Thread: 2002 LT28 TDI starter motor not turning over engine
  1. 2002 LT28 TDI starter motor not turning over engine
    Oct 2020
    Wrexham
    Hi I moved my LT28 yesterday using a non chipped key having it in reverse and turning it over on the key. This worked. A while later tried to move it again though the key turned the starter motor did nothing not even dimmed the dash lights. Is there a relay between the ignition switch and the starter that may have failed or a fuse? If so where can it be found?
  2. Re: 2002 LT28 TDI starter motor not turning over engine
    Apr 2021
    England
    I have just had the same problem with my LT28 1991 - bought it on Friday! Did you ever find out what it was?
  1. Starter Motor LT35 2.5 TDi 2004 109 AVR engine
    By GeorgeOK in forum The Commercial Range
    Last Post: 07-12-2013, 09:22 PM
  2. Starter motor not turning
    By dj_adam in forum Golf MK2 - 1984 - 1992
    Last Post: 24-11-2010, 08:42 PM
  3. Please Help Starter Motor B5.5 V6 TDI - AFB engine
    By Col in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-04-2009, 04:56 PM
  4. Please Help engine won't turn - starter motor?
    By rhian in forum Golf MK3 - 1993 - 1999
    Last Post: 13-07-2008, 12:59 PM
