Thread: Really weird ignition issue.
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. Really weird ignition issue.
    Dec 2008
    Hi, itís been a while since I was on the forum. I picked up a caddy mk2 van recently and have been trying to sort out an ignition issue... I have searched online/Facebook model groups etc but havenít found much of an answer.
    It starts fine, really nicely in fact. But when you turn the key to the off position it doesnít stop until I remove the key from the ignition. I have replaced the ignition switch and the problem persists.
    Looked at an Elsa win wiring diagram and all wiring seems in order. I am at a loss as to how I should tackle this fault. I have a spare immobiliser coil and key but no barrel unfortunately. The only think I can think is that the barrel has some immobiliser bits inside of it that have stopped working? Can anyone help please? Iíd rather not open up my ecu to see if there is any damage as I think the problem is simpler...
  2. Re: Really weird ignition issue.
    Dec 2008
    Anyone?
  3. Re: Really weird ignition issue.
    Mar 2016
    Minervois, France
    46 Post(s)
    It sounds as if the connections on the switch are wrong, so that the ignition is being controlled by the "key in switch" contacts and something else - or nothing, is connected to the contact for the ignition.
    The + terminal on the switch from the battery should be marked 30, and the terminal for the ignition should be marked 15.
    Make sure terminal 30 is live all the time and terminla 15 is live only when you turn the key to the "on" position.
    Did this forum help you? Help make sure it's here next time! click here to make a suitable donation using PayPal and add your forum name .
    1996 A4 B5 Avant 1.8T 150 bhp code AEB automatic with 67,500 kms = 42,000 miles on 01/11/2020.
    VW T25 Camper, Alfa 33 1.4 ie, Alfa Sprint 1.5 QV, 2 Alfa 33's for parts.
  4. Re: Really weird ignition issue.
    Dec 2008
    Thank you for your help. I shall look at this in a few days. Fingers crossed!!!
  5. Re: Really weird ignition issue.
    Mar 2016
    Minervois, France
    46 Post(s)
    If that helps, don't just "like" my effort, send Stuart a few bob for the forum
  6. Re: Really weird ignition issue.
    Dec 2008
    Quote Originally Posted by FrenchAudi View Post
    Update on the problem... So Iíve made time to have a look this morning and terminal 30 is permanently live.
    15 is live when the key is turned on, however when I turn it off it is still live until I pull the key out. I think it can only be the barrel thatís making a difference but I have no idea how. I also tried this with a new ignition switch so I know that theyíre ok.
    Does anyone have any ideas on where to go now?
  7. Re: Really weird ignition issue.
    Mar 2016
    Minervois, France
    46 Post(s)
    Maybe the markings for the terminals are ambiguous - e.g. between two terminals, or just plain wrong.
    Look for a terminal which is live only when the key is in the "ignition" position.
  8. Re: Really weird ignition issue.
    Dec 2008
    10436FCE-0710-4E12-8888-717B28BE42DE.jpgI have pin S (SU on the diagram) and pin X with a supply with the ignition in the on position
    It’s been untouched by the previous owner and I have a mint condition spare loom from a breaker which is exactly the same regarding pin location. It’s extremely weird.
  9. Re: Really weird ignition issue.
    Mar 2016
    Minervois, France
    46 Post(s)
    The output from pin X operates the relay, whatever it is for, stuff that comes on with the ignition.
    SU looks like the "key in" output
    What do you have on pin 15 - a) with the key out? b) with the key in? c) with the key in "ignition on" position?
    Do the wire colours match the diagrams?
  10. Re: Really weird ignition issue.
    Dec 2008
    So pin 15
    a) without the key no supply.
    b) with the key in but not turned, no supply.
    c) key in and ignition on 12v
    however when I turn the key back to off (key still in the ignition) there is a 12v supply. This should be off I’m thinking so I’ve changed the relay out for 6 spares my mate has to see if it’s a relay issue, but no they all do the same thing.
    All the wire colours are exactly the same and in all the right pin locations.
  1. A weird Issue with my new B6
    By XLYC in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-06-2020, 01:39 AM
  2. A4 B6 Weird A/C Issue
    By rowdy-999 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-09-2018, 08:31 PM
  3. A3 TDI 2.0 8p weird starting issue
    By jimmynoshoes in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 06-09-2016, 12:45 PM
  4. Replies: 3
    Last Post: 15-12-2015, 09:04 PM
  5. Weird demister issue
    By butler2.8i in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-11-2011, 06:16 PM
