Thread: wont rev no go
  1. wont rev no go
    Sep 2020
    ANGLESEY
    Thursday,24,September,2020,20:29:05:00009
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 20.4.2.0
    Data version: 20200730 DS317.0
    Ross-Tech: Home
    VIN: WVWZZZ3CZ8E102047 License Plate:
    Mileage: 209350km-130084mi Repair Order:
    Chassis Type: 3C (3C0)
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 72 76
    VIN: WVWZZZ3CZ8E102047 Mileage: 209350km-130084miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: Cannot be reached 1100
    76-Park Assist -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-018-BKP.clb
    Part No SW: 03G 906 018 FG HW: 03G 906 018 FG
    Component: R4 2.0l PPD1.5 G 0907
    Revision: --H45--- Serial number: VWZCZ000000000
    Coding: 0000072
    Shop #: WSC 05314 000 00000
    VCID: 6FED66BB7E9D05FEFA-803A
    1 Fault Found:
    000551 - Throttle Pedal Position Sensor (G79)
    P0227 - 007 - Signal too Low
    Freeze Frame:
    Fault Status: 11100010
    Fault Priority: 4
    Fault Frequency: 19
    Reset counter: 40
    Mileage: 209354 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 04:46:32
    Freeze Frame:
    RPM: 800 /min
    Torque: 16.0 Nm
    Speed: 0.0 km/h
    0.00 %
    Voltage: 13.11 V
    Torque: 1016.0 Nm
    Bin. Bits: 01010000
    Readiness: N/A
    Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
    Part No SW: 3C0 614 109 C HW: 3C0 614 109 C
    Component: J104 C4 440 V1 0003
    Revision: --020--- Serial number: 00000776029026
    Coding: 0001291
    Shop #: WSC 05311 000 00000
    VCID: 1E336B7FC9B7DC7601-804A
    No fault code found.
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No SW: 1K0 820 047 HM HW: 1K0 820 047 HM
    Component: Climatic PQ35 142 1111
    Revision: 00142031 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    VCID: 76E353DF01C7343639-8022
    Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
    Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
    Component: Bordnetz-SG H54 2202
    Revision: 00H54000 Serial number: 01000007654796
    Coding: E1800F0700041A00470A00000F00000000085D435C00010000 0000000000
    Shop #: WSC 05124 000 00000
    VCID: 71E960C368A9130EEC-8024
    Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer 041007 022 0601
    Coding: 00046997
    Shop #: WSC 05124
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 181007 046 0204
    Coding: 00208933
    Shop #: WSC 05124
    Address 15: Airbags Labels: 3C0-909-605.lbl
    Part No SW: 3C0 909 605 M HW: 3C0 909 605 M
    Component: 0C AIRBAG VW8 032 2522
    Revision: 12032000 Serial number: 003B1PLJX51X
    Coding: 0012355
    VCID: 306FA5C7A3235A06A3-8064
    Subsystem 1 - Serial number: 6332MSME18074606
    Subsystem 2 - Serial number: 6342MSME176A4A12
    Subsystem 3 - Serial number: 6351HTS6L4I8HKT6
    Subsystem 4 - Serial number: 6361HTS6L4IOPAS6
    Subsystem 5 - Serial number: 00000000000000000
    Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel Labels: 3C0-953-549-SW20.lbl
    Part No SW: 3C0 953 549 L HW: 3C0 953 549 L
    Component: Lenksäulenmodul 006 0010
    Revision: 00006000 Serial number: 3C5953507BK
    Coding: 0000013
    VCID: 356194D35C417F2EF0-8060
    Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
    Part No SW: 3C0 920 960 N HW: 3C0 920 960 N
    Component: KOMBIINSTRUMENT VD1 1216
    Revision: V0002000 Serial number: 00000000000000
    Coding: 0007405
    VCID: 2E53BBBFB9174CF6B1-807A
    1 Fault Found:
    00562 - Sensor for Oil Level/Temperature (G266)
    010 - Open or Short to Plus
    Freeze Frame:
    Fault Status: 01101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 209354 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:21:57
    Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
