Thread: 2.0 tdi 140 r32 bumper replacement
  1. 2.0 tdi 140 r32 bumper replacement
    Nov 2013
    west midlands
    Seen a car locally for breaking
    I need a rear bumper but this one is a 1.9 tdi 105 bhp
    Will the exhaust kit fit my car at all
    Donít mind cutting the middle pipe if need be
    Anyone know what the difference between the 2.0 140 and 1.9 105 exhaust conversion is
  2. Re: 2.0 tdi 140 r32 bumper replacement
    Apr 2014
    SW London / Surrey
    125 Post(s)
    I remain very confused about what you're trying to do from the other thread and this one. I think you showed that your current exhaust on the ramp at MOT has the downward pointing, behind the bumper tips.
    Did you get a bumper with the cut out for straight tips, and are now looking far an exhaust that will fit there?
    Or have you not yet got bumper, or exhaust, etc and are thinking of taking both from this other car?
    To answer your question, I think the 1.9 (assuming it is BLS or BXE engine) has a 50mm exhaust pipe, while you have 55mm. Looking at replacement parts it looks like they take the same path, so if you take get some form of adapter in the clamp just before the rear box and assuming it doesn't mess with back pressure too much could well work.
  3. Re: 2.0 tdi 140 r32 bumper replacement
    Nov 2013
    west midlands
    Ok thanks this is a different type of bumper would you believe lol the 140 170 and r32 are all different
  4. Re: 2.0 tdi 140 r32 bumper replacement
    Nov 2013
    west midlands
    I have the exhaust and the sleeve measures 57mm ish so maybe it will fit
    The exhaust does get bigger just before the clamp so maybe it was designed for a 2.0 after all
    Will let you all know next week
  5. Re: 2.0 tdi 140 r32 bumper replacement
    Nov 2013
    west midlands
    I could take the end part off or use the whole lot
    Iíll fit the bumper and take the exhaust in the car and try borrow a ramp for an hour
  6. Re: 2.0 tdi 140 r32 bumper replacement
    Apr 2014
    SW London / Surrey
    125 Post(s)
    Isn't there a big, boxy bit missing from that?
  7. Re: 2.0 tdi 140 r32 bumper replacement
    Nov 2013
    west midlands
    Itís a conversion so most look like that online
    Mine doesnít have a box part in the middle like the 170 anyway
  8. Re: 2.0 tdi 140 r32 bumper replacement
    Nov 2013
    west midlands
    Just the exhaust to do
    The bits where they join go to 55mm and are 50mm in the middle
    May cut at the back or more in the middle see how it goes
  9. Re: 2.0 tdi 140 r32 bumper replacement
    Nov 2013
    west midlands
    All the mounts are in the same place between the 1.9tdi and the 2.0
    I didnít have to adjust or cut anything
  1. A/C Condensor replacement - bumper off or not ?
    By ihs61 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-06-2020, 10:06 PM
  2. Question Replacement Front Bumper
    By ajay_vad in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-02-2017, 12:09 PM
  3. Front bumper replacement
    By johndeere2130 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-03-2013, 10:21 AM
  4. Front Bumper replacement?????
    By Andy N.I in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-03-2008, 07:25 PM
  5. rear bumper replacement
    By zx6r scotty in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-06-2007, 12:08 AM
