Thread: 2.0tdi 110kW DSG 6 Dq250 problem
  1. 2.0tdi 110kW DSG 6 Dq250 problem
    Sep 2020
    Croatia
    Hello everyone, i have a problem on my Golf mk7 2013 2.0tdi dsg, 6 months ago when i was driving in D normally car went into neutral and message on the screen appeared Press Brake, as soon as i press brake car goes back into drive, okay i continued my trip home, next morning i was about to go to work, when i turned on ignition there was chrismas tree, Tyre pressure, ESC, check engine... etc, car locked in P. I went to dealer they erased all of the errors(communication with transmission, door sensor, literally everything), since then car worked for 5 months, then again it happened last month, i contacted some people and they said they need to get new mehatronic unit and replace it. Now car works fine for 4 weeks already. Im not to happy to give 2000€ for new unit and still hope maybye there is some other solution and its not unit. HALP
  2. Re: 2.0tdi 110kW DSG 6 Dq250 problem
    1840 Post(s)
    We need a full fail code read report (preferably with VCDS) to be able to help you and please include the VIN.
  1. 2015 1.4 110kw 6speed manual clutch and reverse gear shifting problems
    By jamgolas in forum Passat - B8 Forum - 2015 -
    Last Post: 23-12-2019, 05:22 PM
  2. Eos 2.0tdi BMM problem
    By jonny_v in forum Eos
    Last Post: 17-04-2017, 03:07 PM
  3. Replies: 4
    Last Post: 18-05-2016, 01:11 PM
  4. Replies: 1
    Last Post: 16-05-2016, 09:52 AM
  5. Question A4 1.8T Quattro Sport 110kw??
    By olnmfc in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-03-2010, 07:32 AM
