Thread: V71 Fault Which Motor on Attached Diagram.
Results 1 to 10 of 14
  1. V71 Fault Which Motor on Attached Diagram.
    Dec 2016
    lincoln
    23 Post(s)
    Hello. Sorry for a similar post. I have attached a diagram with the 3 motors around the blower but unsure of which one the V71 fault points towards. Any input would be appreciated. Items 4,5 and 7 are all motors.20201026_161949.jpg
    Current Vehicles
    Passat B6 Estate 170PD (Bluefin Installed 200BHP) BMR Highline
    Aprilia RSV 1000 Factory
  2. Re: V71 Fault Which Motor on Attached Diagram.
    Dec 2016
    lincoln
    23 Post(s)
    Crasher or Mitch do you have any idea?
    Current Vehicles
  3. Re: V71 Fault Which Motor on Attached Diagram.
    44 Post(s)
    995 Post(s)
    The V71 is the inlet air recirculation flap motor.
    If you care about the future of the planet, read this and watch the video
    https://www.bosch.com/stories/synthetic-fuels
  4. Re: V71 Fault Which Motor on Attached Diagram.
    Dec 2016
    lincoln
    23 Post(s)
    Thanks Crasher. That's what I thought after pulling the fault from VCDS. What I cannot fathom though is which motor on the diagram it is. It's certainly a motor from the diagram as the noise is coming from behind the glove box (Removed). Th 3 motors on the diagram are listed as No 4 (Control motor for temp regulating flap V159), No 7 (Central flap position motor V426), No 6 (Servomotor for defrost flap V107). So as you can see the parts diagram from VW shows no specific motor called Air Recirc Flap Motor or any motor labelled V71.
    Current Vehicles
  5. Re: V71 Fault Which Motor on Attached Diagram.
    Apr 2014
    SW London / Surrey
    125 Post(s)
    Do you have a copy of diagram 820-022? Part 2 on there, next to 3 - 1K0907511D.
  6. Re: V71 Fault Which Motor on Attached Diagram.
    44 Post(s)
    995 Post(s)
    Private message me the reg or VIN and I will look it up.
  7. Re: V71 Fault Which Motor on Attached Diagram.
    Dec 2016
    lincoln
    23 Post(s)
    Hello. No I dont have that diagram. I have 867-090 which the VW garage gave me.
    Current Vehicles
  8. Re: V71 Fault Which Motor on Attached Diagram.
    Jan 2012
    Rustington, West Sussex UK
    7 Post(s)
    74 Post(s)
    Quote Originally Posted by Marshall1975 View Post
    The motors highlighted vary depending on which assembly you have (31). There are not 3 separate motors in this assembly just one of 3 possible versions.
    Mad Mitch
  9. Re: V71 Fault Which Motor on Attached Diagram.
    Dec 2016
    lincoln
    23 Post(s)
    Mitch thanks for the info. So the 4 motors that are listed on the parts diagram I attached are actually only just one then. Is confusing as each one one the diagram has a different name and function as well as a different V number.
    Current Vehicles
  10. Re: V71 Fault Which Motor on Attached Diagram.
    44 Post(s)
    995 Post(s)
    It is item 3 on page 820-024, as far as I can tell it is incorrectly described but if you buy the revised duct it comes with it. The motor on its own is now part number 2Q0 907 511 F and you must buy the lever kit 1K0 898 002 B which comes to 130.52 or the complete duct 1K2 820 304 B at 316.36 which is a big job to install.
  1. Error on roof shade. 1 fault found, attached.
    By larserso in forum Q7 - 4M Forum - 2016 -
    Last Post: 01-08-2020, 10:25 AM
  2. Question Diagram for Removing Air motor flap
    By audifab12 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-07-2014, 03:47 PM
  3. Heater fault - Actuator motor fan temperature flap fault
    By jackdaw1990 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-12-2013, 02:30 PM
  4. Replies: 9
    Last Post: 03-01-2012, 10:55 AM
  5. Bosch Starter Motor Diagram - Mk3 Golf
    By alexmcc in forum Golf MK3 - 1993 - 1999
    Last Post: 03-06-2007, 01:11 PM
