Thread: Beetle 2.0 Petrol Cambelt and water pump
  1. Beetle 2.0 Petrol Cambelt and water pump
    stourbridge,west midlands
    I have a 2 litre petrol (Automatic) 2005 beetle which requires a cambelt and water pump, it's well overdue (10 years )but has only covered around 47,000 miles. It's had one belt change in it's life and water pump (which I struggled to get the dealer to change) and as I remember they didn't change the tensioner, just the belt.. Half a job. Anyway, I need to get it done now as I've been putting it off long enough and just looking at water pumps. Could anyone recommend a decent brand to go for please ? I'm thinking INA but I know some have a plastic Impeller and I've been advised to steer clear of those. I may have had an FAI pump before on another car but not sure If they are the best.
    Also, Best quality belt kit ? Again, I'm thinking INA but open to suggestions ?
    I've also got to get the Camshaft sensor changed as recently it hasn't been starting well and more recently the engine management light has been on. I've scanned it with VCDS and found "Camshaft Position Sensor (G40) Signal too high P0343-35-10 - Intermittent"
    I've done a bit of research and it could be a failed cam seal leaking onto the sensor so I'll probably be looking for a cam seal also.
    The next thing is, Do I tackle the job myself ? Done a few belts but not for years and not on a 2 litre VW so confidence is a bit low but it doesn't seem too bad a job to do.
    Many thanks people.
    Matt.
  2. Re: Beetle 2.0 Petrol Cambelt and water pump
    1840 Post(s)
    As modern VAG cars go it is the simplest cam belt job since the Golf 2 16v; they were so easy compared to this modern crap it is daft... ones without power steering could be done in an hour and the water pump was not involved! I would suggest a genuine VAG cam belt kit and water pump but most of the aftermarket kits are excellent, too many to list but INA is OE, Schaefller Group, there is nothing better on the aftermarket Schaeffler Automotive Aftermarket
  3. Re: Beetle 2.0 Petrol Cambelt and water pump
    Cheers Crasher. I believe that INA are the same as you'd get from VW minus the branding but correct me if I'm wrong. I would rather use genuine but the cost puts me off seeing as though I'm not trade that's why I was looking into aftermarket.
    It does seem straight forward enough of a job so I may tackle it myself. Got plenty of tools to hand just need to grow a pair lol.
    Thanks again
    Matt.
  4. Re: Beetle 2.0 Petrol Cambelt and water pump
    1840 Post(s)
    The kits genuine are very affordable, £96.18 for the belt kit and £67 for the water pump... correctly fitted and bought from a VW dealer these have a two year parts and labour warranty.
  5. Re: Beetle 2.0 Petrol Cambelt and water pump
    That doesn't sound too bad as long as that's retail of course. I'm going to need a sensor anyway and would only fit genuine for that anyway. Not worth fitting a Mickey mouse one for that job.
    Matt.
  6. Re: Beetle 2.0 Petrol Cambelt and water pump
    1840 Post(s)
    Yes that is retail over the counter at a VW dealer including VAT. For years we have only fitted genuine cam belt kits with water pump and never had an issue, then I did mine on my 1.8T and the bloody water pump leaks! Not taking it to a Skoda dealer though, the spotty oiks they would throw at it were at nursery school when the car was built.
  7. Re: Beetle 2.0 Petrol Cambelt and water pump
    Hi Crasher. I got the parts today from VW As you suggested. One thing that worries me a bit is the water pump, as feared it has a plastic impeller. I questioned it and they said that is the latest type and can only get that one. If I want a metal impeller I'd need aftermarket. I've gone with genuine but should I be worried ? Many thanks
    Matt.
  8. Re: Beetle 2.0 Petrol Cambelt and water pump
    1840 Post(s)
    The plastic impeller problem is massively over hyped, I have not seen a case of failure in years.
  9. Re: Beetle 2.0 Petrol Cambelt and water pump
    Thanks for your reply Crasher, I appreciate your advice
    Matt.
  1. Cambelt and Water Pump change
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-09-2016, 05:39 PM
  2. Cambelt kit and water pump
    By 30vquattro in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-04-2011, 04:48 PM
  3. Question Water pump/Cambelt replacement
    By Mark Sommers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-07-2010, 08:28 AM
  4. Allroad V6 TDi water pump/cambelt - help
    By deansminis in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-10-2009, 01:23 PM
  5. Question How to tell is Cambelt and Water pump have been done?
    By tomjj in forum Golf MK5 - 2004 - 2009
    Last Post: 26-08-2008, 05:27 PM
