVO1BS H17 0004     Serial number0000986068   Coding90000001000100   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_EPSVWBSAU736 008020   ROD: EV_EPSVWBSAU736_008.rod   VCID: 336F05209ACF921EDE-8066
    Address 46Central Conv.Cannot be reached
    -------------------------------------------------------------------------------Address 47Sound System (J525)       Labels:* None   Part No SW4M0 035 223 A    HW4M0 035 223    ComponentMIB2_amp_PD   H02 0420     Serial number00000000005816   Coding01350608008AF53AAF0000010000   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001   ROD: EV_AMPMst16C4Gen2BOSE_AU73.rod   VCID: 2143FF683033108E3C-8074
    Address 50Seat Adj3rd rowCannot be reached
    -------------------------------------------------------------------------------Address 52Door ElectPass. (J387)       Labels:* None   Part No SW4M0 959 592 D    HW4M0 959 592 C   ComponentTSG BFS       005 0036     Serial number0000155441782    Coding005F9A005C01000000003080   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005   ROD: EV_DCU2PasseSideMAXHCONT_AU49.rod   VCID: 3C7D2E1CB7915D660F-8068
    Address 5FInformation Electr. (J794)       Labels:* 4M0-035-MIB-HGH2.clb   Part No SW4M0 035 035 B    HW4M0 035 035    ComponentMU-P-LND-EU   042 0358     Serial numberA270G0F7507810   Coding013706010000000013111102000A00332F001BE701700100DE   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115   ROD: EV_MUHig6C3Gen2HBAS_VW37.rod   VCID: 234FF5602A2F029E2E-8076
    Data medium:    Subsystem 1 Part No SWV03 959 802 CA    HW: -----------   ComponentECE 2015  --- 0118    Serial number: --------------------
    Display unit 1 for multimedia system:    Subsystem 2 Part No SW4M0 919 605     HW4M0 919 605    ComponentAU536_DU_HIGH  H43 0008    Serial numberAUZ8Z9FJ400DY5
       Multimedia Operating Unit
    :    Subsystem 3 Part No SW4M0 919 615 D    HW4M0 919 615 D   ComponentControlUnit_P  H14 0165    Serial number20061500000000000032
       Compact Disc Database
    :    Subsystem 4 Part No SWV03 959 800 EG    HW: -----------   ComponentGracenote2  --- 1010    Serial number: --------------------
    3 Faults Found:5632 Eject button           B13B0 07 [008] - Mechanical Failure          Intermittent Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency1                    Reset counter32                    Mileage109939 km                    Date2020.09.25                    Time18:44:43
                        Voltage terminal 30
    15.0 V
    3086
    Antenna for Telephone Mount           B1564 01 [008] - Electrical Failure          Intermittent Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority4                    Fault Frequency2                    Reset counter40                    Mileage110445 km                    Date2000.00.00                    Time00:00:00
                        Voltage terminal 30
    11.9 V                    Status of telephone-Antenna diagnosticOK                    Status of telephone-Telephone baseplate diagnosticnot connected                    Status of telephone-Handset in handset holder (cradle): selected                    Status of telephone-Handset holder (cradle): connected
    6696
    Instrument Cluster Control Module on Optical Bus           U10C0 00 [008] - No Communication          [New featureExtended UDS fault detail is only supported by current geninterfaces]          Intermittent Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency2                    Reset counter37                    Mileage110338 km                    Date2020.09.30                    Time22:07:55
                        Voltage terminal 30
    14.7 V
    -------------------------------------------------------------------------------Address 6CBack-up Cam. (J772)       Labels:* Redir Fail!   Part No SW4M0 980 556     HW4M0 980 556    ComponentRVC Compact   H08 0130     Coding0237060102002001000040   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008   ROD: EV_CamSysRVRVCPANAMLBEv_004.rod   VCID: 72E1C024A555DB1615-8026
    Address 6DTrunk Elect. (J605)       Labels:| 5Q0-959-107.clb   Part No SW4M0 959 107     HW4M0 959 107    ComponentHDSG-Modul    H12 0143     Revision: --------    Serial number30093564700000   Coding0010   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_DeckLidCONTIAU736 001010   ROD: EV_DeckLidCONTIAU736_VW37.rod   VCID: 70E5CA2CAB59E906E3-8024
    Address 81Gear Shift (J587)       Labels4MX-713-041-81.clb   Part No SW4M2 713 041 D    HW4M2 713 041 D   ComponentGSM-LL        H07 0066     Revision0L0D5012    Serial number20150615000294   ASAM DatasetEV_GSMWaehlZFAU736 001013   RODEV_GSMWaehlZFAU736.rod   VCID2757E1705E17EEBE72-8072
