Thread: wireless phone charger ... hit or miss ?
  1. wireless phone charger ... hit or miss ?
    Sep 2020
    united kingdom
    Hi there just looking for some of your experience with the wireless charging. I am finding it works sometimes and other times just stops . I can put phone down and it will start, then driving down the road it can stop charging , I then pick phone up and place it down a few times and starts charging again . I do have a thin case on phone , but it is ok with my wireless charger at home
    I have also noticed a message saying something like, please remove other items from charging are or words to that effect , The phone is of course the only item in there .
    Just wondering if it is just no good with a case on at all , or there is an issue with mine, or it is just not great in general ? .
    Thank you for your time
    Regards
    Lee
  2. Re: wireless phone charger ... hit or miss ?
    Jun 2020
    Newcastle upon Tyne
    12 Post(s)
    I've had mine work instantly every time i put my phone on it (Galaxy s20+ 5g).
  3. Re: wireless phone charger ... hit or miss ?
    Jan 2013
    Northern Ireland
    32 Post(s)
    Yes, my Galaxy S20 charges consistently as well. It's in the Samsung case. I did discover that it won't charge unless the engine is running - ie if the ignition is on but the engine has not been started it won't charge.
    The message that you get about removing other objects means that it has detected something metallic (keys, for example) which can't be charged.
    From the manual:
    The factory-fitted Infotainment system will provide information about the start of the charging operation and, where applicable, about any foreign objects with metallic components such as coins, keys, etc. that are detected in the stowage compartment. Remove foreign objects immediately.
    If the mobile device has not been placed correctly or is too large, it cannot be detected or cannot be detected correctly. In certain circumstances, the system will then report that there is a foreign object in the stowage compartment. Correct positioning in the stowage compartment may rectify the fault.
    If you havent done so already, uou could maybe try charging it without the case?
  4. Re: wireless phone charger ... hit or miss ?
    Nov 2020
    Aylesbury, UK
    Perhaps the phone is moving around as you are driving? I have had that problem.
    Worse for me is that if I'm using wireless Apple CarPlay and wirelessly charging the phone will overheat after about an hour, which causes the phone to slow down, maps stop updating etc. Apparently it's not unique to this car. I've resorted to using wired charging!
  5. Re: wireless phone charger ... hit or miss ?
    Sep 2020
    united kingdom
    just a quick update, changed the phones case , and it works all good now, maybe some case material is better, that is all i can put it down too
  1. Wireless Charging/Advanced Phone Preparation
    By KAC in forum Passat - B8 Forum - 2015 -
    Last Post: 10-08-2021, 03:45 PM
  2. Phone getting very hot while in wireless charger
    By muumipeikko in forum Q7 - 4M Forum - 2016 -
    Last Post: 15-03-2018, 09:50 AM
  3. Question Has anyone actually got the QI charger to work with ANY phone ?
    By Lazyoaf in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-10-2016, 07:55 PM
  4. Audi Q7 Phone box with wireless charging
    By Diver Bryn in forum Q7 - 4M Forum - 2016 -
    Last Post: 25-05-2016, 10:16 PM
  5. Phone charger Grrrrrr
    By bigslope in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 11-01-2014, 10:43 PM
