Thread: Golf TDi DPF limp mode
Results 1 to 8 of 8
  1. Golf TDi DPF limp mode
    Oct 2019
    London
    Hi all,
    I've had the DPF light on my dash for the past week (I was meant to take it on the motorway to clear) but this morning the glow plug and engine management light also came on (glow plugs are flashing, the other 2 are solid), since these came on the car is now in limp mode.
    I took it to my local garage who confirmed the error code was "regeneration duration", he tried to clear it but was unable to do so. I was recommended to get the DPF removed and cleaned which will resolve the errors at a cost of 380 plus VAT.
    Is this correct and will this resolve the issues currently being experienced?
    Any advice would be much appreciated.
  2. Re: Golf TDi DPF limp mode
    Nov 2006
    Crewe, Cheshire
    43 Post(s)
    It sounds like the garage you used only has a generic code reader, there will almost certainly be multiple fault codes with the problem you have.
    Phone around & find someone who has VCDS & get it re-checked.
    As it is at the moment, the car won't regen while in limp mode & the DPF will get clogged beyond being salvagable.
    Have a look here :- http://www.vwaudiforum.co.uk/forum/showthread.php/5319-Vagcom-VCDS-User-Locations
    there may be someone local who will check it for you for beer money.
  3. Re: Golf TDi DPF limp mode
    Feb 2020
    Bradford
    29 Post(s)
    My advice would be to get to any road where you won't have to stop frequently for 10 mins plus and give it a good run at higher rpm even in low gear. I'd also try to get wynns (?) dpf cleaner available at tesco petrol stations if its permanently in limp mode then drive at highest rpm allowed by limp mode
    Its not guaranteed to work but certainly worth a shot.
  4. Re: Golf TDi DPF limp mode
    Oct 2019
    London
    Thanks for the response, I took it on the motorway and drove it at over 60mph @2200rpm for 10-15 minutes but that didn't resolve it.
  5. Re: Golf TDi DPF limp mode
    Oct 2019
    London
    Quote Originally Posted by philipharmes View Post
    Thanks, I've had a look but no one is close by - I'm in north west London.
  6. Re: Golf TDi DPF limp mode
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    As it is at the moment, the car won't regen while in limp mode & the DPF will get clogged beyond being salvageable.
    Limp mode can be a lot of things.
    Limp mode: What is it, what are the causes, and how to fix it for the Audi and VW TDI diesel turbo
    As suggested.
    You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing and check systems out.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  7. Re: Golf TDi DPF limp mode
    Nov 2006
    Crewe, Cheshire
    43 Post(s)
    Common cause is the throttle valve on the inlet sticking or the EGR jamming open.
    But VCDS really will be your best friend.
  8. Re: Golf TDi DPF limp mode
    Oct 2019
    London
    Quote Originally Posted by Keithuk View Post
    As suggested.
    Thanks everyone, i took it to someone with VCDS and they confirmed it was the DPF. Forced regen and the car is now fine!
  1. Please Help Golf mk6 limp mode
    By Xzashx in forum Golf MK6 - 2009 - 2013
    Last Post: 27-09-2019, 04:19 PM
  2. Question VW Golf GT TDI goes into limp mode
    By frednemm in forum Golf MK5 - 2004 - 2009
    Last Post: 09-07-2017, 01:47 AM
  3. Please Help Golf Mk5 1.9 TDI Limp Mode
    By Zeeshan Shafiq in forum Golf MK5 - 2004 - 2009
    Last Post: 22-01-2017, 04:06 PM
  4. Please Help golf 1.9 TDI 'limp mode'
    By dave_g1007 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-11-2010, 07:55 PM
  5. GOLF gt tdi cut-out limp mode
    By FLENG2008 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-01-2008, 03:55 PM
