Thread: A3 Bkd dsg 2006 fuel in oil help
  1. A3 Bkd dsg 2006 fuel in oil help
    Oct 2020
    Uk
    Hello I know its my first post, so I hope its OK
    I have a 2.0 tdi bkd dsg 2006
    And over last couple of days it's used more diesel than normal
    Having checked the oil it's definitely more than it was at oil Change 4 weeks ago
    Today I noticed oil around the filling cap so replaced with a brand new one
    Anyway after a run checked no oil around the cap but its smoking from the cap
    I smelt it, diesel
    So the garage thinks injector seals
    But I think tandam pump
    Both expensive jobs but is there anyway to tell them apart.
    Only symptoms car jerks from stationary sometimes, using more fuel then normal
    Seems to be oil/diesel below the tandam sat on top of gearbox but definitely not coming from gearbox
  2. Re: A3 Bkd dsg 2006 fuel in oil help
    1841 Post(s)
    In my experience the Tandem pump causes oil in the fuel and this is easy to check for by opening up the fuel filter. On the BKD it can be damage to the head seating face of the injector and this has to be gently re-cut... what possessed them to not fit a copper fire ring is beyond me.
  3. Re: A3 Bkd dsg 2006 fuel in oil help
    Feb 2022
    South Africa
    Hi guys
    Trust you are well.
    I have a BKD 2.0TDI
    Yesterday whilst on my way home, my vehicle stalled whilst driving. I was lucky enough as this occurred whilst in my driveway. Did a diagnostic with VCDS and did not pick up any fault codes, the car refused to start. I did a bit of digging and opened up the fuel filter housing, it looked quite dirty, so I removed the tank feed line from the fuel filter I primed the fuel into a container and noticed a lot of soot. I then put the feed line back, bolted down the filter housing and then removed the pipe that feeds the Tandem pump. I tried starting the vehicle & tried priming, but no fuel was coming out of the housing.
    Will the soot from the return line go back into the tank?
    What is an acceptable amount of soot in the fuel?
    Could a faulty fuel filter valve on the housing cause an issue of this sort?
    Prior to this, the vehicle ran quite well. But for the last month upon take off at certain times only, the car stutters and feels like it just wants to switch off. Once the car has momentum, it has full power and doesn't seem to have any issues.
    Many thanks
  1. A6 Allroad 2006 intermittent fuel gauge fault
    By mhobson in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-09-2016, 08:46 AM
  2. 2006 Golf 1.9 TDI - sudden increase in fuel consumption - Help!
    By chrisfiss in forum Golf MK5 - 2004 - 2009
    Last Post: 20-11-2013, 08:13 PM
  3. Help.. Removing 3l Quattro 2006 c6 fuel pump
    By Rallyevo3 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 01-12-2012, 01:22 PM
  4. Please Help Oily fuel problem - 2006 2.0 TDI 170
    By stigish in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-08-2011, 12:36 AM
  5. 2006 Jetta TDI 1.9 Fuel Filter Questions
    By miketodds in forum Jetta MK3 - 2005 - 2013
    Last Post: 18-01-2010, 01:40 AM
