Thread: AGM battery coding
  1. AGM battery coding
    Mar 2007
    Brum
    Hi all,
    Just about to replace my car battery and looking at installing a Yuasa 9060 AGM rather than a Bosch or Varta one.
    When it comes to coding on the UDS protocol what manufacturer code gave folks used for Yuasa batteries?
    Thanks in advance
    Scottie.
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  2. Re: AGM battery coding
    Mar 2007
    Brum
    Just to update my previous question and for anyone else’s info.
    I went ahead and swapped the battery over and during the coding found that the car seems to accept Yuasa abbreviated to YUA.
    I matched the battery rating to the new battery which is now a 70ah rather than the previous 68ah oem battery. When looking up the serial number logged by the car VW have installed “1111111111” (ten 1s) as the original serial number so it doesn’t seem to really matter if you have a BEM code or not. I went with the numerical date prefixed with two 0s in the format “00ddmmyyyy” but could have just as easily changed the 1s to 2s or even just the first or last digit to something else. Car accepted these changes and everything seems fine after the necessary drive around the block to clear all of the fault lights on the dash.
  3. Re: AGM battery coding
    108 Post(s)
    1816 Post(s)
    Yuasa batteries are my favourite choice, excellent quality.
    1 1 0
  1. Does 2011 A3 need battery coding?
    By 31satara in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-07-2020, 06:20 PM
  2. Coding a new battery
    By 54A4Avant in forum VCDS - General Questions
    Last Post: 04-01-2018, 08:14 PM
  3. Question Help coding new battery
    By Darks in forum VCDS - Help Requests
    Last Post: 28-09-2017, 09:38 PM
  4. Battery coding
    By glh-ronin in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2016, 11:06 PM
  5. Please Help Battery coding
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2013, 07:42 AM
