Thread: Instrument cluster - lights on warning light
  1. Instrument cluster - lights on warning light
    Sep 2020
    Saham, England
    i have a Golf, and I am sure it had a green lights on light. Now it does not work, so I don’t know of the lights are on (not at night of course, I mean the DRLs are alway on, but as light fades the headlights automatically come on). Now, the headlights work fine, but the green notification light does not. I tried recoding so the green light comes on with DRLs, but. The green lights still doesn’t come on. I have had the cluster out, and clearly it does not have conventional bulbs, and must have LEDs. Has anyone else had this problem, and have they successfully fixed it or soldered in a new LED?
  2. Re: Instrument cluster - lights on warning light
    1840 Post(s)
    Mess around inside this panel at your peril, it contains the immobiliser and you can end up with a non starting car.
  3. Re: Instrument cluster - lights on warning light
    Sep 2020
    Saham, England
    If it’s a risky job, I’ll leave it or swap the whole unit out.
  4. Re: Instrument cluster - lights on warning light
    1840 Post(s)
    If you replace the unit is has to be coded and matched to the car, it is not plug and play. Often it is impossible to make a used unit work even with the proper equipment.
  5. Re: Instrument cluster - lights on warning light
    Sep 2020
    Saham, England
    I wonder why it has to be made so hard.
    will VCDS be needed to code the cluster?
  6. Re: Instrument cluster - lights on warning light
    1840 Post(s)
    VCDS can USUALLY do the coding as in the cars functions such as pad and screen wash warning but it CANNOT match the immobiliser section inside the dash to the engine ECU and learn the keys chip coding or enter the component protection ID, i.e. the VIN. This is made difficult because certain elements in society are of a nefarious nature and refuse to leave other peoples property alone. A new pod should only be matched using the VAG system ODIS in its GEKO security function, getting access to this second level of ODIS is very difficult for a non franchised repairer like myself but I felt inadequate without it, I hate relying on anyone else and especially the VAG dealers as they are rude, awkward and uncooperative. One chap that used to be the service manager at Volkswagen Nottingham when I was just starting out was a really helpful friendly chap that always took time to help me. His son came from there to work for me about 15 years ago and for the last five years, he has worked for me as well.
  7. Re: Instrument cluster - lights on warning light
    Mar 2007
    Brum
    I always thought the lights on light was part of the light switch on VWs which is why there’s light on symbol in the main dash panel.
    I’ve had B6 & B7 Passats, a mid noughties Touran and currently a MK7 Golf and all have had no lights on symbol on the main dash panel.
    2007 VW Touran Sport 2.0 TDI
    Pumpkin Android headunit
    1990 Mk2 Golf Driver 1.6, 1999 Passat SE 1.9 TDI, 2006 Passat Sport 2.0 TDI and 2012 Passat Est Sport 2.0 TDI - all gone but not forgotten.
  1. Replies: 6
    Last Post: 10-12-2021, 05:39 PM
  2. instrument cluster lights
    By sbt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2020, 01:20 AM
  3. Question Instrument Cluster Warning Message - A5 2017
    By rajadazz in forum 2.0TDi - Engine
    Last Post: 11-12-2017, 12:40 AM
  4. Coding Q7 instrument cluster to stop seat belt warning light
    By tune-tec in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-06-2008, 09:59 AM
  5. Removing Instrument Cluster On 2002 Golf V5 To Remove Emissions Warning Light Bulb
    By AndyV5 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 21-06-2007, 06:02 PM