    Part No SW: 3C0 907 530 E HW: 3C0 907 951
    Component: J533__Gateway H10 0080
    Revision: H10 Serial number: 1200P07A180452
    Coding: F9807F0E0002021003
    VCID: 23455A8BE2D5F19E2E-8076
    2 Faults Found:
    01305 - Databus for Infotainment
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 209354 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:22:00
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 209354 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 08:22:03
    Address 25: Immobilizer Labels: 3C0-959-433-25.clb
    Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
    Component: IMMO 042 0383
    Revision: 00042000 Serial number: VWZCZ000000000
    Shop #: WSC 131071 1023 2097151
    VCID: 397998E370599B4E14-806C
    Subsystem 1 - Part No: 3C0 905 861 G
    Component: ELV 027 0380
    3C0905861G ELV 027 0380
    Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
    Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
    Component: J386 TUER-SG FT 1132
    Revision: 32008001 Serial number: 00000118079015
    Coding: 0000693
    VCID: 3B7582EB7A65A95E06-806E
    1 Fault Found:
    00932 - Electric Window Motor; Drivers Side (V147)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 5
    Mileage: 209354 km
    Time Indication: 0
    Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
    Part No: 1K2 909 144 M
    Component: EPS_ZFLS Kl.134 H08 1901
    Shop #: WSC 02069 000 90108
    VCID: 366393DF41477436F9-8062
    Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
    Component: KSG PQ46 ELV 042 0472
    Coding: 01910A0001860E763004941570085FCE107CA0
    Subsystem 1 - Part No: 1K0 951 605 D
    Component: LIN BACKUP HORN H07 9001
    Subsystem 2 - Part No: 3C0 951 171 C
    Component: Neigungssensor 004 0611
    Subsystem 3 - Part No: 3C0 951 171 C
    Component: Innenraumueberw.004 0611
    Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
    Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
    Component: J387 TUER-SG BT 1132
    Revision: 32008001 Serial number: 00000536579009
    Coding: 0000692
    VCID: 3C7781F77F6BAE660F-8068
    Address 53: Parking Brake Labels: 5N0-907-801.clb
    Part No SW: 3C0 907 801 J HW: 3C0 907 801 J
    Component: J540 EPB3 VW-09393 0009
    Revision: 008 Serial number: 00000000209248
    Coding: 0000056
    Shop #: WSC 80093 222 69422
    VCID: 295948A380F92BCE64-807C
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1118
    Revision: 11006001 Serial number: 00000002493441
    Coding: 0000144
    VCID: 3D718CF36471A76E38-8068
    Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
    Part No SW: 1K0 959 704 P HW: 1K0 959 794 G
    Component: J389 TUER-SG HR 1118
    Revision: 11006001 Serial number: 00000002497664
    Coding: 0000144
    VCID: 3E738BFF6977BC7621-806A
    Address 76: Park Assist Labels: 3C0-919-283.lbl
    Part No SW: 3C0 919 283 C HW: 3C0 919 283 C
    Component: Parkhilfe 8-Kan 004 0013
    Revision: 00004000 Serial number: 90640728303588
    Coding: 0000014
    End-------------------------(Elapsed Time: 02:09)--------------------------
    changed pedal cleaned egr
  2. Re: wont rev no go
    Sep 2020
    ANGLESEY
    ALL sorted now thanks
  1. Please Help car wont rev.. :(
    By plumo in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-08-2013, 02:38 AM
  2. SAT DVD Wont Gon In
    By quattrodaddy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-07-2011, 02:46 PM
  3. Boot Wont Open& Rear Wiper wont work...HelPPP
    By mohammedpatel in forum Golf MK5 - 2004 - 2009
    Last Post: 17-09-2009, 05:54 PM
  4. Boot wont open! fuel flap wont lock!
    By 2rabbits in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-03-2009, 02:28 PM
  5. 80 tdi wont rev
    By ch1ll1 in forum 80 - 90
    Last Post: 06-05-2007, 03:33 PM
