Hey everyone, wondering if anyone has had a similar experience I can learn from: drove my 2005 1.9 TDi SE Touran for about 25 minutes a couple days ago, parked up and spent 5 minutes out of the car. Got back in, turned the key and none of the dash lights came on (by dash lights I mean the EML light, the glow plug light, ABS, seat belts, that sort of thing). I could start the car fine, but it promptly cut out after 2 seconds.
Got towed to a garage near my home where it was left for the mechanic to look at. He was very unhelpful, but appreciate he is currently rammed with all the lockdown MOTs that have built up. He's saying the problem is with the instrument cluster, and the car is basically a write-off. One suggested option is to send off the dash (by that I'm guessing he means just the instrument cluster?) to a company that fixes them. I'm prepared to take the dash apart and send it off, if we're looking at a cost of under £200. I've heard of other people with similar problems, for whom it turned out to be a faulty ignition switch. Could this be the problem?
I had a friend run his VCDS laptop on the car, and I have a file of the codes (below). One of the ones that stood out was something along the lines of "engine start is blocked by immobilizer". What's the logical place to start here? Am I looking at getting the cluster sent off?
Also, the wife is fixated on the key fob. "Just change the battery in the key!" "Why haven't you changed the battery in the key?!" so as an aside, if someone can reassure me it's not going to be that simple I'd appreciate it. I've tried both the main key and also the spare. Both activate the remote locking, both have the same effect in the ignition.
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
VIN: WVGZZZ1TZ6******* License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 72
08-Auto HVAC -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
18-Aux. Heat -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0E2442731
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 67DD826C56F41E7274-8032
5 Faults Found:
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 96.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.55 V
Bin. Bits: 00001100
Temperature: 8.1∞C
Bin. Bits: 00110000
18049 - Please check DTC Memory of A/C Controller
P1641 - 000 -
Freeze Frame:
RPM: 1260 /min
Torque: 88.0 Nm
Speed: 19.0 km/h
Load: 23.9 %
Voltage: 14.14 V
Bin. Bits: 00001000
Temperature: 86.4∞C
(no units): 0.0
18263 - Powertrain Data Bus
P1855 - 000 - Software Version Monitoring
Freeze Frame:
RPM: 840 /min
Torque: 66.0 Nm
Speed: 6.0 km/h
Load: 0.0 %
Voltage: 13.76 V
Temperature: 19.8∞C
Temperature: 86.4∞C
Temperature: 64.8∞C
17978 - Engine Start Blocked by Immobilizer
P1570 - 000 - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.08 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 0.0
17949 - Fuel Pump Relay (J17)
P1541 - 000 - Open Circuit
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Bin. Bits: 0
(no units): 1.0
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 Q HW: 1K0 907 379 Q
Component: ESP FRONT MK60 0102
Revision: 00T12001
Coding: 0021190
VCID: 408F79F0131A094A95-8014
No fault code found.
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No: 1K0 820 047 DF
Component: Climatic PQ35 090 0505
Shop #: WSC 00000 000 00000
VCID: 6BD5FE5C4A1C3A1210-803E
1 Fault Found:
00819 - High Pressure Sensor (G65)
009 - Open or Short to Ground
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005072890
Coding: 00890F210004100000120C000000000000087B075C
VCID: 2A5B3B588566E31AAB-807E
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 01324
3 Faults Found:
00906 - Horn (H1)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 59
Mileage: 215075 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.10 V
OFF
ON
OFF
OFF
OFF
02071 - Local Databus
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Mileage: 215075 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.10 V
OFF
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 99
Mileage: 0 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.10 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0EKLLP
Coding: 0012338
VCID: 356118245CD8BCE236-8060
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AF HW: 1K0 953 549 AF
Component: Lenks‰ulenmodul 634 0070
Coding: 0000042
VCID: 76E3DF28015EF7FAFF-8022
Address 17: Instruments
Cannot be reached
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 P
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
VCID: 326B2338ADB6ABDA13-8066
5 Faults Found:
02251 - Heater Unit Locked
000 - - - Intermittent
00664 - Fuel gauge
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 7
Reset counter: 95
Mileage: 211386 km
Time Indication: 0
Date: 2000.00.00
Time: 24:59:05
01444 - Under-Voltage Shut-Off (Automatic)
Freeze Frame:
Fault Priority: 0
Fault Frequency: 7
Reset counter: 95
Mileage: 211386 km
Time Indication: 0
Date: 2000.00.00
Time: 24:59:05
01415 - Recirculating Pump (V55)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 0
Fault Frequency: 255
Reset counter: 63
Mileage: 210650 km
Time Indication: 0
Date: 2000.00.00
Time: 16:56:21
Freeze Frame:
OFF
Temperature: 9.0∞C
Temperature: 8.0∞C
01305 - Databus for Infotainment
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 241
Mileage: 209513 km
Time Indication: 0
Date: 2000.00.00
Time: 17:08:08
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001057130B89
Coding: 3D3F1340078003
1 Fault Found:
01207 - Control Module for Auxiliary Heater (J364)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 99
Mileage: 215075 km
Time Indication: 0
Date: 2000.00.00
Time: 00:04:43
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Part No: 1T0 920 962 A
Component: IMMO VDD 1012
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1T0 959 701 B
Component: Tuer-SG 024 2302
Coding: 0000692
VCID: 36631F2841DEB7FA3F-8062
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K2 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
VCID: 3365263C52ACA2D218-8066
2 Faults Found:
00750 - Warning Lamp
013 - Check DTC Memory - MIL ON
Freeze Frame:
Mileage: 5040 km
Temperature: 27.0∞C
Voltage: 12.10 V
Voltage: 11.90 V
00778 - Steering Angle Sensor (G85)
000 - -
Freeze Frame:
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 01C802087F2D8405485FC61010CC
VCID: 79F9D4143040988292-802C
Subsystem 5 - Part No: 1K0 947 291 F
Component: Innenraumueberw.009 4809
Coding: 00000000
Shop #: WSC 00000
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1T0 959 702 B
Coding: 0000692
VCID: 377D122C46D44EF224-8062
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 P
Component: Radio BVX 017 0023
Coding: 0040400
1 Fault Found:
00877 - Treble Speaker Rear Right (R16)
011 - Open Circuit
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 2F6D2A4CBE8486327C-807A
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306F2930A3BA99CA65-8064
End-------------------------(Elapsed Time: 01:47)--------------------------
