Thread: Audi A4 1.9 TDI 2005 - Advice needed please
  1. Audi A4 1.9 TDI 2005 - Advice needed please
    Oct 2020
    Rugby, Warwickshire
    HI all
    I have a Audi A4 1.9 TDI 2005 , and would like some advice please with issues im having .
    Mileage 146K
    Basically appx 1 year ago noticed the water level in the expansion tank was low , so i topped it up and thought nothing of it . I have owned the car for 5+ years and have never ever needed to top the water or oil in between services . Its been a amazing car .
    Then a month later the coolant light came on and i had to top the coolant up again . It seemed strange , i got the car checked out and no mechanic could find any visible leak . I have changed the cap and expansion bottle to rule them out. Also, I have noticed that even after not using the car for a day, when I remove the coolant cap, there is a lot of pressure in the system.
    Anyway fast forward I've been laboring on with it , and now i have to top up every other day .
    Also now today i started the car this morning and it ran really rough . i gave it a rev and eventually it revved up and billowed a big white cloud of smoke .
    Now emission sensor light is on and car is in limp mode permanently .
    Any ideas what issue i might have ??
  2. Re: Audi A4 1.9 TDI 2005 - Advice needed please
    Mar 2018
    GB
    19 Post(s)
    Get a sniff test done, usually if coolant is leaking you can see the residue on the joints or unions, from what you're describing it could be a head gasket or a cracked block, but that test will confirm an issue, basically it changes colour if it detects oil or exhaust gases. Gives you a better clue at least and shouldn't cost a fortune.
    Sent from my SM-G965U using Tapatalk
  3. Re: Audi A4 1.9 TDI 2005 - Advice needed please
    Oct 2020
    Rugby, Warwickshire
    Many thanks for your message. I think you're right in that it is a head gasket or cracked block. I've got a mechanic coming to look at it on the weekend. Hopefully should get it sorted
  4. Re: Audi A4 1.9 TDI 2005 - Advice needed please
    Jan 2009
    Birmingham
    35 Post(s)
    Get the EGR cooler checked that could be leaking i don't think it could be cracked block or head gasket but you never know is the engine code BRB.
  5. Re: Audi A4 1.9 TDI 2005 - Advice needed please
    Jan 2009
    Nuneaton England
    6 Post(s)
    Quote Originally Posted by munnauk View Post
    Any news on the fault?
  1. Audi A3 2.0 tdi 2005 dsg bkd turbo problem help needed please
    By RevoA3Audi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-08-2017, 01:19 PM
  2. Pondering a 2005 2.0 FSI SE Quick advice needed pls.
    By stonesfan in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-10-2014, 11:55 AM
  3. 2005 A4 Engine swap disaster. Advice needed please
    By podge999 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-09-2011, 08:27 PM
  4. Question Retrospective Satnav Audi A6 2005 - Help Needed
    By gasc2188 in forum In Car Entertainment
    Last Post: 04-03-2009, 10:56 PM
  5. Golf 2005 plate oil light has come on advice needed
    By verachion in forum Golf MK5 - 2004 - 2009
    Last Post: 13-08-2008, 12:18 PM
