Thread: Rns 315
Results 1 to 10 of 17
  1. Rns 315
    Nov 2013
    west midlands
    Is there a cable to buy to make a line out on this model to run a subwoofer
    If not is it splice into the speaker cables only ?
  2. Re: Rns 315
    Apr 2014
    SW London / Surrey
    125 Post(s)
    There aren't any line level outputs or VW adapters to get them. Others use either an amp that takes hi-level (ie speaker) inputs, or an extra widget to get the RCAs to feed amp.
  3. Re: Rns 315
    Nov 2013
    west midlands
    Thanks has anyone used a bass controller connected to a line converter
    Are the speakers possible to switch to line out in vagcom it is this not possible
  4. Re: Rns 315
    Nov 2013
    west midlands
    Hi all brought the above radio with code plugged it in and itís asked for the code
    Put it in and it says code invalid but letís me in the stereo anyway
    Is this a glitch everything seems to work ok
  5. Re: Rns 315
    Nov 2013
    west midlands
    I didnít realise the microphone connector is different to my old stereo ( added cost)
    Is there an adaptor available to use my old one itís a normal headphone socket plug
  6. Re: Rns 315
    Apr 2014
    SW London / Surrey
    125 Post(s)
    Do you mean a microphone for phone use, or the 3.5mm socket to plug something like an iPhone into to hear music?
    The pins are on the back for a latter, and a suitable socket / cable is one of these which plugs into one of the small 12-way connectors on the back of the radio: AUX Cable 3,5mm >> Quadlock 12pol for VW RNS310, RNS510 | eBay. You can get them with 3.5mm sockets that will snap into a spare / blanked button on the console, or with a 3.5mm plug to go straight into the iPhone, etc.
    If the old radio was a similar VAG one it should be a same. What was that?
    BTW, depending on the coding in the radio it may or may not come to life easily. If for example it has been told a CD changer (or emulator like the iPod widget) is connected it might not like a "plain" AUX input. VCDS or similar can get the coding right I think.
  7. Re: Rns 315
    Nov 2013
    west midlands
    Thanks all the microphone was different so had to replace
    I have brought a gps antenna but all the pics online show a Fabra connector I donít have one on mine any ideas what I do
  8. Re: Rns 315
    Apr 2014
    SW London / Surrey
    125 Post(s)
    That looks like it may be the right connector, except that the blue locking surround has been lost somehow. I'd be suspicious of why that might be, but if it all works then fine.
    If the antenna will push on I'd see if something like a stick-on cable tie could be positioned to keep it in place, although once safely mounted in the dash there shoild be nothing to pull it iut.
  9. Re: Rns 315
    Nov 2013
    west midlands
    Yer I wondered that no way to get a new connector it doesnít seem to clip on very well
  10. Re: Rns 315
    Apr 2014
    SW London / Surrey
    125 Post(s)
    If you look for "pcb fakra" on eBay you might find something you can punch the "electrical" bits out of to get a plastic part to glue to radio.
