Thread: Little water leak in tail but not from lamp ?
  1. Little water leak in tail but not from lamp ?
    Dec 2019
    Eda
    Hello. We have rainy days in my country and I noticed that I have some water on wiring from rear right lamp and the lamp itself My first thought was that the tailight seal is the problem. So I replaced it with butyl tape and the water was still leaking. Today I notcied that the water shows above the lamp. So lamp seal is 100% good. It isn't big leak. After two days there's not much water, but any water is bad when it is on wiring.
    Here you can see some droplets above the lamp
    How to fix it and search the cause ? After visit on car wash I don't see any leak. Removing upholstery also don't help because this water is between two plates. Maybe someone faces similar issue before ?
    I thought is could be antenna gasket but headliner is dry from what I see. I also thought about rubber wiring cover but it looks good. Can the water let go to the car thorugh hinges ?
  2. Re: Little water leak in tail but not from lamp ?
    Dec 2019
    Eda
    I think I found the cause. Under the trunk seal there's welding of two sheets. And I find that there's very little hole. I glued it with silicone inside and outside. Now waiting for big rain and I will see result.
  1. Water in boot tail lid inner lights 2008 b8
    By aj4u in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-12-2019, 03:08 PM
  2. Please Help Troubleshooting on my first car - A4 Avant estate 1999 - A-frame water leak, footwell leak etc.
    By damn_seagulls in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2014, 10:02 PM
  3. Audi a4 avant 2004 n/s/r tail lamp needed
    By domy123 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-04-2010, 10:10 PM
  4. temp gauge water leak, fuel leak all sorted
    By a6rom in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-02-2009, 12:44 PM
  5. Please Help Touran Rear Tail Lamp
    By skinnedrabbit in forum Touran - Sharan - Caravelle
    Last Post: 14-06-2008, 12:55 PM
