Thread: Video input to MMI
  1. Video input to MMI
    May 2020
    Estonia
    Hi
    I own a 2009 C6, which has MMI 3G high, navigation, cd changer and dvd player+2 sd card slots and AMI connector in the glove box. It is also worth to mention that I have rear view camera but not the tv tuner.
    I want to add video input to my original MMI, so that I could mirror waze from my phone. Can anybody know what would be the best way to do it? I would like to avoid aftermarket MMI solutions if possible.
    I cannot use AMI connection for that purpose. I tried with RCA to AMI connector- MMI recognizes that connection has been made but displays "not supported". When I was searching for RCA to AMI cable, I was warned by the audi dealership that it is not compatible with my car. I presume that AMI in my car can only used as an aux for music.
    I know that since I have RVC I should have FBAS. I have also stumbled upon a potential solution where OEM tv tuner is installed and RCA input added to the red connector. However it seems somewhat redundant to draw the wires from the booth to the front. Is there some way I could replace my dvd player unit in glove box with a RCA A/V input?
    I have surfed through different forums and different threads but have not found an answer.
  2. Re: Video input to MMI
    Jul 2013
    76 Post(s)
    I have retrofitted the TV tuner into my car this not a hard job to do, I made the loom up and the Video/ antenna leads myself but you could just buy them from kuftec.
    Running the wiring to the glove box is not a difficult job.
    Do you have an Avant or saloon as the antenna modules for the saloon were a pain to get the right ones as there was a change in 2008.
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Video input to MMI
    May 2020
    Estonia
    It is an Avant
  1. Video Input to MMI
    By Angus99 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-02-2013, 08:03 PM
  2. Replies: 0
    Last Post: 20-04-2011, 02:46 PM
  3. Aux Video Input
    By mohammadrasool in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-02-2010, 02:37 PM
  4. Video Input on A6 MMI
    By lakerisers in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 16-01-2009, 06:15 PM
  5. Video input to SatNav
    By hidnmine in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-11-2008, 07:36 PM
