Thread: Bern offered a car. Need help to decide 😂
Results 1 to 10 of 13
  1. Bern offered a car. Need help to decide 😂
    Sep 2020
    Norway
    OHello. I have Been offered to buy a very cheap 2006 Audi a6 2.0 TDi automatic. But it has some problems that the mechanics didnt find out of. Glow plug indicator in dash is on all the time, the car is shaking at idle and if you drive it hard or push it, it goes in limp mode. Any suggestions what this might be? The message from the mechanic was, maybe need to change turbo, maybe need to change transmission or bad flywheel. The car is in daily use
  2. Re: Bern offered a car. Need help to decide 😂
    bristol
    10 Post(s)
    Walk away unless its free. If its the autobox its not worth spending the money at that age.
  3. Re: Bern offered a car. Need help to decide 😂
    Sep 2020
    Norway
    Quote Originally Posted by quattrogary View Post
    Ok, Hmm. The car costs 3500 norwegian kroner. Thats right under 300£. If i send it to the wreckers i Get 250 back instantly. Would be a cheap car to use to and from work AS long AS its working. ��. But not worth fixing i guess
  4. Re: Bern offered a car. Need help to decide 😂
    Nov 2018
    Tamworth
    22 Post(s)
    My gut reaction is to run away.
    It just sounds like a money pit - try changing this, then that, then something else in the hope that one of them might cure it.
    IMHO there's nothing more frustrating than a car that's not reliable and attacks your wallet at the same time.
    I'd be surprised if it'll get you to work and back most of the time.
    Andy.
  5. Re: Bern offered a car. Need help to decide 😂
    1840 Post(s)
    Start with a code read and see what comes up, then we can try and help BUT you could throw huge money at it and lose it all... that’s modern cars for you; extremely environmentally friendly-not.
  6. Re: Bern offered a car. Need help to decide 😂
    Apr 2014
    SW London / Surrey
    10 Post(s)
    168 Post(s)
    It sounds like it could be fuel, injector or timing related. If you got a VCDS reader you would be able to read many error codes and performance data. If you have time and inclination to do that and disposal of a car that doesn't tell youvan easy fix is no problrm Id take it
  7. Re: Bern offered a car. Need help to decide 😂
    Sep 2020
    Norway
    Hello again so i just bought this car and just got home. No problems when i drove it home. The glow plug indicator turned of when car started. Did not Shake at idle. I didnt push it very much when driving home, so it didnt go into limp mode. It felt like a genuin good car. Im sure the problems will show later, so i will ask on this forum when the problems show up
  8. Re: Bern offered a car. Need help to decide 😂
    Sep 2020
    Norway
    I have taken the car for a spin now and have noticed some things, that may be normal But i dont know. Its My first automatic car i own. It seems that i need abit of rpm to Get it going when taking of in drive and revers. Normal? My parents have a 06 a6 2.7tdi auto. And that car is very different to take off with.
    When im driving it, it shifts good and smooth. But the car seems slow, not much power for 140hp. Are They generaly slow? Or is there some problems here?
  9. Re: Bern offered a car. Need help to decide 😂
    1840 Post(s)
    I imagine it is a CVT box and these can feel odd in the take up (especially early versions) rather like having a “high stall” torque converter on a conventional automatic.
  10. Re: Bern offered a car. Need help to decide 😂
    Sep 2020
    Norway
    Drove it to work today so i could test it it goes into limp mode if i try to accelerate up a hill for example. Seems like it does not like to Get pushed. Boost Pressure problem?
    If i drive it very carefully it works very nice. No problems.
  1. Bought a a4 b6 2.5tdi quattro so I def needed to join 😂
    By milleme in forum New Member Introductions
    Last Post: 29-12-2016, 10:13 AM
  2. 1.4 TSI ACT now offered in the Audi A3 for £2k less
    By J400uk in forum Golf MK7 - 2013 - 2019
    Last Post: 22-04-2014, 04:39 PM
  3. I Just Got Offered
    By DSG4ME in forum Chat - Adult Banter - Sponsored by Audi VW Specialist Centre
    Last Post: 04-10-2011, 11:59 AM
  4. VAG COM help offered
    By audipersempre in forum VCDS - General Questions
    Last Post: 05-03-2008, 03:03 PM