    No fault code found
    Address 82Heads Up Display (J898)       Labels:* None   Part No SW4M0 919 617 A    HW4M0 919 617 A   ComponentHeadUpDisplay H25 1507     Coding2A00C0   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_HudNSEIKAU736 001012   ROD: EV_HudNSEIKAU736_AU73.rod   VCID: 336F05209ACF921EDE-8066
    Address A5Frt SensDrvAssist (R242)       Labels:* None   Part No SW4M0 907 217 D    HW4M0 907 217 A   ComponentBVS           H13 0042     Coding0407030600000401024023A0A50000B400F0C020C020   Shop #: WSC 55552 002 1048576   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002026   ROD: EV_BVSMLBevKOSTAAU736_AU73.rod   VCID: 2F67095076E7B6FEBA-807A
    2 Faults Found:1123600 predictive route data           B1630 02 [008] - Signal Failure          Intermittent Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency7                    Reset counter38                    Mileage110300 km                    Date2020.09.28                    Time18:36:42
                        Control Module temperature
    24 °C                    Voltage terminal 1514.50 V
    1123601
    predictive route data           B1630 02 [008] - Signal Failure          Intermittent Confirmed Tested Since Memory Clear             Freeze Frame:                    Fault Status00000001                    Fault Priority6                    Fault Frequency14                    Reset counter41                    Mileage110293 km                    Date2020.09.28                    Time16:19:56
    33 °C                    Voltage terminal 1514.40 V
    -------------------------------------------------------------------------------Address ACReductant Control (J880)       Labels4M0-907-355.clb   Part No SW4M0 907 355     HW4M0 907 355    ComponentSCR-Stg-G3H10 0003     ASAM DatasetEV_RDCMINERGAU736 005009   RODEV_RDCMINERGAU736_AU49.rod   VCID6ED9D454B16DFFF6F1-803A
    No fault code found
    Address BBDoor Rear Drv (J388)       Labels:* None   Part No SW4M0 959 595 D    HW4M0 959 595 C   ComponentTSG HFS       005 0036     Serial number0000155453763    Coding004F98000001000000003080   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_DCU2RearDriveMAXHCONT 001005   ROD: EV_DCU2RearDriveMAXHCONT_AU49.rod   VCID: 3F875910A687467E2A-806A
    Address BCDoor Rear Pass (J389)       Labels:* None   Part No SW4M0 959 595 D    HW4M0 959 595 C   ComponentTSG HBFS      005 0036     Serial number0000155456515    Coding004F98000001000000003080   Shop #: WSC 31414 790 00001   ASAM Dataset: EV_DCU2RearPasseMAXHCONT 001005   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod   VCID: 3F875910A687467E2A-806A
    Address D6Light Ctrl Left 2Interface not compatible.Please upgrade to a current Ross-Tech interface.
    Address D7Light Ctrl Right 2Interface not compatible.Please upgrade to a current Ross-Tech interface.
    End-------------------------(Elapsed Time06:08)--------------------------
  2. Re: Q7 4M Coolant fan control circuit fault, only start with jump starter
    Jan 2018
    Warsaw
    65 Post(s)
    Have you coded a new battery?
  3. Re: Q7 4M Coolant fan control circuit fault, only start with jump starter
    Aug 2016
    yes
  4. Re: Q7 4M Coolant fan control circuit fault, only start with jump starter
    Jan 2018
    Warsaw
    65 Post(s)
    If the car starts with jump starter it rather indicates a problem with the battery. Try to recharged the new battery. Perhaps also the new one was not charged sufficiently.
  5. Re: Q7 4M Coolant fan control circuit fault, only start with jump starter
    Jan 2018
    Warsaw
    65 Post(s)
    All these errors could be caused by low battery. Charge fully the new battery, delete errors and try to start the car. It happened to me also couple of times when the battery was low - many errors.
  6. Re: Q7 4M Coolant fan control circuit fault, only start with jump starter
    Aug 2016
    the battery is showing 12.8v when the car is switched off
  1. Replies: 16
    Last Post: 03-07-2022, 08:15 AM
  2. Replies: 3
    Last Post: 25-06-2020, 12:02 PM
  3. 5301 - Throttle Actuator Control Circuit- Fault ---PLEASE PLEASE HELP
    By yerfdog in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 10-04-2019, 07:05 PM
  4. Please Help ABS/ESP fault codes, fog & rev lights inop after jump start (may be ECU software problem)
    By ujlakigy in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-03-2018, 03:22 PM
  5. P0480 00 [040] Coolant fan Control Circuit 1 fault
    By crazy4alfa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-12-2013, 12:25 AM
