Thread: 2019 Disabling Stop Start ?
  1. 2019 Disabling Stop Start ?
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    My brother in law has just bought a 2019 VRS.
    He loves everything apart from the Stop Start which he hates.
    What is the easiest way to disable permanently?
    I have VCDS .
    I did it on my Audi a long time ago by altering some parameter concerning air con , if I remember correctly.
    I'm sure someone out there has just the setting I need,
    Please share.
  2. Re: 2019 Disabling Stop Start ?
    Aug 2016
    South Lakes, UK
    29 Post(s)
    Can you change the voltage it kicks in at. I've just ordered a Octavia and hoping this will be the first modification.
    Sent from my ELE-L29 using Tapatalk
  3. Re: 2019 Disabling Stop Start ?
    May 2012
    Everywhere
    308 Post(s)
    There is a connector on the negative terminal ?
  4. Re: 2019 Disabling Stop Start ?
    Feb 2004
    Yorkshire
    46 Post(s)
    I have Skoda Superb with stop/start, it does not bother me really, if like mine the car is a DSG then you can control it with the brake pedal... or tur it off with a switch on the console if you dont want it..
    With a DSG it works on the pressure on the brake pedal... if you come to a stop and know you may be a while then I just let it stop. once, for instance the lights change I lift the pedal slightly and the car starts ready to move off... if on the other hand I know I am only stopping for a short while, once you come to a stop just lift the pressure on the brake pedal slightly and the engine keeps running... takes some getting used to but once mastered it is easy to control and only needs a slight lift of pressure..
    Stuart l VWAudi Forum
    VW Audi Forum - Founder
    Member of BMW Car Club GB
    Ways to support the website
  1. Question Start/stop disabling via VCDS
    By Stevie Wonder in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 29-06-2020, 06:44 PM
  2. Question Disabling Start/Stop
    By Nartey in forum VCDS - Help Requests
    Last Post: 31-05-2019, 04:33 PM
  3. Start/stop system disabling and LED reversing
    By Audidua in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 08-01-2019, 11:08 PM
  4. Disabling the Start/Stop function
    By AllotmentChap in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 20-04-2015, 02:05 PM
  5. How does Start/Stop interplay with Stop-Go on the ACC?
    By Timothy Nathan in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 09-02-2012, 11:40 AM
